- I'm at a loss. $3850 for replacing PCV, some hoses, and thermostat: 2013 3.0T
- bad idle/misfire codes after oil change/air filter replacement?
- UK: Electrical Gremlins?
- 2010 Q5 had loss of power which eventually stalled and now can’t get it started again
- Missing Tire Pump on recently purchased Q5 from authorized Audi Dealer
- Cargo area anchor/tie down point plate???
- Fuel door won't open
- 9445973 - Seat occupied recognition control module
- Motor Mounts? Heavy rumble/Vibration
- P2293 and P12A4
- Clicking noise still exist after putting RAXLES
- Oil level sensor problem
- sq5 manifold stuck closed.Help
- RPM warning message...Do not exceed 4000 rpms
- Parking Brake Malfunction on 2010 3.2 Q5
- UK: Audi Q5 Four wheel Drive Fault, Has anyone got this error on Dashboard?
- 2010 Q5 Won't Start After Maintenance
- Side mirror wired symptom!
- Brake pads/rotors for a 2017 Q5 2.0
- Shift cable adjustment
- Looking at used Q5s - things or engines to avoid?
- Q5 becoming a bit needy
- Need help with radio
- Scheduled Maint - Driveline Service?
- Battery Part Info Audi Q5 2015 Premium plus 3.0t
- High Pressure fuel pump
- 2015 Q5 — part information
- Key fob works but door handle touch sensor won't
- Good brand water pump?
- Retrofits
- audi q5 2016 w/ bluetooth problems
- New to this Group
- 100k Service - 2009 Audi Q5
- Replace timing chain?
- Excessive Oil Consumption
- Water pump/thermostat housing leak - help from dealership
- This is what a 2,000 mile OCI looks like
- 3.0T timing numbes?
- Where to find Engine Code Sticker?
- Hose Name?
- Q5 Dash Replacement steps
- 2013 Q5 is completely unresponsive after attempted start!
- Greetings from SuperSprint Italy
- Rear Sway Bar Upgrade
- Not another Oil Consumption post.
- 2014 Q5 miles to empty issue
- 2015 Q5 dipstick addition
- UK: Help please re parking sensor beeping
- HPFP???
- Cylinder 3 misfire and random misfire - Misdiagnosed for 2 years now
- 2014 q5 rear window replacement
- Fuel Gauge
- Which part under or near the radiator is possible culprit for coolant leak?
- Engine temp issues
- 2010 Q5 multiple missfires, 3.2L
- Rear Suspension Ride Height Sensor - How Urgent to replace?
- Q5 2.0 tfsi timing tensioner check with obd eleven
- 2015 Q5 Front End Clicks On Hard Take-Off
- BRAKE SENSOR
- Steering stiff on occasions. EPS power loss?
- Dash cam install (not hardwired)
- Help with tail light cover
- Wireless Apple Carplay retrofit for 2016 Q5
- Q5 TDI- Timing Belt/Chain?
- Crankshaft speed abnormal
- 2021 q5 hybrid key drains battery??
- 15 Q5 plotting...
- Q5 Quattro - Clutch Stuck/Rear Diff
- LED Control Module Wiring for DRL
- Very Late to the PARTY... my first Q5!
- Wheel Bearing Replacement
- NO: 2.0 TFSI oil leak and too lean code
- Automatic Door unlock not working
- Report: upper control arms change in Audi Q5 2014
- Trying to find a compatible Bluetooth music adapter for 2013 Q5
- Vent Tab Replacement
- SQ5 8th gear vibration
- Drive System Malfunction in 2019 Q5
- New 2019 SQ5 Prestige owner
- Replacing the Emergency Key
- Bluetooth Audi issue
- Repair prices?
- Hitch install 2016 Q5
- Reduced revs after EGR valve replaced
- MMI 3G+ firmware update
- Splash Guards Damaged
- 2017 Audi Q5 2.0 questions
- Welcoming a 2012 3.2 Prestige!
