New phone - bluetooth issues
I just got a new Motorola Droid X2. I paired the phone with the bluetooth and the phone works but my contact list on the MMI is blank. I can receive calls but I can't make them via the voice command because the contact list is blank. I went into the phone settings in the MMI and did the "import contact list" but I am still having the same issue. Any help would be greatly appreciated.
In order for your MMI to import or access your contacts, the Phonebook Access protocol must be enabled. By default that procedure is automatically executed AFTER your initial pairing with the MMI.
I'd unpair and then delete both devices from each other then on your phone, add MMI first then watch for a second bluetooth access/pair request. At least that's how it behaves on my phones, Android or not.
You might also want to always enable authorization to the MMI on your phone.
Also, it could be a software issue (the phone).
I hate my Driod X. My issues that I've had for over a month now is dialing a number through blue tooth/voice command. I'll hit the button on the steering wheel and say call "chris". The call won't connect and I get the error message stating my phone doesn't support this function. Start the call over again and it works just fine. Really annoying because everything worked great before motorola sent out some damn software update for the phone. On my second Driod X now and it's still the same problem.
chyates
S6 (C7 Platform) Discussion
20
03-31-2020 08:21 PM
NVR_FOLO
Q7 MK 1 Discussion
12-19-2006 06:27 AM
