Please tell me the where to hook up a oil pressure gague...
I know it's on the block above the oil filter, and i saw there is a nut that you could remove using an allen wrench key. Is that it? Someone please show me a pic.
What about on a 1.8T?...
On mine, there is an oil line from the oil cooler going into the turbo. Think I should tap into that line? I think that's what I am going to tru now.
NO! There is an easy to get at fitting on the driver's side of the motor!
Look at the oil filter adapter on the motor. There is a sensor with a single wire hooked up there. It has a 10x1mm thread. Unscrew it and screw in a VDO T-fitting (part number on Rob's Page) and hook the sensor back to one leg of the t fitting, and the oil pressure sender to the other leg. If you have a VDO sender, it should be 10x1mm metric already. If you use Autometer, it'll be 1/8" NPT, which is tapered pipe thread. It will start to thread in to the 10x1mm opening, buut if you leave it it will leak badly, so get a 10x1mm to 1/8" NPT adapter or rethread the sender with a 10x1 mm tap.
Don't mess with the oil line to the turbo!
Low oil indicator, puddle of oil found near where oil filter is, please remind me what this is again
TonyA8
01-23-2009 03:00 AM
Which wire coming off of the oil sending unit on the oil pan do I tap into for a oil pressure guage?
SNogaro4
05-14-2006 07:24 PM
aerohr
13
03-22-2006 05:03 PM
Luxus Panzer
12v V6 Discussion
07-22-2004 12:44 PM
