Best all season tires for 2014 Audi Q5
#21
Warhead-
Coupla nice guys tried to play Oreo Sandwich with me one day, that's how I came to appreciate the ESC/ABS system and just how delicately a hippo can dance. Now if Audi would only get on the program and sell pink tutu's in the correct size...
There is no TPMS in my Q5. No sensor hardware in the wheels at all. The car uses the pulses from the ABS system to figure out if one tire is low, which is very nice, although a PITA because it doesn't tell you WHICH wheel, and that wheel has to be about 6psi down before it trips. Possibly all the older systems with TPMS sensors used metal stubs, while all the new ones use rubber? Or vice-versa?
Or do the SQ's really still use TPMS to be more precise and sporty?
#22
Warhead-
#23
Warhead-
AUDI service should be able to amend the spec xml parameters (as sold) also called PR codes and register them to the audi on-line database. Their system does not allow this flexibility.
E.g. keyless entry, laptimer, TPMS, door warning and puddle lights retrofit, power tail gate, security alarm retrofit, and many other can be retrofitted later.
#24
Warhead-
#25
when we bought our airstream trailer , we added a 6(4 for the q5 + 2 for the trailer) channel temp/pressure sensor. then sell it upto 22 channel
EEZTire Tire Pressure Monitoring System - 6 Sensors (TPMS)
it works very well
you set low and high pressure and high temp
it is wireless and replaces your tire vale cap
it also locks on and cant be removed without a tool
i got mine off Amazon
i will move the 4 caps to my winter tire this winter
it is on my car 100% of the time, wi the trailer or note
it works very well
#26
it works very well
it works very well
#27
I just got a set of Conti DWS06's, I like them so far. I have had good luck with the original DWS's on two other cars, they were very smooth riding and quiet with good handling. My first impression of the DWS06's is that they are slightly less smooth and quiet but better handling, a compromise I am willing to live with as long as they do not get any harsher than they are now.
Other than that, I have nothing to add to this thread. I have only ever bought Continental tires, I am very brand loyal, however if these don't work out I'll be looking into something along the lines of a grand touring tire that's super smooth and quiet, but I have no need for any snow capability since I'm down in Texas.
#28
My prior tires were Goodyear Eagle LS2's OEM's which were pretty good. Got 42,000 miles on those.
mroberte
Audi A3 / S3 / RS 3 MKII
158
08-31-2020 11:32 AM
Audi Other SET OF 4 NEW TIRES PIRELLI 245 45 17 $400
uragan1955
10-25-2016 06:30 AM
plat27265
10
10-25-2016 04:28 AM
Corey
01-17-1999 08:18 AM
