PDA
View Full Version : 3.2 24v VR6
  1. 2006 a3 vr6 3.2 (8P)
  2. 2011 Q5 3.2l V6 Odd malfunction
  3. 2006 A6 Quattro Camshaft position codes
  4. 2009 A5quattro 3.2L oil leak spots and gas consumption
  5. 08 a6 3.2 engine swap to a 4.2
  6. Audi indy shop in SW Houston?
  7. 2011 Audi a6 3.0T engine swap
  8. Oil leak below intake manifold - Audi Q5 2011 3.2
  9. A6 3.2 throwing multiple engine codes
  10. Audi 2011 Q5 3.2 How to access injector on cylinder #3
  11. Radiator Fans Out of Balance ??
  12. 12 q5 3.2 timming code again
  13. Codes P0491 and 492 Secondary Air Injection
  14. 2010 Q5 3.2 Water Pump DYI
  15. Rattling noise 3.2 FSI
  16. 2011 Q5 Timing Chain Replacement
  17. Mk2 Audi TT Quattro 3.2l Project Modified Throttle Body & Subframe Install
  18. 034motorsports ECU & TCU/DSG Stage 2 Tune
  19. CTS Turbo Intake Install
  20. 3.2L cv axle identification
  21. 2005 Audi A6 short serpentine belt A/C bypass
  22. Q5 3.2 Trouble
  23. Anyone knows a good guide for o2e DQ250 removal?
  24. H?
  25. Camshaft Position sensor B code P0391
  26. Replacing A/C Compressor
  27. Redline a day keeps the carbon away?
  28. Any tips 2012 q5 3.2 p0019 crankshaft position correlation b2 sb
  29. Hi, NEED some help with my A6 C6
  30. IAT Sensor Location 2010 Audi Q5 3.2 Premium Plus
  31. 2007 a6 3.2 quattro rich banks 1 and 2 Help Help
  32. 2009 q5 misfire
  33. 2008 A6/S6 repair manual ?
  34. P2294/$07E Fuel Pressure Reg 2 Code?????
  35. Things to look for, 2010 Q5 3.2.
  36. 3.2 timing chain tensioner issue
  37. Audi A5 3.2l 2008 Emission Control Warning Light
  38. Power steering pump
  39. 2006 Audi A4 3.2. No spark on bank 1 passenger side
  40. 3.2 Transmission
  41. 2006 A4 3.2L Intake Camshaft Bank 2
  42. 2008 Audi A4 b7 3.2L struggles to start in cold
  43. Help P0301 P0303 P0300 EPC light Q5
  44. Engine hits hard stop when rotating by hand
  45. 2006 A6 3.2 liter rear main seal installation
  46. 2010 Audi Q5 3.2 (CALB) noise under 1-3 valve cover & #3 misfire
  47. won't start 3
  48. won't start
  49. won't start
  50. What work to do when opening up engine for valve covers
  51. 2005 a6 3.2 misfire / hesitation
  52. 18082 - Powertrain Data Bus: Implausible Message from Instrument Cluster
  53. 2004 Audi TT 3.2L V6 issues
  54. 2011 Q5 3.2L Engine Air Filter Housing
  55. Please help... A6 3.2 Intake CAM Bank 1. W/ pics
  56. I need help!
  57. Which 0W-40 synth is better, mobil one or castrol edge?
  58. '06 Audi A3 3.2 Quattro alternator replacement
  59. 2006 Audi A4 B7 3.2L oil leaks
  60. Strange noise in Audi A3 3.2 Quattro MY2005
  61. Fault Code - P2857 Clutch A Pressure??
  62. Gumout "Renevate" dfi intake spray cleaner
  63. A5 clutch switch problem?
  64. Fuel pressure regulator problems?
  65. 3.2L Groggy Performance
  66. Trouble with timling chain 3.2 A3 DSG - lot of questions.
  67. Help leak oil then pulled coils 4 out of 6 covered in oil
  68. 05 audi a6 quattro 3.2 esp fault with check engine light on
  69. 2005 a6 3.2 fueling issues?
  70. Anyone know this part number? Lower intake manifold
  71. Former 2.7t owner; data on 3.2 durability?
  72. Replacing engine or selling A6 2006?
  73. Multiple A6 3.2l oil leaks help
  74. 2005 A6 3.2 litre quattro ENGINE BLOWN!!!
