PDA
View Full Version : Q5/SQ5 MKI (8R) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66
  1. Rear sensors with hitch style bike rackE
  2. 2016 BLUETOOTH q5
  3. Mirror puddle light
  4. Cylinder4 Loss of Pressure?
  5. Mystery model designation?
  6. Q5 oil drain - sucking waste oil into the tank
  7. Help: Door alignment is off
  8. How to Replace Air Filter and Snow Screen
  9. How to Replace Cabin Air Filter Audi Q5
  10. Trail hitch
  11. P0304 code on a Q5
  12. White Q5 powder coating
  13. Modification #2 -pics
  14. Could Service appt. cause Audi Adaptive Light Defective message?
  15. P219F Fault code - Fuel air mixture cylinder #4 unbalanced
  16. Audi Maintenance
  17. Bang Olufsen Subwoofer Upgrade?
  18. Maxpeedrods Turbochargers?
  19. 2010 Q5 Best, least expensive tire set?
  20. Another successful engine swap - CAEB TO CPMB
  21. 2017 Q5 radio
  22. SQ5 COVID Purchase - Thoughts on Discount/Approach?
  23. Help me Identify this part
  24. What Power Steering Fluid to us in my 2012 3.2?
  25. Q5: What’s up with my injectors?
  26. Limited Sale Pricing - Q5 Pre-Facelift Bi-Xenon Eurolights...
  27. Audi Q5 2013 "Jumps" afetr parking brake released
  28. Heads up
  29. 2016 Q5 Water pump leaking
  30. Pano-Sunshade repair
  31. Q5 AC not working 2014 TDI
  32. 3.2 Q5 Oil Leak
  33. 2010 - 2012 VIN change?
  34. Green leak behind drivers side front tire
  35. Q5 Panoroof Adjustment/Alignment? HELP!!
  36. Welding aluminium bung on transmission case
  37. 2012 audi Q5 2.0t modification
  38. 2012 audi Q5 2.0T: flashing EPC, low oil pressure
  39. $ Deal on SQ5 21" Tires
  40. car smells when opening windows
  41. Newbie OBDeleven questions
  42. Shut off car & check coolant?
  43. 2014 Q5 TDI - Brake Upgrades?
  44. Purchase advice Q5 3.0?
  45. New member..MMI question
  46. MMI coding for B&O sub volume control
  47. new Q5 owner - former vw owner
  48. P0229 fault code - low boost amoung other issues
  49. 2011 3.2 Motor Throwing Code po172
  50. Total TDI production numbers?
  51. HELP Right Side Fuse Box Removeal
  52. Audi Drive Select Individual for Q5 / SQ5 with mmi Prefacelift
  53. 2015 Q5 TDI 3.0 Malone Stage 2 with EGR delete impressions
  54. Auto to Manual Trans swap
  55. Need help with finding the Part number of these fasteners
  56. Right Side Fuse Box Removeal
  57. 2017 Q5 S-Line Splash guards
  58. Need for Speed... MMI Hardware Update Available?
  59. USA: Rear License Plate?
  60. Front rotor - would you replace? 28.6mm?
  61. Q5 TDI 155k Miles, Replace Suspension with Stock Parts??
  62. BRAKE sensor tripped with good pads
  63. 2014 TDI break rotors
  64. Help removing headlight housing
  65. 2009 Q5 Accelerator pedal VAG readings
  66. How to disable lights out warning?
  67. 2012 Q5 2.0T oil change now Crank sensor light on
  68. Best Oil Brand: 2013 Audi Q5 2.0T
  69. Rear Hatch Remote Closing?
  70. New tires needed for my 2016 Q5
  71. 2016 SQ5 Grill Replacement
  72. Steering wheel issue
  73. Hack for Radio?
  74. clicking evap valve???
  75. TPMS Malfuction
  76. Front ADS G Sensor Video Camera 1080P USB 32GB for Android
  77. "Xenon" bulb replacement
  78. Can not find Headlamp Range Control Module
  79. Q5 - Cabin Water Leak
  80. Q5 setup headlight converter on/off???
  81. Feeling my tire like it has a flat spot
  82. Mmi software, maps update, door problem
  83. SSR AUTOBODY ♖ | SoCal's #1 Source for Quality European Collision Repair!
  84. Q5 VS Forester
  85. Taillights not working after Rear bumper light replacement
  86. Navigation update for 2017 Q5
  87. 2014 Q5 2.0L Needs New Engine - HELP!
