PDA
View Full Version : Q5/SQ5 MKI (8R) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66
  1. GU: 2011 Q5 COMPLETELY DEAD BUT LIGHT ON DASH ARE ON?
  2. New member - 2016 aftermarket backup camera
  3. Steel oil filter cap wrench?
  4. MAF Connector
  5. 2017 SQ5 Air Suspension always on level 3
  6. 2010 Q5 piston replacement
  7. 2015 rear tail light, light on cluster but lights work
  8. 2015 Q5 Rear Parking Sensor Connector
  9. Trailer module removal and coding
  10. Q5 Lane Change Assist fault
  11. battery not holding charge when idle for a few days
  12. Oh, so THAT's why my park assist system failed!
  13. Ride quality with 21" wheels - and other questions
  14. Re-FRONT SHOCKS
  15. Meet the vehicle built for [re]
  16. Occasion Noise =-> Loud Rattle & No Power :-(
  17. New Owner - Having Issues :(
  18. Oil drain plug T40? or T45? [2014 q5 2.0t]
  19. Power seat breakers / fuses
  20. Sponsored Content?
  21. 3.0T PVC Should i wait?
  22. Brake wear sensors light still on (HELP)
  23. Bad Alternator?
  24. TPMS Sensor Replacement Cost?
  25. Water/condensation Tailgate light housing
  26. Doors fail to unlock when touching handle while damp
  27. 2010 audi q5 3.2 quattro premium Maintenance?
  28. How-To Remove Front License Plate Bracket Safely!
  29. 2013 Audi Q5 2.0t - normal oil use?
  30. Knocking sound when at low speed or full lock reversing
  31. Door Locks When I Reach For IT
  32. SIM not working after installing new MMI 3G+ and removing component protection
  33. Strange issue with P2563
  34. Wheels for a utopia blue
  35. Audi Engraved Laptop
  36. 2016 Q5 Premium Plus Quattro
  37. Researching 2014-2016 SQ5
  38. Front bumper peeling
  39. 2015 TDI Fan Running
  40. 2015 q5 rear bumper conversion to sq5 or S line?
  41. Exhaust AWE
  42. 2.0T Generation Years?
  43. Audi Q5. 2.0l Tfsi 2016, Engine icon on & Cruise control not working
  44. DMV Fees
  45. epc light
  46. Traffic not working on 12 Q5
  47. Q5 turbo
  48. Name that noise!!
  49. New Member
  50. 2015 Q5 - 2.0 8 Speed Transmission Fluid Change ( Cross Brace)?
