Sponsored by:
Sponsored by:
2013 Audi A8L D4 Door Panel Removal Help
Old 05-24-2019, 11:34 AM
Falcon7478's Avatar
Default 2013 Audi A8L D4 Door Panel Removal Help
Is there anyone knows how to remove the Front Door
Panel D4 Left and Right for Audi 2013 A8L.
I need to replace the woofers. I have attached some
photos of the Left and Right panel doors.
I was able to remove the screws located on the wood
trims but still unable to detach the panels.
Front Left wood trim removed
Front Right wood trim removed
Front Left
Front Right
Any photos you can share will be helpful.
I appreciate the help!
Old 05-25-2019, 12:38 AM
laurent0613's Avatar
You are on the right path.
Behind the wood trim.
Behind the small speaker grill
below the door handle. You see the switch, below it, look from down to up.
there are no screws next to the big speaker.
everything else are plastic rivets
why do you want to replace the speakers? And with what?
Old 05-25-2019, 09:41 AM
Falcon7478's Avatar
Thanks for the info. The two woofers are both
blown out.
Old 05-25-2019, 09:47 AM
Falcon7478's Avatar
blown out. Im replacing it with exactly the same
Bose woofers.
Old 10-21-2019, 10:33 AM
Jonohio's Avatar
Did you grab any pics of the door with the card removed?
FASTAXI
9
02-17-2009 07:01 PM
jmoors
TT (Mk2) Discussion
10-08-2007 11:27 AM
BoostFrenzy
09-11-2007 04:21 PM
Avantadrive_Original
04-12-2005 07:24 AM
odj
10-04-2001 04:29 PM
Quick Reply: 2013 Audi A8L D4 Door Panel Removal Help
