idle at 3000ish rpm
idle at 3000ish rpm
all of a sudden my 5000tq started to idle at like 3000 rpm and it was just running the best it has been in a while. but it idlews that high even when it is warm so it cant be the iac... so anyone have any ideas?
Re: idle at 3000ish rpm
See if you can disconnect the bypass at the throttle plate. If so it will idle very slow. You have unintended exceleration!!! There is a small module under the dash that has a bad resistor and needs to be fixed or replaced. The automatics had a different part from the 5sp. I had this happen on an 84 5000 a long time ago. Sorry I cant remember the name of the little unit, but it just unplugs.
