- Audi SQ5 2016 - Drive Select Coding *Newbie*
- Audio amp pin-out needed.
- UK: Q5 TFSI QUATTRO S LINE 2009 Petrol FSH
- Q5 3.2L timing chain/guide issues - inevitable? anything to do preventably?
- 2013 Q5 DRL not working
- just picked up a 2012 3.2L - had a few basic questions to try and get some direction?
- Question: Q5 3.2L CALB engine swap- are there any changes from 2011 to 2012?
- drivers side intake manifold removal ?
- 2012 Q5 Lower Control Arm Replacement
- P0299 Code
- Plug & Play Color Changing footwells or solid white, red or blue footwells
- CA: Moving to USA. Can I take my 2018 Audi q5?
- P2015 and 00473-013 codes, any suggestions?
- Whining noise under load at certain speed
- Warning light : P circle with electric red
- Tailgate motors Q5 2013
- part number-rear bumper left lens
- Shuddering During Heavy Rain - Causes?
- Clicking / knocking noise coming from front passenger side
- 2015 Q5 Power Outlet (cig lighter) in Center Console - replacement
- 2013 Q5 3.0 MAP Sensor Gas/Oil Residue
- Water puddling in gas door and over the tire jacks
- 2021 Q5 Sportback
- TPMS wont reset after new tires
- Sunroof sunshade replacement 0 for 2
- 2014 2.0T Q5 Ticking when accelerating up hill
- 2010 3.2L Stalled, codes: P0019 & misfires on cly 4,5,6 - Please help me diagnose
- 2009 3.2 Starting Issue Low RPM / Stalls out
- 2009 q5 AMI issue.
- SQ5 Tailgate Lower Trim Squeak/Rattle
- Fred Meyer fuel?
- 2.0T preemptive water manifold replacement at 90K miles
- Fuel pressure regulator change, car not starting!
- CY: audi q5 diesel 2009, problem with ignition?
- Keyless Entry, Proximity Feature
- One radio station not working
- Q5 sunshade
- 2015 Q5 Coolant Hose
- 2012 With Bad Turbo?
- Q5 Windshield auto mode not working
- Spark plug destroyed Q5 engine
- Help! Check engine / Turbo problem (?)
- 2011 Audi Q5 Engine Swap? NEED HELP
- Help selecting a cabin air filter brand?
- Adaptive Cruise problem and Cornering Lamps
- Need a new windshield on my 2015 Q5. Who is the best to go through to have this done?
- Disconnecting battery for RSNav install
- 2015 Q5 3T - P52E00 fault?
- Missing a trim piece
- Exterior car cover ?
- 2012 Q5 Suspension Noise
- Q5 Skid plate/armor?
- Etka pringing problem
- performance tuning options ???
- 2012 ADI Q5 3.2 - S Line?
- 2012 Q5 3.2 Premium Plus - Backup Camera and Streaming Bluetooth
- Splash shield tore
- 2013 Audi Q5 change the grille
- GPS direction arrow 2018 Q5
- 2014 Q5 TDI
- Weak brakes, low pedal, ABS helps - weird issue
- Q5 OEM Trailer hitch retrofit
- When was heated steering and foot opening hatch available in Canada?
- 2014 Audi Q5 Scan Report
- does the 2021 Q5 have mag ride?
- 2 Upgrades to my Q5 TDI: Malone Stage 2 & New Steering Wheel
- Q5 TDI coolant question
- SQ5 Control Arm question
- 2018 Q5 - what should I know?
- 2011 Q5 won’t start ( intermittently) PO190 and PO343
- 2015 Audi Q5 3.0T Hood Seal missing, need help figuring out.
- Best OEM Brake Discs/Pads for 2016 2.0 TDI Q5 S Line
- IAT sensor code P0113
- Pasenger Airbag light is on - VCDS showing an error
- Brake rattle/ringing
- CEL and EPC / misfire cyl#2 - no other threads post a final fix
- Added vented seats
- Q5 rear diff and injectors
- 2015 D3S bulb OEM K rating and manufacturer?
