Yellow and Green Adaptive Suspension Lights
2007 Audi A8L
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
Shop #: WSC 02313 785 00200
VCID: 285823E29B685B0181-807C
2 Faults Found:
01575 - Control Switched Off
000 - -
Freeze Frame:
Fault Status: 11100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 164
Mileage: 298684 km
Time Indication: 0
Date: 2018.02.22
Time: 03:50:11
00668 - Supply Voltage Terminal 30
009 - Open or Short to Ground
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 164
Mileage: 298684 km
Time Indication: 0
Date: 2018.02.22
Time: 03:50:11
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J6510BB
Coding: 1120503
VCID: 5CB04F329FB0C7A1D5-8008
1 Fault Found:
00778 - Steering Angle Sensor (G85)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 163
Mileage: 298684 km
Time Indication: 0
Date: 2018.02.22
Time: 03:26:49
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Address 01: Engine Labels: 079-907-560-BVJ.clb
Part No SW: 4E1 910 560 A HW: 4E1 907 560
Component: 4.2l V8/4V 0040
Revision: --H16--- Serial number: AUX3Z0F4794778
Coding: 01060009190F0120
Shop #: WSC 05927 444 87830
VCID: 20483BC2F358A341C9-8074
4 Faults Found:
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
If i turn the car off and back on again, it goes away...
The car doesn't seem to drive any different when the light comes on, all the suspension modes work as they should including lift mode and I don't notice the ride height changing...
Any ideas why this might be...?? Photos are of the car after its been sat running for 5 minutes, I know it's a little hard to tell but looks pretty level all round to me, there's no unusual noise or anything I've noticed even when the yellow light comes on...
