Top View Camera changing to graphic mode?
#111
yes 18 since February. For the longest time couldn’t figure out why my view kept switching in reverse. Since the key FOB thing. Solid in camera view.
Another time I noticed setting change is when my wife pushes setting 2 for driver. Even when I set my setting back to 1, the Q would default back to hers. Then one day I left my keys on the counsel. Seat settings stayed...and then the camera view stayed
#112
Have you tried "unchecking" toggling front/rear camera automatically (in that same menu as the graphic view)? Someone had posted that was the "dealer fix" (obviously not a "fix"). It would be that random situation that might be causing it to revert to graphic. It's not all driving situations that the front camera toggles on.
#113
#114
Actually tried all variations of automation on/off, and nothing lasted - eventually reverted when backing up. It may have reduced the incidence - didn't count - but nothing so far works permanently. I'm inclined to agree with Audi - this is a software problem. And it's obviously not their top priority to address.
#115
There is a thread on the new TSB that just came out...
https://www.audiworld.com/forums/q7-...verse-2960885/
#117
Here is what the service invoice says:
C/S BACKUP CAMERA WILL NOT STAY SET ON TOP VIEW. (SOFTWARE UPDATE AVAILABLE)
svm code update performed created for VIN , technical service bulletin pending.
(Spellings, punctuation, and caps are as they appeared on the invoice.)
I am going back tomorrow to have my S5 Cab updated as well.
#119
Thanks for the update. Let's hope that this actually fixes the issue. I have a couple questions though -- were you able to retract your MMI screen while driving before the update, and can you do it after? I have an early build 2018 and I can retract my MMI while driving. I fear that any software update will disable that feature.
#120