  88. 2014 Q5 DEF cap
  89. SQ5 front brake pads are how much?
  90. Parking Assist and Reverse Camera System Failure
  91. I love my Q5... but
  92. 2010 Q5 Lower Control Arm Bushings Leaking ?!
  93. Upper timing chain cover
  94. P2177/P0177 diagnosis?
  95. Vaccun pump repair/replacement HPFP roller tappet replacement
  96. 2015 Q5 TDI in accident
  97. Beep, mapping & running
  98. Q5 Hybrid, touchy. Is it normal?
  99. 10W40 full synthetic for 2.0tfsi
  100. Loud whirring noise coming from drives side front tyre.
  101. White spots under paint
  102. 2016 Q5 carplay
  103. Coilover questions (rattle, height, compliance)
  104. Production/Build dates
  105. Jerky downshifts
  106. 2012 Q5 has a gas smell when i am walking around it
  107. Xenon head light 35w or 55w ?
  108. Audi Care good deal or not?
  109. Driver Door Switches Quit Working
  110. Fog light Audi q5 is there high low and low beam?
  111. What type oil for best performance
  112. Replacing exhaust hanger
  113. Axle Oil after Wheel Bearing/Hub Replacement?
  114. 4 wheel brake pads/rotors replacement cost.
  115. 2011 Audi Q5 Electronics Problems
  116. Cigaretter lighter sockets not working
  117. 2015 Q5 loses heat and AC after 10-15 minutes
  118. 2010 Q5 Front Seat removal and heat repair
  119. Purchasing higher mileage Q5?
  120. Q5e charging issues
  121. 2014 Q5 3.0 brake pad sensor replacement question.
  122. Oil Consumption Issue
  123. Audi Q5 Cold Start Exhaust "misfiring" and Vibration
  124. Audi Q 5 2.0 TFSI 2011
  125. Back up camera
  126. Q5 axle replacement help, please (actually the bearing)
  127. Steering Rack
  128. HK: Q5 spark plugs?
  129. Any aftermarket alternators that are cheaper than OEM??
  130. Q5: epc light?
  131. How to fix the rear lower bumper cover?
  132. 3.2 Q5 Electrical issue
  133. Audi Connect
  134. 2014 Rear Tail Light Section Intermittent
  135. 2014 Q5 Parking Assist Issue
  136. 1st gen or 2nd gen
  137. 2012 Q5 with oil consumption issue now seems normal
  138. VAG COM Missing Message
  139. 2016 Q5 2.0T Quattro low oil light/optional dipstick?
  140. 2016 SQ5 common problems? Carbon blast, maintenance nightmare etc?
  141. LT: Buying a salvage-fixed Audi Q5?
  142. UK: Audi Q5 2013 Issues
  143. Q5 sway upgrades...
  144. 4cyl Q5 MAP Pressure Sensor
  145. Canada 12years rust warranty
  146. UK: Audi Q5 Engine faliure - Snapped Crankshaft
  147. Extra ledbar on Audi q5 2009
  148. Normal rear end noise
  149. 2012 Audi Q5 doesn't have AMI port -- Can aftermarket bluetooth unit be installed?
  150. Are there any problems with the timing chains on the 3.0 TDI
  151. 2016 SQ5 - Rear Caliper Retraction Tool?
  152. Got Q5 2018, lovely car but don’t like its seats and legroom, any thoughts ?
  153. Totally late to the party. 2015 White Audi Q5 TDI
  154. Memory seat - passenger?
  155. 2015 SQ5 with 44,500 miles
  156. Seats from a ‘18FY fit a ‘15 8R
  157. Exterior Trim Replacement
  158. Door Handle Sensor Removal/Install
  159. 2012 Audi Q5 Prestige Ignition Port constantly CLICKS
  160. Audi Q5 Engine not starting
  161. Nav Update
  162. Buying my first Audi. 2017 Q5 or 2016 SQ5?
  163. can this Q5 make it to 100k without more issues?