  51. P24C7, P24C6
  52. Audi Connect Carrier Plan?
  53. How to repair the main unit from Audi Q5 2009, code 8t1035666jx
  54. Audi Q5 2015 Bi Xenon Adaptive AFS Headlight -- Retrofit
  55. OT: Volkswagen says driverless vehicles are at least five years away
  56. Dent Repair Cost
  57. Looking into SQ5 Tire Replacement with 265/40R21s
  58. Roof rack socket wrench lost
  59. OBDeleven---What do you think?
  60. Rear Tail light Replacement
  61. Turbo Cooling Recall--Followup
  62. Park aid module compatibility?
  63. Audi Q5 2.0T 2012 Rear Hatch Problem
  64. MMI 3G High issue with Name and Contacts
  65. Fuel Gauge Stuck on 3/4 - I'm a new Audi Q5 Owner
  66. p24c6 fault code
  67. Tallest Tire on a 2014 Q5?
  68. q5 3.2l aux water pump help
  69. 2015-16 SQ5 Reliability/known trouble aftermarket Warranty ?s
  70. Blown drivers strut
  71. Q5 Problems?
  72. Newbie with non-working backup sensors / parking system on 2010 Q5
  73. Audi q5 3.0T towing ??
  74. Looking for new Control Module: 8R1035746D Anyone?
  75. 2014 Audi SQ5 steering problem
  76. Introduction
  77. Creeking Noise Drivers side suspension
  78. Headlight switch "knee" fixed!
  79. HID Bulb Upgrade
  80. Leak from Oil Drain Plug SOLVED !!!! Must Read INFO
  81. 2014 SQ5 21" OEM Wheel question RE: center caps
  82. adaptive lights error code
  83. Help! I hosed my MMI!
  84. Summer vs. All-Season Tires
  85. Stumped by water pooling in rear passenger footwell
  86. External SIM issues - Q5 2018 UK model in Trinidad
  87. Audi Q5 2009 MMI 3G is dad
  88. best 2 channel dashcams
  89. OEM illuminated MKII sills on 16SQ5
  90. 17619 - Secondary Air Injection System: Bank 1
  91. HELP! NEWLY POWDER COATED WHEELS CARE
  92. UK: Q5 Brake Pad Sensor location?
  93. Leaky 3.2 engine
  94. 2014 diesel Q5 steering rack problems
  95. 2014 Q5, fuel injector problem
  96. Burger tuning--BT+
  97. Magnaflow 15378 Q5 3.0T
  98. favorite mods?
  99. audi q5 2014
  100. '
  101. Cylinder 2 Misfire, CEL and EPC.
  102. Manually Dimming Auto-Dimming Mirrors ?
  103. Rattle when pressing & releasing accelerator
  104. 8 Speed ZF Transmission- how many litres for a fluid change?
  105. 2014 q5 s-line premium plus parking aid/back up camera problem
  106. 2014 Q5 trunk won't open, car requires fob to be inserted
  107. Click while driving on low speed.
  108. Piggyback tuners for Q5 TDI
  109. q5 key no longer auto opens vehicle
  110. RKX transmission mount
  111. Q5 Tire Size Question
  112. Air Intake Temp Sensor
  113. new to Audi
  114. 2011 Q5- Rear shock replacement price
  115. Rattling sound on start up
  116. audi q5 2017 snow chains
  117. can the "average gas mileage" calculations be adjusted?
  118. 2010 Q5 trunk not metal?
  119. Dash Brake Warning Light with no Error Message / Code
  120. internal storage add ons missing from Q5
  121. Broken Lateral Adjustement Screw on Pass Side Headlight
  122. stupid GM - hopefully no other OEM
  123. towing camper trailer with 2.0T
  124. 2011 Audi Q5 2.0 - multiple coil pack replacements
  125. miles to empty
  126. auto-sensing windshield wipers don't sense very well
  127. Q5 squeaky/screeching/noisy brake pad fix?
  128. Software Updates MMI or Bluetooth
  129. Q5 water pump replacement.
  130. Dealer Paint Issues
  131. 2015 Audi Q5 QUATTRO OIL CONSUMPTION
  132. Update maps: 2011 Q5 3.2?
  133. Radio Stuck on channel
  134. SQ5 - CEL P0172 - Anyone have this issue?
  135. Audi Care
  136. Potential New Owner Q5
  137. Steering defective - polar vortex induced...
  138. Tech breaks seized rear shock bolt
  139. Removing Factory Tow Hitch Electrical Connector
  140. Fuel Door Won't Lock
  141. Accident Advice
  142. Q5 Steering Wheel Swap
  143. ZF 8-Speed Transmission Behavior (14' TDI)
  144. 2015 Audi Q5 QUATTRO OIL CONSUMPTION
  145. What color silver is Cuvee Metallic?
  146. New Tires Q5 - Which Michelin?
  147. TPMS error code
  148. Service Delays
  149. Sunshade broken - Sunroof inoperable
  150. VCDS for a noob and a noob owner
  151. Antifreeze smell in 2016 SQ5
  152. Led parking puddle lights of side wing mirrors retrofit.
  153. 2009 Q5 premium 3.2 with 130000 miles
  154. 2013 Q5 water pump
  155. How to change xenon headlight bulbs ?
  156. New rattling sound in 2015 SQ5 front suspension at 45K miles
  157. Oil Drain Plug Leaking and Driving me Nuts :(
  158. The dealer screwed me, let me tell you how...
  159. Anyway to activate cornering lights on my Q5?
  160. 8R vs 80A Visual Differences
  161. '14 Q5 3.0 PP thermostat change
  162. Audi Logo projector door light
  163. 2010 Q5 3.2 Oil Level Low after Oil Change Service
  164. Where is cam position sensor bank 2 sensor b located?
  165. B8 to B8.5 look
  166. Comfort Blink Change adaption
  167. Do I need a new Battery? (Battery Test Results)
  168. Driver Asst. Error.
  169. Slight noise dropping 1000 RPM
  170. Side mirror button
  171. 2011 Q5 Halogen to Xenon swap
  172. It's lowered!!
  173. Looking for 2 small parts to freshen up an old 2010 Q5
  174. Issues with Stalling
  175. Backup Camera Installation
  176. new SQ5 owner here..
