OBDeleven Fault Codes
#11
You must of scanned the car while it was running as most of those faults show up because the car is on or moving.
Database errors usually show you because of a weak battery.
The recirc, try opening the piece in the glove box to see if something is stuck, the flap is located right above the filter if you take the filter out.
I'd email the fault codes to yourself to have on file, erase the codes and then see if they come up again. Be aware that from factory and/or while the dealer has the car before selling, a bunch of cars have faults without the owner knowing. Most of the time, when going into service, the car isn't scanned to see/erase them.
