Sponsored by:
Sponsored by:
Swapping MMI control board anything I should know??
Old 11-14-2013, 02:30 PM
Smitty5534's Avatar
Default Swapping MMI control board anything I should know??
I'm swapping out control board with one that one of the kind members on here sold me. I'm just wondering if there's anything special I have to do other then maybe pull battery cables to make it work. Is there anyway to avoid component protection? And if it comes on is there anyway to turn it off without taking it to dealer? Thanks in advance guys!!
Old 11-14-2013, 03:23 PM
mishar's Avatar
No need to disconnect battery. Just strait forward replacement. There is nothing that you can do in order to prevent Component Protection and you have to go to a dealer to remove it.
Old 11-14-2013, 05:17 PM
viper04's Avatar
Default component protection
So is Louis mistaken or did he get lucky?
"You have component protection came on because you didn't select and omit all the components in your car when you replaced the gateway"
https://www.audiworld.com/forums/sho....php?t=2854737
Post 25
Old 11-14-2013, 08:57 PM
mishar's Avatar
Neither one. The only module he changed is Gateway and it doesn't manifest Component Protection like some other modules do, but there is a code registered. Hi added F-bas to his original MMI and other modules do not have Component Protection.
1loveaudi
A6 (C7 Platform) Discussion
10
03-24-2021 08:53 AM
Bullgator
01-26-2018 01:34 AM
benpitt
07-23-2015 12:01 PM
Mike141
05-16-2010 04:16 AM
MarkyC
08-27-2004 05:41 PM
Quick Reply: Swapping MMI control board anything I should know??