- Passenger Front Seat Replacement
- Audi Q5 2014 Repair Costs?
- Rear light alert
- 2013 Q5 in PNW - Battery Compartment FULL of water
- Weird oil leak! bolt on front of head.
- Mann 7029 engine oil filter?
- Replacing B&O Front Door Speakers
- CPMA to CPMB firmware
- Swapping 2013 headlights to a 2009-2012 Coding.
- Carbon fiber Dash/console/door trim value?
- Q5 8R engine cover insulation layer replacement
- 2015 Q5 3.0 TDI recall
- Lubricating Sunroof Rails
- anybody tried this: https://thenavman.com/?
- AU: Q5 problems help?
- Front End Damage - Advice Needed
- Coolant loss sq5
- My Q5 was destroyed
- UK: 2016 2ltr diesel q5 s line quattro boost sensor
- Tail light flickering
- Sensor for parking aid issue on a 2016 Q5
- Towing with a Q5 Recommendations
- installing after market apple play unit in 2012 Audi Q5?
- 2014 Q5 piston, ring, etc. job
- Q5 TDI owner with Cyl Contribution Balance Error
- MMI Update / Air Con Fault
- Q5 Back Glass fit question
- Help with possible SQ5 purchase
- 2011 Audi Q5 2.0 oil pressure warning
- 2023 sQ5. How to I check mpg gas consumption and dynamic mode question
- One of the two 12 V Batteries not charging
- 2013 Q5 HEAD LIGHT PIN DIAGRAM
- 2014 Battery Type for PP+
- 2011 Q5 MMI or head unit replacement
- Engine wiring harness
- Backup camera and Parking Sensors NOT working
- 2011 Q5 Front Axle Boot
- No Quattro badges?
- 2012 Q5 motor mount,control arm,power steering hose replacement?
- Repairing gauge cluster backlighting
- Audi Q5 Chime Switch
- 14' 2.0t quattro running lean P2187 and P2279 codes
- New to me 2015 Q5 2.0T Maintenance
- Q5 will not turn over after a new battery
- Audi Oil in Spark Plug Hole fix
- Replaced Parking Assist Module but back up camera and sensors still don't work
- Valve Cover Gasket 2014 TDI
- Battery leak/Car would not sleep
- New owner 2016 Q5 - map update question
- Brake Boost at low speed problem - Help Please
- 2013 d pillar removal to access shark fin antenna?
- E-dipstick error - 2010 Q5 with 3.2L V6
- Need a couple part numbers.
- Headlight washers stay open
- valve cover gasket
- Replacing passenger side mirror cap on 2013 Q5
- Proplem with sensor
- Green Menu Problem
- IT: 2013 SQ5 Diesel in Italy?
- Choices
- Q5 TDI Coolant Leak - Self Repair
- O2 codes after cat delete and 034 Motorsport tune
- Tallest tire that can fit with a 1 inch lift?
- Wheel alignment?
- SQ5 Bumper screw P/Ns
- Did Car Wizard Uncover a new 2.0T Malady?
- Turbo inlet intercooler clogged up
- Prestige Windshield Replacement
- Power Tailgate Help
- what year android auto for SQ5 ?
- OBD2 Reader won't Power Up on 2010 Q5 V6
- “Navigation database incomplete” message
- Taking out 3.0T supercharger dampener
- AU: Wheel speed sensor fault
- Need to identify this!!
- 14 SQ5 P052E00
- 2015 Q5 Rear Driveshaft replacement
- Battery Replacing Problem
- WeatherTech front and rear mats for B8 Q5.
- Brake light on after new rear pads?
- Q5 excessive oil consumption: lawsuit
- Q5 2012 pre facelift both tail lights on
- SQ5 Lowing springs
- 2.0 TFSI cylinder 4 harness
- Replace rear caliper bracket bolts?
- Problem with the Bluetooth
- Wrong Transmission Issues?