  177. Goodbye SQ5 MKI ... Hello SQ5 MKII
  178. misfires on 1 & 2
  179. Help....Battery continue drain
  180. Blend door location?
  181. Primary cat goes bad?
  182. Replacing Control Arm Bushings at 50K Miles?
  183. Possible Q5 purchase
  184. License Plate Bracket Fix
  185. SQ5 Wheel fitment question.
  186. Audi Q5 2009-2012 B8 Retrofit Road Map and VCDs CM list
  187. MMI SD slot technical limitations- 2016 Q5
  188. Extended Warranty Prices
  189. Fuel level sensor goes out a week after fuel pump flange replaced - thoughts?
  190. SA: DRL has a yellow tint, headlight is weak and yellow?
  191. New to the Q5 world, help!!
  192. 2015 LED DRLs
  193. Quattro ultra Vs VW 4Motion
  194. K&N Air Filter & Diverter or Blow Off Valve for Turbo Engine
  195. udi q5 remote starter installaion without leaving in Key (English)
  196. Am cumparat un Audi Q5 Quattro 2.0 din 2009 si s-a defectat MOST sau o componenta MMI
  197. 2013 Q5 3.0T with 80K miles, what to check?
  198. need replacement screw for blower motor 2012 Q5
  199. error 00457 J519 module
  200. Audi q5 remote starter installaion without leaving in Key
  201. Integrated Engineering Tune Impressions
  202. adding a tow hitch
  203. Real World MPG for the TDI.....?
  204. 2015 No rear heat?
  205. Headlight Upgrades
  206. All-Wheel Alignment Cost & Question
  207. Brake & Rotor Replacment Costs & Questions
  208. 2016 SQ5 Transmission jerking
  209. Parking aid stopped working
  210. ZF Transmission fluid change, only 4 qts?
  211. 3.2L Spark Plugs - Fact Check Please
  212. How is the oil consumption testing done?
  213. Q5 Prestige of Q7 P+....?
  214. Rear door lock issues
  215. Tube of coolant reservoir how to replace
  216. SQ5 Brake pad and rotor replacement (fr)
  217. Adaptive Damping VS. Stock - Q5 TDI - Worth it?
  218. 2014 SQ5 pads and rotor replacement
  219. What's the real deal with towing near the max capacity with a Q5?
  220. Problems getting Takata airbag replaced?
  221. How do you put Q5 on jack stands?
  222. Does your 2.0T sound like mine? Trying to troubleshoot
  223. Back in an Audi - - This time it's an SQ5 - - Tinted Brake Light Covers?
  224. TSB 2044940 - Google Earth Patch
  225. Battery maintainer
  226. speaker panel in back popped out
  227. Going Up a Tire Size
  228. retrofit heated steering wheel
  229. Humidity/foggy windshield
  230. Q5 TCM? Error
  231. Light of vanity mirrors
  232. MMI 8T1 035 664C to 4G0 035 746C ?
  233. Chrome Exhaust tips Question
  234. High Beam Assist Retrofit
  235. Filter replacement campaign due to Northern California fires?
  236. brakes and rotors? Please review ASAP!
  237. 2011 Q5 headlight plug
  238. Upper Control Arm Bushing - 1st Warranty Visit
  239. Q5 TDI emissions - Who has not gotten it done yet?
  240. Mud down both sides of vehicle
  241. 2017 Q5 3.0T Exhaust
  242. Powder coat roof rails !
  243. Extended Warranty Purchase
  244. are the black clips that latch to the coil packs replaceable? 2015 SQ5
  245. Fuse location? Fuse SF4 (5A) 2018 SQ5
  246. Trunk not closing reliably
  247. q5 trailer module and harness wiring question?????
  248. Question about maintenance/services provided from an Audi dealership
  249. Audi’s first all-electric car-sized between the Q5 and Q7
  250. 2016 Q5 MMI STRIKES AGAIN !