  75. What is the procedure to test the IM tuning valve position sensor
  76. 2007 A3 3.2 coolant leak
  77. Modifying the 3.2 24valve VR6
  78. Misfire in MN winter
  79. What is this piece and is there a missing clamp?
  80. Slow oil leak
  81. Oil Catch Can for Mk I TT 3.2
  82. My engine is making this weird noise ... Video Inside
  83. 2006 A3 3.2 Idle Issue
  84. c6 error codes
  85. APTuning Black Friday Weekend Sale - Custom Euro Plates - APR - United Motorsport
  86. Need to replace 3.2 engine off A6
  87. car chugs, possible isv?
  88. What to do with my Audi Q5 3.2 Engine?
  89. another 50 hp
  90. Temp gauge at 0 and fans run all the time
  91. APTuning/APR December to Remember Holiday sale!!!
  92. My first Dyno test, need opinions
  93. Revo Technik Spring Sale Marth 27th - April 11th 2010
  94. sludge et al?????
  95. APTuning/APR Holiday Sale Has Begun, Nov. 23rd-Dec. 31st!!!
  96. Replacing pump valve unit in 2005 Audi A6
  97. *Revo Technik continues to expand its authorized tuning network with 4 new dealers.*
  98. Looking for a TUV Ceritified Body-Collision Shop
  99. 3.2 #3 Misfires
  100. Number one!! !!!1111one!!! Yay. Who's done a VR6 swap lately?
  101. best spark plugs?
  102. APR's Spring Into Power Sale March 9th- April 10th
  103. THE A4, A6 ARE NOT VR6 ENGINES, PLEASE POST IN THE APPROPRIATE FORUM. THANK YOU!
  104. 2006 A6
  105. 2006 A3 3.2L V6 Thermostat Replacement P2181 Engine Code
  106. a4 avant...2.0t vs. 3.2 v6
  107. Anyone want a mk5 R32 Eurojet Exhaust?
  108. help for new transplant
  109. 2009 TT S-Tronic 2.0 Versus 3.2
  110. ENGINE SHUTTING DOWN 2008 A6 3.2
  111. Exploded View
  112. Looking for a 98 vr6 MAF
  113. 2007 Audi A6 S-line on 20 inch wheels
  114. Where exactly is the coolant temp sensor in our engine bays?
  115. Forced to buy new A6 3.2 engine after just 3 yrs & 43k miles - Audi UK will only pay half
  116. Any advice on how to squeeze out a little more power from my 3.2. Thanks
  117. APR Motorsport Vacation Raffle Today!
  118. Engine ecu replacement
  119. APR and Jim Ellis Audi present Petit LeMans Customer Appreciation Weekend
  120. Expensive problem
  121. Looking for an air intake system. Any recommendations
  122. New Car?? I'm very close to purchasing a 07 A4 please advise.
  123. mods?
  124. 12
  125. Are these the same VR6's as in the GTi's?
  126. DSG Failure
  127. S/C for 3.2 V6 quattro?
  128. Audi technicians: here's a unique opportunity
  129. 2005 A6 3.2 - octane question
  130. Happy New year to the VR6 3.2 crew..
  131. 2007 A6 3.2 FSI
  132. DSG gearbox, oil/fluid spec/grade?
  133. APR Announces H2o International Sale offered throughout North America!
  134. Still no 3.6 VR6 FSI forum.
  135. *crickets*
  136. Boost 3.2 HP from 255 to 300
  137. turbo for b7 a4 3.2?
  138. Mad project request
  139. Looking for 3.2 L 6spd owners any out there???
  140. 3.2 in RoadJet Concept
  141. Audi Expo 2006 - Come be a part of history again!
  142. is the 3.2 in the Mk 2 TT any different than the old?
  143. Audi Expo 2006 - It's coming!!!!
  144. Audi 3.2 litre VR6 engine, cast iron or aluminium block.
  145. Anyone done or heard of anyone that has done the AMD V6 3.2 STAGE 3?
  146. A.W.E. Tuning at H2O International September 25th
  147. has anyone turbocharged the r32?
  148. 5th Annual Audi Expo - Schedule:
  149. 9 days 'til Audi Expo! - Have we heard from you ?
  150. 5th Annual Audi Expo - Come be a part of history again!
  151. 5th Annual Audi Expo! - It's coming!!!
  152. 3.2 huh
  153. nice, new forum! welcome everyone to the quattro 3.2 world
  154. How to post Pictures in thread??? Pic of my intake on 3.2 TT
  155. Anyone know the limitations of torque on the DSG?
  156. 3.2l 6 speed bi-turbo TT...
  157. anyone ever read that issue of european car where they show cased all those turbo charged R32's??
  158. Anyone Chip their 3.2?
  159. Welcome to the 3.2 24v VR6 forum