- Adaptive Cruise B8.5 v B9?
- 2016 Lights are not coming on when I unlock it.
- Q5 factory trailer hitch up and down loose - normal?
- P03A2
- New to Audi and I got a SQ5!!!
- Anyone in Houston want roof racks for a B8 Q5 for free?
- 2014 SQ5 auxiliary radiator leaking?
- 2015 SQ5 too stiff, will 20" wheels help?
- Audi Q5 2011 Vibration
- P2425 - EGR Cooling Valve - Where is it on the TDI 3.0??
- Stripped oil pan screw (CAE engine)
- Need help identifying a leak!
- Fault code 04698, 04699, 01750
- Electric troubles
- 2012 Q5 2.0L Premium Plus?
- 16 Q5 2.0T front lower control arm bushing replacement
- Heat not blowing hot enough
- 2010 Q5 3.2 Water Pump DYI
- MMI3G+ myAudi Import Contacts/Destinations with 3G Data ?
- Fuel Pump Puzzle: 2010 Q5 3.2L
- New OEM Varta Battery but VCDS Measuring Blocks don't look right
- 2018 Q5 Quattro premium Plus lane/steering assist question
- 13 Q5 HELP!
- Help with fuel door
- Need opinion for buying a 2012 3.2L Q5, 125k miles?
- Opinions on a possible 2014 SQ5 purchase?
- Opinion on possible purchase?
- The Q5 is a tank
- Po491: secondary air injection fault code
- Should I buy 2012 Audi Q5 3.2 quattro Premium Plus AWD?
- TDI warranty work - dealer has no loaners
- 2014 SQ5 Stock Catalytic Converter number/photos?
- Audi Q5 3.0 2011 Gearbox Problem
- 2014 Q5 B&O losing door speakers
- Check Engine Light Related to Bad Batch of Gas (Costco or non Top Tier)
- New SQ5 Chrome Delete help!
- GR: AUDI Q5 quattro 190 2015 - Should I buy it?
- clear bumper protector?
- 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
- UK: S-Line v SQ5 Bumper help
- Follow up on fuel leak 2012 Q5
- Q5 3.0T vs Q5 tdi 3.0
- Q5 not Starting, swapped starter, no go
- Comfort access intermittently not working
- BG: Q5 about to buy with vcds report?
- Possible door fit 2011 vs 2014 Q5
- 2.0 fsi oil consumption states side issue only or worldwide?
- Audi Q5 2012 - faulty temperature sensor
- 2017 Q5 Totally Dead - antitheft?
- driver Power seat stop working
- Shall I buy 3.2v6 or 3.0T Supercharged?
- D3S LED HEADLIGHT CONVERSION KIT
- Anybody know the contact info for Audi corporate? (Q5 needs new engine at 24K miles)
- 2011 q5 in limp mode with epc, check wngine and don't exceed 4,000 warning lights
- a short - silly - question on 2015 Q5 2.0 tfsi
- Please help with ongoing issue
- Location of DPF Matter Sensor? Q5 TDI
- 2013 Q5 lights up, won't start
- WTB 09-12: Qs, 2.0T vs. 3.2 V6
- J271 Power Relay Location
- 2014 Audi Q5 TDI Prestige S-Line valuation?
- 2014 USB port
- 2011 Q5 3.2 - Labor cost to replace engine?
- Fuel problems
- Audi Q5 2014 Ignition Port Clicking Noise with start button
- Outside air temp displaying 90 degrees when it's 30
- No flow to heater core after water pump change
- 2015 SQ5 Fuse box diagram - Specifically Cigarette Lighter Location
- Help: Q5 2018, rear door speaker grill replacement
- Black Friday // Cyber Monday Sales on now – Bright error free LEDs @ the best prices!
- NI: About to buy Q5 8R 2017 3.0T on Cert of Destruction
- Car battery - Autonation Precision Parts brand?
- 2013 Audi Q5 parking brake issue
