Thinking about a set of K04's. More inside...
Old 04-03-2008, 02:33 PM
  #31
lemieux@curbside's Avatar
Default well in that case i'll do it ! just make sure they don't leak oil
other than that they should last you a while ..and if you'll do the work yourself and don't mind u'll make it worth it no doubt , but the equation would change if you'd have to pay someone to do it .
16 psi + MBC +TCD will work for you
and if they turbos are ok they'll hold up @16 psi for a while if everything else is good (no boost leaks).
Old 04-03-2008, 02:53 PM
  #32
2001s4loored's Avatar
Default Sweet, I might do it then. However, the only problem is that I have APR software, and from
what I hear, most people say it doesn't take well to a MBC...so what should I do? Also, I found another set with about 20,000 miles on them for the same money, but they have a *tiny* nick in one of the compressors. I can get a compressor blade from audspeed for $95, and then get it balanced. Which option would be better do you think? And could I still homebrew on APR or would I have to do GIAC?
Old 04-03-2008, 04:01 PM
  #33
Default i'd prob stick to what's together and working already (50kmi ones)
and i think you can run the APR with KO4-s (MBC just to limit the original spike - that might not be a problem anyway), maybe a 5 bar FPR to be on the safe side (and see if it'll require some fuel pulled with lemmi when you log it).
maybe someone that tried that already can chime in.
Old 04-03-2008, 06:51 PM
  #34
Default Alright, but what if you just replaced the compressor wheel and had a shop balance it? Wouldn't
you be better off with lower milage?
Old 04-03-2008, 08:43 PM
  #35
S40RCE:Smurf's Avatar
Or within the first 5 minutes
Old 04-04-2008, 11:18 AM
  #36
Default man that shop is no Borg Warner i tell ya .. not sure i'd trust it as much
plus these turbos "need" servicing in pairs .. and if the fins are bent .. i'm not sure how well those turbos were treated regardless of mileage , honestly.
2001s4loored
19
11-23-2007 02:21 PM
CMS4
21
10-19-2005 02:16 PM
matthewk
9
02-08-2002 07:26 AM
BenM@University Audi
11
05-01-2001 04:34 AM
Quick Reply: Thinking about a set of K04's. More inside...