  164. 2013 Q5 Steering Resistance
  165. We Build Faster. Shorter lead times on AWE Exhausts.
  166. Installed a hatch-close-with-remote module
  167. Jackstand points
  168. Audi Q5 FY B9 Model 2018 - Tail Lights Coding for Q5 - US to EU
  169. Q5 tow wiring harness part number?
  170. Vacuum leak from hell
  171. 2016 Q5 P+ (bought used)
  172. Bridgestone Alenza RFT 275/45/20
  173. Battery Coding by the Dealer
  174. Costco Battery?
  175. SQ5 3.0 Valve Noise...Does this sound unusual?
  176. Electrics shut off in hot weather
  177. 2014 Q5 Timing chain stretched
  178. UK: diesel Oil change over...
  179. 2013 Q5 2.0 Timing Chain Issues
  180. P303 continues
  181. Never late but now - Bought a CPO Audi Q5- feedback
  182. Can somebody tell me what this is?
  183. Waterpump 35k
  184. Removing 2017 Q5 MMI - back left stuck?
  185. Q5 Hub Bearing/Assembly size?
  186. How the heck does the rear hatch open?
  187. 3.2L 2009 Q5 engine rattle
  188. 2013 Q5 CV Joint Part Number Issues
  189. Q5: Timing Chain Malfunction - now what?
  190. Fix? for SQ5 panoramic sunroof
  191. 2009 Q5 Driver Door Unlocking problem
  192. NP: timingchainlitigation.com Extended Warranty covers for 10 years or 100000
  193. 2013 Q5 2.0T cel codes p2293 and p0016
  194. General advice - driving forest roads/snow?
  195. Interior lighting
  196. maintenance lists? water pump leaking @30k
  197. No heat at idle
  198. 2016 Q5 2.0 Burning Oil?
  199. Removing right trim panel in luggage compartment
  200. Update: snow chains for 2014 Audi Q5
  201. Replacing blown dash speaker (B&O)
  202. UK: 2011 Q5 2.0TDi Auto Gearbox Failure
  203. Snow chains? 2014 Audi Q5
  204. Timing chain for EA888 Audi B8 TFSi 2.0L - unknown tools
  205. Q5 Steering Defective Do Not Drive....HELP?
  206. Auto Dimming Mirror
  207. Sticking Hill Holder?--2016 Q5
  208. Low Oil Pressure
  209. Battery Replacement
  210. Low-speed cornering lights disappeared?
  211. Bad bushings at 52k miles on a 2016?
  212. ABS - activates - dry road braking - downhill only?
  213. New Member
  214. Q5 Park assist issue
  215. Climate control panel HVAC
  216. Audi Q5 Power caméra wire back trunk
  217. 2012 Q5 rear differential fluid change?
  218. Control panel/heated seats
  219. Q5 mirror locked looking away from car!
  220. Engine codes?
  221. Heater fan stops working
  222. Engine / gearbox rattling noise
  223. Wrong Coil Packs?
  224. Cheapest option to code Headlight washers OFF
  225. Bad coil ruin spark plug?
  226. Fixed sunroof rattle, but is it going to leak?
  227. 2012 Q5 - remote start with OEM key?
  228. 2013 Q5, Instrument panel dead and no power steering?
  229. How to remove the inner boot polystrene?
  230. Vacuum pump leaking.
  231. Aftermarket suspension SQ5
  232. VCDS coding for exhaust flaps
  233. Quality rotors?
  234. 2012 Q5 ubcentric ring size?
  235. 2013 q5 cv axles
  236. Picked up a 2012 Audi Q5 3.2L and needs another key fob...
  237. Fuel Injectors Carbon Cleaning with Ultrasonic Technology
  238. RO: Aquisition advice Audi Q5 ,Year 2016-2017
  239. DriveShaft Issues (vibration)
  240. Alpine X702D for 2017 Q5
  241. Q5 w/Falken All Terrain Tires
  242. New Android Headunit Options Coming !!!!
  243. Exhaust Actuator (Speaker) Resistance?
  244. 2016 Q5 premium OBDEleven? What can be done?
  245. 2017 3.0T Latest Navigation Update
  246. Axle front left Audi Q5 2013 Premium Plus 2.0
  247. Sirius Channel Updating?
  248. Audi Q5 2,0TDI 2010 many failures/not clear cause
  249. Rough idle?
  250. 2016 Audi Q5 coolant reservoir crack
