- Help darnest thing new engine falters and doesn't have power
- Sunroof Stuck Open in Vent Position on One Side
- How screwed am I? Sunshade getting stuck crunching sound(video link)
- Exhaust piping replacement
- Audi Q5 (2009–2016) OEM+ Upgrade – Snapdragon Android Screen with Wireless CarPlay
- Adding cooled seats to my Q5
- I NEED SOME ADVICE PLEASE ON MY 2012 AUDI Q5 3.2L V6
- P02279, Too Lean at Idle issue
- mmi issue, wont switch status display
- I need some assistance with this please ! New in the car world!
- How to disable Hill Assist with VCDS?
- 2015 Q5 Driver side kick panel removal
- 2010 q5. Worth it?
- 2014 Q5 Rusted Rear Subframe
- Help with underbody hose clips
- real or not
- 2015 Q5 TDI Engine Reseal alternative?
- Is this heat shield washer removable?
- Can you leave the rear liftgate up, but power down the car?
- Oil test on a 2014 SQ5 B8.5 at 80k miles
- 2011 q5 Water leak right rear fuse compartment
- 2018 SQ5 ECT sensor 2 error
- Rear lower control Arm bushings 2015 SQ5
- Just got my 2017 SQ5 out of the shop and I am getting '02912' code
- EGR system replacement - Q5 TDI (2015)
- Can anyone ID this part? Control arm bushing?
- Oil Leak 2013 Q5 3.0 supercharged
- Differential Fluid Confusion (Front, Rear and Transfer))
- New shoes are here
- How to flush money, own an Audiy
- Q5 oil consuption
- MMI controls not working!! - 2015 Q5 Hybrid
- Squeaky noise from the rear
- Cracked Fuel Pump - Will Audi Still Cover Repair?
- Missing Splash/Underbody Panels?
- Battle of the Intakes
- ABS and multiple error lights Q5, 2015
- Control panel not working
- VCDS Fault Codes
- Locating 12v Battery 2015 Q5 Hybrid
- Audi Q5 2.0 Tdi rattling
- Sun shade drooping.
- 2016 Q5 Hesitation on starting.
- EPB error codes
- Audi Q5, 2017 Recent Service
- Trying to code Window Roll up/down with Key Fob
- Mmi 3g+ rebooting every 30 sec need help
- too much oil in the supercharger help !!
- 2016 SQ5 total loss of power to everything. Zero Electrical.
- ‘17 Q5 with worrisome steering issues. Need help.
- Android Screen Upgrade for Audi Q5 (2009–2016) – Keep OEM System + Add CarPlay
- Camshaft Position Sensor location
- Transmission cooling line
- 2015 Q5 2.0 turbo - No compression in cylinder 2. 125 in 1, 3 and 4.
- Door handle differences and interchangeability?
- heater problems
- backup cam and parking sensors not working
- 179mm Pulley and 034 S2 Tune
- New owner: 2011 Q5 (Intermittant issue with EPC light and misfire)
- 2018 Q5 (US) any way to restore traffic data to built in Nav?
- 3.2 V6 Major Misfire
- CarpuTech | Upgrade Your Audi Q5 with a 12.3” Digital Instrument Cluster
- 2016 Q5 3.0T No Crank, No Start
- Liquid on engine cover
- Cooling system fault codes, need advice
- 2017 Q5: Bad Timing Chain?
- Wheel offset
- AU: Help.....My headlamps suddenly went off
- Black Optic trim question
- Engine Mounts
- Clunking noise from the wheel - 2010 Audi Q5 2.0 TDI Quattro
- TDI starts but dies immediately, ideas?
- Mystery Coolant leak
- '13 Q5 3.0T front grille replacement
- D3S LEDs - brighter than xenon - cleaner white - instant on - no errors
- Lowering Springs. H&R or 034 Motosports
- Front Right Passenger Side Tire Ticking Noise,Tie Rod Gone Bad?
- Cylinder Block/Head Carbon Deposit - B12 Piston Soak?
