Log In
View Full Version : Q5/SQ5 MKI (8R) Discussion
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66
  1. AU: P034000 camshaft position sensor circuit?
  2. CarPlay Module
  3. Need help with this wire plug
  4. 2014 Q5 TDI #2 Glow Plug Broke
  5. Q5 Sway Bar Links- Can't Get At Bolt Head for Re & Re ?
  6. No crank No start.......On and off
  7. 2012 Q5 Liftgate height not adjusting
  8. 2016 SQ5 Overheating and I don't know why!
  9. A/C Nightmare
  10. RE: front and centre also rear differential oil change
  11. AU: Why Audi used son many aluminum nuts?
  12. Battery adaptation h8 to h9 using obdeleven
  13. AU: NEED some help with new pistons
  14. Car says to add oil but it's full
  15. Q5 MMI and Maps update
  16. BA: New to Audi, Buying used Q5/SQ5 3.0 TDI?
  17. Issues with 2017 Q5 2.0t
  18. 3.2L Engine Air Filter Housing?
  19. Vibration through the Accelerator pedal
  20. Positive camber
  21. Coolant Flush and Fill (2.0T)
  22. SQ5 Turbo Inlet Valve stuck open P22D2
  23. Help please
  24. Post eye surgery (headlight replacement)
  25. Roof Rack Torque Wrench Question
  26. 2023 Audi Q5 SLine Prem Plus
  27. SQ5 Maintenance and some Upgrades
  28. Broke Lower Rear Brake Carrier Bolt Trying to Remove
  29. Is this for holding wheel nuts when changing tire?
  30. 2010 3.2FSI Tensioner Replacement
  31. Q5 Tires?
  32. Oil filter housing upgrade?
  33. 3.2 FSI 2012 - Knocking noise from intake manifold
  34. 2016 Q5 3.0T battery change
  35. UK: Q5 2.0tfsi 2009 engine gone
  36. Car when put in parked and turned off does not fully disengage the electronics
  37. white smoke
  38. AC Issue - Every Now & Then Abruptly Stops Cooling ( Blows Regular Air)
  39. Sudden oil consumption Q5 2016
  40. Knocking sound when accelerating (but not steering)
  41. SQ5 2017 , transmission weakness and vibration when accelerating from 4th to 5th
  42. Cornering lights faults
  43. Which brake kit (brand) should I buy?
  44. AU: help me with this trans model?
  45. underinflated!Please Check all four tires and Reset [2017 Q5]
  46. Rear Differential Bushing
  47. How much coolant loss with "bad" PCV
  48. AU: what's this part?
  49. Stage 1 or go to stage 2??
  50. 2012 Q5 3.2 sucking sound when tap throttle in neutral, and when turning engine off
  51. Stuck Rings
  52. AU: new build for 2014 AUDI Q5
  53. AU: which parts can be used in Gen 3 from Gen2 engine rebuild kit?
  54. Counterfeit Brake Pads?
  55. 2.0T exhaust diameter
  56. Various mechanics diagnosing 2 problems differently
  57. UK: Temp warning on Q5 diesel?
  58. AU: engine number issue
  59. UK: 2012 Audi Q5 suddenly stopped
  60. 8R0907441A
  61. Repair Manual
  62. AU: Will Q7 brake fit Q5?
  63. Pano roof shade gear issue
  64. Seeking Fault Code Assistance: P307A
  65. RU: AUDI A4 ECU TO AUDI Q5 SIMOS 18.1
  66. AU: spare tyre for 2009 Q5?
  67. Build Sheet
  68. Check Engine Light, Multiple codes showing
  69. Remove 2013 Q5 Hybrid Prestige subwoofer
  70. A/C problem
  71. PL: Oil consumption - should I be worried?
  72. O2 sensor
  73. Need advice-2016 Q5 2.0L T w/53k miles/85k km’s - low oil- add 1 quart warning light
  74. Audi Q5 2010 Gearbox Malfunction Alert
  75. How do I remove vapor canister purge valve
  76. AU: P001100 [000AEB] A Camshaft Position (Bank1)
  77. No tailgate lights
  78. 2.0T Engine Problems
  79. UK: Q5 I'm new and I need help!
  80. Ride Height Sensor Design Guaranteed To Fail
  81. AU: Need to reset or adapt trans after replaced fluid
  82. AU: Should it be running when check trans fluid level?
  83. AU: why the inline filter so pricey ?
  84. UK: Front washer weird problem
  85. Adaptive suspension tests?
  86. Cost of brake/rotor replacement?
  87. no or intermittent left channel
  88. 85K Miles on Original Brakes
  89. Intermediate steering shaft replacement
  90. 2010 Q5 2.0 tdi- Ambient temperature sensor wiring
  91. UK: Lights?
  92. something missing in the trunk ?
