Power top problem: Could it be the trunks power lock actuator??
I ran accross a post about the trunk lock actuator going bad and causing the top to malfunction.
I messing around with the wires in the trunk and locking unlocking the trunk I found that the locking actuator is malfunctioning.
If you lock the car with the door key, the trunk doesn't lock. If you lock the trunk the doors will lock.
What do you think?
Also do you know were I could purchase the two wiring harnesses for the trunk lids,and the trunk switch, and trunk lock actuator cheap(no dealer)?
What do you think?
Mine has same conditions ...
by locking with the trunk, all doors will lock, by locking at the doors, all doors lock but trunk will not (also same results with the remote)
I thought it was normal for the door locks to not lock the trunk though, is it not?
as for wiring harness' try autox.biz or force5
Re: Not sure on Cabs, but on Sedans, the trunk will lock or not lock, depending on how
you used the key last. You can set the key cylinder so it will unlock (for normal, for example) or will stay locked (for valet).
Re: Mine has same conditions ...
I didn't know if the trunk should lock or not. I ran across it in a post (about the actuator problem)
Thats why I posted this to find out what should or shouldn't happen.
well according to the manual trunk should lock with doors..
and all can be locked from trunk as well.. Azeem said that he has same problem but his top works??? so now i think we need to look somewhere else
Steve W
15
01-24-2014 11:02 AM
Ringnalda
11-03-2006 07:18 AM