- Audi Q5 2010 Alternator Failed, battery failed
- Considering chipping my 2017 Q5 3.0T. Thoughts?
- Where can I find a Q5 Quattro Hybrid (2012) Repair Manual?
- Need engine replaced in 2012 Q5 - AL, TN, or MS
- Gear box malfunction
- 2014 q5, steering control roller issue
- Gaining ground clearance on a 2011 Q5 3.2
- 2015 Audi Q5 Timing chain replacement?
- 2014 Q5 Tdi 3.0
- Engine Check light - P0491 Carbon Build up !!
- passenger airbags crash sensor ?/
- 0B5 box disconnecting
- Q5 MK1 Tail lights coding
- Sunroof mesh
- P0492 and 17620 codes
- SE: A/C Nightmares - Help! 2012 Audi Q5 Hybrid
- Water inside headlight due to crack - how to dry out?
- q5 passenger B pillar external trim help
- vin decoder help needed please
- Ambient Lightning Installation
- 2014 SQ5 Rattle
- Oxygen Sensor - P0158
- Slight fog on windshield when using AC
- 2013 Audi Q5 ALOT of OBD2 Codes
- Air conditioning compressor running when AC button not pressed?
- will the Break warning system actually apply brakes?
- UK: Aircon blowing hot or ambient air
- 2014 Q5 TDI - remote trunk
- Voltage reading on a Q5-2016
- Adaptive Headlight Defective Warning Indicator - Fix or disable?
- Which Lane assist is giving me fits
- testing adaptive lighting ..
- Air intakes?
- NEW BOSCH WIPERS CHATTERING BADLY
- Anyone with experience with Renewable Diesel?
- 2015 Q5 cold start issues
- B20 Biodiesel
- Squirrel turds
- Shutting off Compressor / Fan
- Transmission Oil Service
- Potential New Owner
- OEM Roof Box/Carrier P/N?
- Steering pump and and high pressure hose replacement
- Possible to repair door lock?
- Urgent. Need help! Misfiring in cylinders 4, 5, 6
- Roar Pedal Throttle Controller
- Reason for concern?
- Weird A/C and Horn Issue - Summer Heat
- BG: Q5 engine flush
- Oil burner
- Anyway to see tire pressure without a guage?
- Fault code on my uk Audi SQ5 reads DTC:-P204B00 parts code required
- Q5 Sportback color pick
- how do you enter LAt and LONg to MMI interface
- Rough idle when cold- causes?
- Sirius XM ant connection, where is it?
- Modifying Q5 3.0TDi Quattro (2013-2016)
- Open up trunk handle
- Electromechanical Steering Unit Extended Warranty Letter
- Audi Symphony and Display Cluster Problem
- Buying my first audi
- 2018 Q5 lookg for a rood rack cross bars and Cargo carrie
- mystery bolt found on pass floor?
- Q5 TDI 2017 Air Con Top Up Valve
- Service Due Light Reset
- 09 Q5 Air Bag/Parking Brake Malfunction/P0068
- Replacing front brake pad and rotors?
- Low Pressure Intake Fuel Pump
- Major Oil Leak.. Please help!
- Going to need some detectives.
- 2017 AUDI Q5 with metal pieces circulating through engine
- 2012 Q5 Tensioner replaced. Single click after startup?
- Weird jerk on SQ5
- Audi Concert - changing radio station with single dial turn?
- 2015 Q5 TDI CELs
- UK: Power Steering Getting Heavier
- 2012 Audi Q5 EPC light P034100 and P150A00?
- 2011 Q5 MMI. SCREEN not staying on.
- 2011 Q5 Modification
- 2012 Audi Q5 diesel oil sensor location
- DPF to turbo pipe
- Audi Vent Tab Replacement
- 2014 Q5 EPC issues
- New headlights
- Rear wiper arm replacement with a traditional attachment?
