- US: what year was adaptive cruise first offered?
- NO: 2.0 TDI 143hp egr rattle
- Q5 convenience key defect
- Fault Code 0955
- Bulb indicator
- No flow to radiator with new waterpump
- Q5 oil leak advice pls
- Tire size?
- 2012 Headlight orange marker light bulb?
- side mirror replacement?
- Q5 gear shift (auto, no 6 spd)
- Pads error even after shorting cables
- 2010 engine problems. No oil?
- 14 SQ5 Park Assist stopped working
- 2013 Q5 Electrical Gremlins - At a Loss to Fix?
- 2011 Audi Q5 vapor canister valve
- Difficulty Getting Rid of Check Engine Light
- Can't find coolant leak
- 2015 Q5 3.0T vs 2021 Q5 2.0
- Urgent Help?
- 2010 Q5 to buy or not ?
- Brakes
- 2012 Q5: Is some oil normal on turbocharger hoses?
- Major Coolant Leak - Front Upper Engine Timing Cover/Gasket
- IR: What is this sign?
- Audi q5 2011 - right headlight and daytime running light
- GY: Car?
- did audi extend the water pump warranty on 3.0t?
- Heated side mirror wiring diagram
- Cost to Fix Scratch $10,000...Really?
- Passenger window wind noise after hitting pothole and cold outside
- Q5 8R light problems
- EPC
- 2012 q5 3.2 timming marks?
- What should I believe? Dipstick or computer?
- Fuel Pump Replacement
- Transmission Error - VAG fault code 08031
- Noticeable Turbo Lag -2013 Audi Q5
- PCM, ECM, TCM possible issues?
- 2023 SQ5 requires pin each time I enter
- Radio dead
- Rear loud clunk in low speed (0-25 km/h)
- Coolant Drain & Fill 2015 Q5 TDI
- 235/55R19 all terrains on an SQ5
- Part number for height level sensor in rear suspension with sport suspension?
- Adding Start/Stop System with ObdEleven?
- HU: 2015 Audi Q5 2.0 TDI Quattro S-Tronic stalls&jerks
- Upper Oil Pan to be repaired on my TDI under emissions warranty
- SQ5 hitch weight without WDH
- 2010 Q5 TDI brakes / steering shudder when turnring
- TH: What electronics commands the wipers?
- AU: P00B7
- Sunroof Cover Sunshade Replacement - Atlanta Area, SC, NC,AL, FL?
- Turbo Lag - Aging Car or Old Transmission Fluid?
- AU: Q5 TDI Temperature gauge false readings
- Q5 at vacation home
- Diesel Emission Warranty expiration?
- control comfort unit was defective new setting vcds
- ac sometimes cold
- Q5 2011 Parking brake stuck after pad replacement
- 2012 Q5 2.0T - seized balance shaft - low oil pressure after replacement
- Issues after Audi Service
- What is the problem? Audi Q5 2012 CHJA Hybrid
- New to me 2017 P+ engine replacement
- Q5 TDI - timing chain
- Rear view Mirror options for 2014 Q5?
- SQ5 3.0 TFSI 8R breaking during launch
- Audi q5
- Crank Positioning Sensor location on a 2013 Q5 Premium Plus 2.0L
- 2014 Q5 extreme oil consumption
- p2789 clutch adaptive learning at limit
- Freaky Wiper syndrome - WTF (wipers turned freaky)
- Oil starvation CGQB advice needed...
- MX: I have a strong “chemical smell”
- Troubleshoot or Replace Motor?
- How do I removed an M12 triple square wheel bearing bolt that has a stripped head?
- Fuse
- Fuel leak
- Sirius Radio
- Towing small trailer
- trailer wiring colors
- intermittent howling from front passenger vent
- Bando Serpentine Belts ?
- Audi Q5 Coolant leak from Coolant pipe/hose
- Overheating?
- Will an audi Q5 Hybrid still work if the electric brushless compressor fails?
- Removing front seat back plastic panels
- Serpentine belt failure sheared other wires
- 3.2L Q5: Timming issues after timming job
- Seat comfort opinions
- Broke hose clamp, help
- Questions from a new Q5 owner
- Power Steering warning light light
- Gearbox Malfunction: you can continue driving P174000
- 2014 Q5 trunk height?
- Android Auto
- Coolant Leak
- Odd steering noise
- Navigation System Problem
- Coding
- What’s with the 2023 Q5e tax credit ?
- Tpms wont store dtc02214
- 2012 Q5 - Working through the codes
- Water Leak
- Q5 head gasket failure
- 2012 Q5 3.2L Help
- P208A Help with wiring diagram
- 2017 Q5 S-Line
- 2017 Audi Q5 rear driver side passenger footwell vibration
- What's this sensor?
- Spare tire
- Track for Sunshade Malfunctioning
- AL: Clunking noise from rear in low speed
- 09 3.2 Q5 Throwing Multiple Codes
- Q5 cylinder 2 misfire (only at idle) not solved
- 2010 MMI Update Questions
- 2012 Q5 2.0T EPC Issues
- Anyone have experience of Pirelli P-Zero PZ4 tyres /tires?
