Now I'm perplexed... TBB is fine, but have a over boost problem.
Symptoms: low rpm WOT leads to a big spike in boost (20 psi), back down to 10-12, and slow climb again.
Car: '01.5 6 speed, running AMS T-Box. All else stock.
I thought it was a TBB, so I pulled it off, and it's in perfect shape.
I did a pressure test, and at 10 psi the Y-Pipe to DV hose springs a large leak. I can't tell if there's any other leaks.
Where else should I look? The IC hoses look fine. I didn't hear any whooshing or anything.
The car has NEVER done anything like this before.
Thoughts?
Thoughts?
It can be but they usually fail the other way boost wise. Check your wastegate
lines to make sure they're not leaking. That can cause what you're seeing.
After you do that shoot me an email and I'll tell you what to log and all to see if something else is the problem. I assume you have no DTCs?
svenson69
2.7T V6 Discussion
15
04-25-2007 04:05 PM
avantissimo nogaro
09-14-2004 11:03 AM
denic992-- JAYHAWK
09-14-2004 09:39 AM
davematthews-S4
10-22-2002 03:22 PM