  93. NAV update 2014 MMI
  94. AU: 2009 Q5 2.0L petrol, where is the after-run pump relay?
  95. 2020 Q5 Evaporator Replacement by dealer under Warranty Key U43
  96. 2014 sq5 loss of power /glow plug light engine management light
  97. 2011 Q5 2.0T - Vetting Maintenance Recommendations
  98. Q5 2014 2.0 TDI Parking Sensor Drama - Help
  99. 2015 Q5 3.0T with PCV issue - looking for advice
  100. How would you fix (or at least 'stop the bleeding' this rust spot?
  101. Can I manually fold power sideview mirror arms?
  102. USA: diesel availability in SQ5?
  103. Catastrophic Electrical Issues [2015 Q5 2.0T]
  104. Cost of labor (even just diagnosis) at indy shops
  105. What is the going rate for installing 4 tires + alignment?
  106. Question - Center Differential or Drive Shaft leakage?
  107. Did I just dodge a bullet?
  108. Time for PCV Vale replacement?
  109. 2014 Q5 power seat flex shaft
  110. Is this a normal range of brake pedal travel?
  111. MMI FAILURE IN A 2017 Audi A6 sedan. Total outage of internal lighting and MMI!! The
  112. Koni Special Actives
  113. 2017 Q5 2.0T Won’t Start
  114. P052E is not in 2013 Audi Q5 Quick Reference Specification Book
  115. cv axle replacement
  116. Q5 TDI Coolant issues
  117. Car reverse jumped, full of electrical gremlins now
  118. Will my car support a 2G MMI CarPlay upgrade?
  119. Help diagnosing secondary pump failure code P261C00
  120. Secondary Air Pump / Carbon Buildup in secondary air ports? P0491 & P0492
  121. 2011 Q5 Weird Idle
  122. UK: no fautl
  123. DE: Question related to Audi DataPlug fuel monitor
  124. Bad headlight indicator won’t go out
  125. Upgrading Apple Carplay Screen
  126. MIL & EPC Lights - ROUGH idle/accel @ low RPM - 2013 Q5 2.0T - VAG codes
  127. 2014 Front Parking Sensors Detection reversed
  128. lighting question
  129. Recommended OBDII scanner / EPC error
  130. Driver's window replacement
  131. 2017 Audi Q5 Roof Top Tent - thoughts/questions
  132. 2016 Q5 2.0t premium plus clicking noise
  133. Brake Pads - TRW, Raybestos or ATE?
  134. High Mileage Q5 TDI - Reliability? Winters?
  135. UK: Numerous warning lights.
  136. Help- Break light question
  137. Q5 8R 00384 011 open circuit
  138. Cam fixing/cleaning air system be DIY? P0491 & P0492
  139. Rear Right Fog Light Won’t Turn Off and Muliple Warnng Lights
  140. Service items not in service manual - Recommendations?
  141. Water Pump Class Action
  142. SQ5 long term ownership - anyone at 125K, 150K+ miles?
  143. Intermittent fail to start
  144. Confusion on quote for repairs
  145. Wakaa carplay/Android auto unit free
  146. CZ: Audi q5 2.0 tdi CAHA 2010 - Overfilled oil
  147. Turbo coolant line leaking
  148. Android auto apple carplay retrofit reverse camera problems
  149. MK: 2009 Q5, dsg problem, jerks or shuts down enigine when I stop or put in R or D
  150. 2015 Q5 TDI - would not go past 90km, glow plug light came on- has codes PO401 and 40
  151. Engine noise help
  152. What Is This Part - Front Left Axle
  153. low oil warning light
  154. preferred water pump
  155. UK: Q5 manual with diagrams?
  156. 2024 q5 phev check engine light runaround
  157. Couple of issues
  158. MMI Update - NavMan
  159. MU: Q5 - Low oil pressure - New engine
  160. 2011 Q5 2.0 TFSI Quattro with gearbox issue: Repair or scrap?