- Wiring Entry - Weather Seals ETC - Antenna / Solar
- 2015 SQ5 MMI / MOST Loop Help / Diagram
- 17" wheels on '15 Q5 Prestige S line?
- Q5 TDI Owner: My Next Car Musings…
- Stopping whining isn't that easy.
- i need a better spolier
- Is there a CarPlay Retrofit for the 2014 Q5 MMI that actually works?
- 2016 vs 2017 SQ5 Help
- Disable "Navigation not active" voice via VAG-COM?
- 2015 q5 rear bumper loose - need assistance
- Shopping for a used Q5 - Need Advice!
- Advice: Used Q5 TDI 2014/2015
- How to remove parking / esp / hill descend button?
- OBDeleven Scan - Shed some light?
- 2012 Audi Q5 2.0t miss-fire
- I have trust issues
- Strut brace delete
- Cleaning the top of the head: a cheap and fast method
- Extend battery life by locking your car?
- 3.2 FSI known oil pump or rod bearing issues?
- 2.0T owners check your coolant reservoir
- 2021 Audi Q5 Headlight question
- 2011 Audi Q5 Rear Bumper Lower Valance Cover w/hitch
- Aftermarket parts- your experience?
- Dead battery, no warning signs
- MAJOR oil consumption issue - 2015 Q5 2.0T
- PSA: Tire rack warranty is fantastic
- How many Folks here have stage?
- 2014 SQ5 136k Miles
- Help needed- cannot disconnect upper radiator hose from radiator
- Q5 Rear Hatch
- Aftermarket Touchscreen with CarPlay?
- 2015 Q5 2.0t oil consumption
- CV axle torque specs for 2015 Q5?
- Best steering wheel cover for 2016 SQ5?
- Stage 1 done this morning by
- Headlight conversion?
- VagCom / VCDS mod for disabling fogs on convenience exit car?
- Occasional gas smell in cabin
- Prevent SAI ports are clogging on the 3s?
- Gas mileage?
- Corrosion of Aluminium Trim - how did you fix it?
- Stage 1 for Q5 TFSI EA888.3 - manual transmission
- Intermittent power to MMI, screen, control board
- Battery disconnect for blower fan replacement
- Random Key Not Detected Message's
- Your opinion is needed- dealer vs. independent Audi specialist?
- Anyone fixed the radiator hose?
- Bubble on back roof
- Water Pump Replaced - New Issues - 3.0T
- Q5 2.0t
- Brake light!
- Did the shop sabotage my CV boot?
- Main ECU logic
- USA: Torque converter noise, 8HP
- Torque converter noise
- A/C & mass air flow sensor
- VCDS vs OBDEleven
- Anyone know where to get Explosion Diagrams for 2012 Q5?
- What are these bolts and how do I get them out of the ceiling?
- SQ5 Paint Code Location
- Thinking of Q5 2.0, need advice
- Homelink Pairing Issue + Side assist fix (Video)
- EagleTunning
- Audi dealer replacing suspension bushing
- 2021 Q5e electrical system malfunction
- Front Wheel Bearing Removal Help
- P2293 error code with heavy smoke from exhaust pipe
- Anyone changed valve cover gaskets on 3.2L ?
- Need help identifying trouble codes
- Jogon Sequential LED Dynamic Turn Signal Light review
- 18 Audi Q5 SRS Module
- PA: Audi Q5 keeps asking for a quarter of oil per week
- wiring Curt 59236 on '13 Q5
- Replacing Audi Symphony with Apple Carplay but no MMi
- Wiring schematic: 06E971627S Drivers side fuel injector loom question.
- 2011 Q5 - 36-Seat Memory Driver and more
- Sunroof rattle fixed: it took 5 years!
- 034motorsports control arms or Audi direct replacement
- 2016 Q5 Premier AWD OIL ISSUES
- tilting pass mirror
- sideview mirror switch
- 2015 SQ5 - LOUD popping sound when steering in reverse
- Oil Filter Issue 2.0T ?
- After run coolant pump, it just keeps getting better....