- Updated repost p0089, p0087
- Car starts rough
- DRL issue SQ5 - both sides
- Paint code location 2015 Q5
- Is this the CV Boot that’s leaking?
- Q5 2016 2.0T Replaced Battery car worked fine for 30 minutes
- Audi Q5 totaled - insurance offer
- 2015 Q5 Carplay Options?
- Rough Idling/Driving during cold start (Possible Misfire)
- Floor Mat Question
- NZ: No fluid pressure RHS after calipers off
- HVAC Blower motor doesn't fit in my 2014 Q5 3.0
- P008700
- P203B 00 trouble code-no-start countdown
- Stabilization fault error
- Audi Q5 2.0 TFSI 2015 Transmission Mount issues?
- Battery maintainer
- Rebuild or replace folding mirror motor?
- possible to mod Q5 for residual heat feature?
- Side mirrors not unfolding, Display not coming on
- Audi q5 idle isue
- 2013 Q5 3.0T flaps stuck open question
- Repair/Replace Sunroof Liner in Q5
- Is 90,000mi to many miles on a 3.0T?
- What type of motor mounts?
- 2015 Q5 - Check Sunroof Drains
- Drivers Seat Motor
- Q5 2.0 TDI 2013 346000km
- Water In Headlight
- Audi q5 cam/crank corelation codes
- ‘15 Q5 3.0T injector issue
- 2010 Q5 3.2
- Compensation for mishandled timing chain repair
- Audi Q5 3.0 TDI gearbox – alternatives?
- Headlight plastic lens replacement advice
- Buying Help Q5 2013 2.0 TDI 177hp stronic
- No SAT option
- Grinding Noise coming from the front end when accelerating (Audi Q5 8R 2009 CCWA)
- Q5 2015 whining through lower gears
- MAF actual much higher than MAF specified
- Let’s play where does that bolt go
- Phone mount
- Recommend changing thermostat and a 3rd water pump at 75k miles with PCV job?
- Error Control Circuit for Reductant Heating 1
- Questions for amateur mechanics - SAI de-carbon, crankcase/pcv, VCG, coolant, O2 etc
- Replaced Passenger Rear Handle Sensor, now Radio and Left side not working
- Radiator again?
- leaking coolant around water pump
- 2014 SQ5 with a case of the smokes...
- Looking to buy this Q5 TDI - cold start vid, check for timing chain rattle?
- REAR DIFFERENTIAL CENTER BUSHING
- In my 2009 q5 All my 12 volt outlets don't work and all the fuse are good help!
- Cylinder Misfire after HPFP replacement (IN A MESS SINCE LONGTIME)
- Where is the oil leak coming from?
- Rusted rear suspension parts - cross member?
- Vents barely blowing in hi heat mode
- 2014 Q5 headlights poor compared to my BMW X5?
- P164B 00 and Epc light
- BLACK FRIDAY SALE ON NOW - STOCK-UP AND SAVE!
- 2014 Audi Q5 No Fuel
- New 3.0 TDI Owner - Looking For Advice
- Q5 2011 2.0T PCV Diaphragm Repair Kit
- P0491 & P0492 - Cleaning Carbon buildup from secondary air ports?
- Control Arms Replacement Costs?
- 2011 a5 3.2l Oil leak front of engine
- Air con won't stay on..
- Wet floor
- Lower Control arms
- 2015 Q5 shakes when driving, epc light on, multiple codes
- Power steering leak
- Does a 2015 SQ5 3.0 TFSI have a cam bridge oil screen/filter?
- Cylinder 3 Misfire after HPFP replacement
- Upgrade Your Audi Q5 with CarpuTech’s Wireless CarPlay & Android Auto
- Why is there no AMI module in my Glove Box?
- SQ5 door mirror quandary
- Remote Start options
- Trailer Hitch retro fit
- Trailer wiring harness
- Code 00003 B8 Q5 2012
- Water manifold replacement instructions
- Heater fans not really blowing much
- 2014 Q5 Rear Tail Light Replacement
- Broken rear suspension springs
- Headlight problem
- HomeLink programming fail
- 2011 Q5 Front roof does not completely close
- MMI 3G High stuck on Audi logo after region change
- 2016 q5 3.0t Instrument panel backlight
- 2017 Q5 Seized Engine, 2.0T. What to do?