  161. 2023 Audi Q5 multiple fault codes
  162. P0492 code - insufficient air system flow at bank 2
  163. 2014 Audi Q5 2.0 Fuel codes
  164. MyAudi app icon
  165. Enabling engineering menu in 2012 Q5
  166. Radiator fans issue
  167. Blacked out control units in OBDeleven app.
  168. RO: Q5 3.0 TDI -245 HP - Body Vibration starting from 110-130 km/h
  169. 2011 Q5 Front Passanger side rattle
  170. 2011 Audi q5 2.0T No Crank No Start
  171. PLEASE HELP- 2014 q5 Kind-of-new guy
  172. B9 (2020) SQ5 w/ Air ride - widest tires on 20" rotor wheels?!?
  173. Which Q5 to avoid?
  174. Is main seal something you would ever DIY?
  175. Vibration when going very slowly 1-5mph
  176. 2012 Q5 Oil Consuption - Turbo leak or rings?
  177. AMI / Aux connection conundrum
  178. No Aux - Green Menu Enabled/Stock Radio/Car Link Radio Swap - 2011 Audi Q5 S-Line
  179. Constant limp mode when towing
  180. UK: Audi Q5 black edition S Line Quattro Auto 2011
  181. 2011 Q5 3.2 Blown Head Gasket
  182. SQ5 vs Q5 3.0t Shift Burble
  183. QuickJack - will 7000TL work for Audi Q5 and Porsche 911SC?
  184. Audi Q5 B8 PDC Not doing anything
  185. 2010 Q5 3.2 EPC /P0306
  186. Coding Help
  187. Any 2013 Audi Q5 2.0T Rear main seal replacement video
  188. SQ5 EPC quandary
  189. Audi Q5 hybrid underbody photos
  190. Automatic 2012 Audi Q5 Gearbox Malfunction
  191. AU: Audi Q5 bulb rear light 2012
  192. 2016 SQ5 front brakes
  193. Q5 3.0 TDI 2012
  194. Ignition Lock Defective
  195. Q5 fault codes P0238, P0179, P303F, P1572, and P165F at once
  196. Turbo Lag on Q5
  197. GoodYear Reliant All-Season Tire?
  198. 2017 Q5 2.0T brake light
  199. Help how to hardwire dash cam in rear (Q5 2013 3.0 TDI)
  200. Drove a TDI Cayenne today
  201. Decreased Fuel Milege
  202. ABS Module Replacement on 2013+?
  203. Dipstick in / out
  204. Help Needed - High Pitch sound from engine bay
  205. FAULT CODE: P046100 ?
  206. How Program Old Key Fob ToMatch New
  207. What's the process / route of my 21 Q5 assembly ?
  208. 2015 Audi Q5 2.0t Premium
  209. Q5 Spare tire Subwoofer suggestions
  210. 2020 Q5 Drive System Light
  211. Lane Assist Modules Missing
  212. Differential Fluid Swap - Help
  213. VIN decoder says my 2014 SQ5 is a Q5
  214. Poor Ride
  215. 2015 q5. Flashing check engine light. Epc light.
  216. Engine 2015 Q5 Premium Plus Quattro
  217. 2016 Audi Q5 - Wiper Arm Alignment Measurements for Driver and Passenger side
  218. 2015 q5. Is my baby over with?
  219. 2012 AUDI Q5
  220. Touch up silver paint: Foil Silver?
  221. Audi indy shop in SW Houston?
  222. Audi Q5 8R 2011 Auto HVAC issue
  223. Which OBD II Code Reader App
  224. Finally Completed 3.2 SC kit
  225. Inner Tie Rod Replacement - Help
  226. Q5 Transmission ID & servicing?
  227. 2009 Audi Q5 lower control arm
  228. 2011 Q5 2.0T Driveshaft Ujoint replacement
  229. 8 digit pin
  230. Newbie with AudiQ5- Require help with AMI/MMI
  231. Audi Q5 TDI 2010 oil vapor smell
  232. Blind spot detection - needs calibration, but module is dead?
  233. Buttons on MMI Centre console not working
  234. Part name or part number needed.
  235. Part name or part number needed.
  236. KW: 2011 Q5 2.0, Misfire, then crank, finally no start
  237. Are these two the same parts?
  238. Blind spot modules
  239. Urgent Need Help! Audi 2015 Q5 3.0 Supercharged Misfiring on cylinders 4,5,6
  240. Sunshade.. fix or not
  241. Check engine and Misfire: 2013 Audi Q5, 115,000 miles
  242. Audio Failure
  243. Connection hardware
  244. 2016 Q5 3.0L Battery Replacement
  245. Taillights Swap
  246. What part is this?
  247. Audi Warning Lights and no Parking assist
  248. 20% off our bright D1S / D2S / D3S LEDs! These are brighter than xenon bulbs!
  249. Higher Left Side of AUDI Q5 FY 2017 AIR SUSPENSION
  250. Intermittent P0229, P0234
