20×10.5 +30 Wheels Fitment
I have a 2018 Audi RS5 Coupe completely stock ATM. I'm looking at a set of Verde Axis V99 20×10.5 with a +30 offset all the way around and I'm planning on lowering it on springs in the future.
1. Is it best to go with 285/30/20 or 295/30/20 since I don't want to sacrifice too much of the ride quality?
2. 295/30/20 or 295/25/30 since 295/30/20 is a pretty tall tire and I don't want it to make the car higher off the ground?
3. What size spacers will I need to have a flush fitment without rubbing the suspensions/fender?
TIA
TIA
Club AutoUnion
TIA
TIA
https://www.audiworld.com/forums/aud...tment-3037380/
This is a question that is hard to answer with a precise answer as to this will fit, not rub, allow you to lower the car and not contact the suspension. I didn't see you mention the tire brand you will be using, as it makes the biggest difference (in my opinion) because none of the manufacturers are standard on how it sits when mounted to the rim. You should decide what tire you will be running on the rim and see who has that brand to get more feedback from members using that tire/wheel combo. I'm sure you already seen this thread and all the information for you to get an idea how many things make up the stance. I originally was going to lower my car, but the taller 295/30 sidewall filled in the wheel well gap that was really bothering me on my '19 RS5 Sportback.
Also with the 9mm spacers up front, are you barely clearing the steering knuckle or do you have a lot of room to spare and only went with 9mm for a flush fitment?
Thanks.
Stock size (265/30-20) diameter=26.3"
295/30-20 diameter=27" (+2.7% difference from stock)
295/25-20 diameter=25.8" (-1.5% difference from stock)
Either size works as it is inside the acceptable percent difference. You can get closer to the stock dimension by mounting a 285/30-20 tire.
As Mortys66 mentions, tire sizes can vary significantly (mostly on width and not diameter) from various manufacturers. You need to be knowledgeable on the variance of suspension components if you drop the car. Dropping the car may require altering the camber to avoid rubbing.
____
EDIT: If you change suspension components (e.g. upper control arms) or camber to lower your car, you will be outside of Audi's support for tires, and probably more exclusions.
____
Club AutoUnion
Does your set up poke outside the fender at all with +25 offset all the way around and 9mm/3mm spacer or is it super flush?
Thanks.
Thanks.
It gives it a flush fit for me, others would say it doesn't... see pic's (these are what I can get now, until I look at what's already transferred to my home computer). The front was up against the steering knuckle at 7mm, I gave 2mm of room for movement on cornering, I adjusted the back to match the front.
Thanks for your immense help.
Club AutoUnion
As for the Headlights, Taillights, Marker Lights and Side Mirror Turn Indicator Light I wrapped them all using the following Light Wraps from Amazon: Front Headlights: - Luxe LightWrap Light Smoke Universal TintFront Marker Lights: - Luxe LightWrap Dark Smoke Universal Tint (over the LightWrap Light Smoke Univ Tint)Side Mirror Turn Indicator Light: - Luxe LightWrap Mid Smoke Universal TintRear Marker Lights: - Luxe LightWrap Dark Smoke Universal TintRear Taillights: - Luxe LightWrap Mid Smoke Universal TintRear License Plate Lights: - Luxe LightWrap Light Smoke Universal Tint
Luxe LightWrap Dark Smoke... Luxe LightWrap Mid Smoke... Luxe LightWrap Light Smoke...
ZThang
A4 allroad (B9 Platform) Discussion
08-25-2021 06:49 PM