- What would you tell your sister? Keep? Sell it!
- Remote Convience Close Stopped Working
- Front Struts - Aftermarket OEM (Monroe or Sachs)
- How to code new car battery
- FRONT BRAKE UPGRADE
- Upper Link Bushings repairs under warranty
- 2014 SQ5 fill/drain plugs
- Problems After Battery Replacement
- Fuel Rail Identification
- AC Expansion Valve Location - 2014 Q5
- coolant leak / Gainesville, FL shadetree mechanic
- Locked up 3.0 TFSI 2015 SQ5
- New front grille sources? 2014 Q5?
- Failing/About to Fail HPFP ?
- 256-Color Ambient Lighting Upgrade for Audi Q5 (2010–2017)
- Audi SQ5 won't start
- Hot air from the vents
- Advice Replacing Valve cover gaskets & Thrust arms
- Faulty MAF Sensor or Vaccum Leak
- P2015 and p2181
- Dynmaic Steering System Fault, and BOTH scroll wheels stopped working
- High HTFT (Fuel Sytem Running Lean)
- ATF Change or Not?
- Door speakers not working - Help!
- Leak from near starter
- MAF sensor Screws
- Discuss the 2009-2017 Q5 Carputech Kit for CarPlay and Android Auto
- 2016 Q5 - just getting started and have an EPC
- 2018 Q5 pre-purchase feedback?
- AU: why is it running @ high pressure ?
- AU: steering issue and terminal 30 open circuit
- 2.0T Misfire & Oil Issues
- 2010 q5 117k won’t start epc light on PLEASE HELP
- Q5 Battery department flooded no crank only one click.
- 2011 audi q5 Quattro 2.0T radio, no sound
- D3S LEDs Brighter than XENON & Dual Fog LEDs! Perfect combo
- Sunshade Cover
- 2016 SQ5
- Key Replacement
- Q5 transmission issue
- AU: how does this low oil pressure sensore work?
- 2009 Q5 display
- Possessed Door Locks
- 2015 Q5 TDI Oil Level Sensor Wiring (Rodent)
- HPFP or Electric Fuel Pump or Timing Chain Tensioner Failure?
- 2.0T getting P0201 after new injectors (and IM, and carbon clean)
- Discussion: Which Part/Feature Do You Like The Most of Q5?
- Stability program fault
- 2015 Q5 - 03366 Vacuum Sensor Code - Please help
- Unsure where this fits or What is this ?
- 179/63 (OEM) Setup Belt Question
- 2013 Q5 w/215,000
- TSFI 2.0 Crate Motor (Ebay/ China)
- CarPlay Installed in My 2009 Audi Q5 — Loving the Upgrade
- 2014 Q5 brake pad experiences?
- Overheating/Staying in first gear
- EE: Q5 2012 diesel - no pre ignition time?
- Intermittent Connection From iPhone 16 to MMI
- P208A
- 2011 Q5 - Display Screen Dead
- 2016 2.0 Cam Bridge Reseal
- 2017 Q5 console vent replacement
- AU: purpose of Balance Shaft Sleeve ?
- Underfoot problems
- Side Assist Fault
- L@@K SUPER MINT OEM Audi SQ5 21” Wheels – Satin Matte Black – No Curb Rash! L@@K
- 2016 SQ5 Plus OEM Tow bar
- Can I use Iphone 15 to stream xm wireless 2012 Q5
- 8 front control arms replacement - dealer cost?
- EGR delete for 2014 TDI Q5
- Tuner module change out
- 2014 SQ5 Prestige 034 Stage 1 ECU/TCU
- OBDeleven coding battery issues
- 2012 q5 hard start
- Rooftop box
- AU: 8HP55A transimisson valve body and solenids cean
- Where to find entrance to sunroof drain lines
- Did Some Light Maintenance
- sq5 CEL ambient temp sensor (in engine bay??)
- Any way to stop cruise control from slowing down Q5?
