so i have a fault code for my engine speed sensor
is this for my crank angle sensor? The lil sensor with the metal rod the goes under the intake side of the engine towards the bottom? I checked it out and it didnt have a screw holding it in and so we found on that threads in and works right. Before this there was no sparking at all. I haven't had time to check to see if it sparks now that it's screw in right.
Additionally i wired my new fuel pump wrong and will have to be getting that back out to swap the wires, woo hoo. I just bought new tires and wheels today and want to put them on and now my car doesn't run >_<
Probably a result of the car not starting, not the cause but just in case, the FAQ has some info
<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/149828.phtml">Click here for more info</a></li></ul>
lberisha
05-22-2008 09:49 AM
Mitaka
02-07-2005 10:13 AM
BigMouse
04-01-2002 12:56 PM