- 2012 Q5 front brake pad sensors?
- Oil leak on 14 Q5 TDI
- Can I install the navigation control center console in my 2017 q5 and it also work?
- MMI display blank
- Upgrading Radio Options
- 2017 SQ5 keyfob retrofit?
- 2010 Rear View Mirror Question
- Charging Devices with Engine and Battery Off
- Battery coding
- Additional Key Fob 2010 Q5
- Exhaust cam failure?
- CZ: Accidentally reseted DPF learned values and oil ash volume
- Proper Trans fluid?
- Horrible Audi Q5 engine rebuild
- 2012 Q5 with 52k miles service?
- UK: Manually close power tailgate door?
- AUDI STEVENS CREEK SAN JOSE WITH A DISHONEST BUSINESS PRACTICE
- Brake issue Q5 2017
- OBDEleven
- AC ISSUES - 2016 SQ5
- Cannot get Rubber Dust Boot on Caliper
- TDI Fans – I got $76,098.73 for my 2015 A6 TDI with 146,179 miles
- RO: Audi Q5 2015 problem, slow stereo
- 2013 Audi Q5 MMI & Backup Camera Issues
- Reasoning about wheel hub replacement (Audi Q5 2014)
- 2016 SQ5 died after starting to accelerate at light
- Reverse light
- New to Audi World, wanting to upgrade my Q5
- Ferodo Brakes Pads ?
- Will a 255/55r19 Falken wildpeak fit?
- The 034Motorsport SummerFest Dynamic+ Sale Is Here at PartsByTopher!
- 2021 Q5e PHEV have you had these issues
- Q5,2010, CAHA, Passenger power seat not working
- OEM Battery ?
- Ferodo vs Brembo Brake Pads?
- Lane assist quit working
- 2011 Audi Q5 - Ratchet sounds when costing or revs below 2k RPM
- Q5 TDi 2015 issue with fuel unit
- CAEB to CPMB swap questions
- Technology Package Credit
- TDI emmission repai?
- Head Curtain Air Bag
- Spare key for 2015 A5
- Help a noob Q5 shopper?
- Audi Q5 (2013) 2.0 TFSI Coolant Drain Plug position
- 2016 Q5 3.0t vs 2014 3.0t, any differences that affect reliability? Major issues?
- Rough ride/vibration first mile or so
- Keep it...or Torch it?
- TH: Auto transmission internal/external filter
- UK: Ringing Nosie at 2000RPM
- 2015 Q5 2.0T - Carbon Clean on Intake Valves
- P0506 - rough idle after long park, went away.
- Dipstick (P/N)?
- Wrong PR code? 8 piston caliper
- 2015 AUDI Q5 oil burner
- Trouble codes - OBDeleven
- EE: Stabilisation programme and ABS fault?
- Q5 has developed Rattle noise when taking off, disappears when I reach 20km/hr
- B8 SQ5 Wheel & Tires. What's your setup?
- Interchangeable Fender?
- HU: Audi Q5 2.0TDI Gearbox malfunction P179E
- Help reviewing Speediagnostix Report?
- 2013 Q5 Hybrid sometimes takes 2 tries to start
- 2012-Q5 -Parking sensor and rear view display not working
- after market unit for music from phone via BT ?
- Australian VIN Decode Request
- new to Audi! software version?
- Q5 3.2L Misfire, only on long drives.
- SQ5 TDI Unkown problem
- Q5 lost indicator/drl and headlight on front n/s
- Cylinders 1 and 3 misfire. Help
- 2016 Q5 Suddenly Using Oil...
- Economic way to fix this side swipe? Q5 2012
- Suspension noise on grooved concrete like blowing on a bottle
- TDI engine vibration -- how much is normal?
- 2016 Q5 TDI Transmission Weirdness
- Not Driving much?
- 2012 Q5 2.0T Keep or Sell
- Gearbox malfunction issue
- Audi Q5 High Pitched Noise
- 2012 3.2 Q5 - P0491/P0492 Secondary Air Intake
- SQ5 P207F00 Help!!!
- Brake Pads & Rotors
- Battery Replacement
- Brake Fluid Flush
- Ross-Tech VCDS or OBDEleven or something else
- 2012 Q5 Folding Mirror Issue
- 2013 sq5 felt arch liners
- ZF8HP Transmission Service kits
- Matte finish on these Q5 wheels?
- Should I rotate tires after 30K miles?
- Q5 towing
- CZ: P0544, please help me
- Proud Owner if a 2016 Q5 today however…
- VIN Decode
- Electrical Problem?
- Reliable and economic Auto repair shops for Q5?
- Misfire Cyl 2 and 4. Not plugs coils or injectors
- Suggestions on Oil Consumption, 2015
- TFSI - fast overheating - cold radiator - no coolant flow out of block
- No more mess cable and bring you a nice and clean drive space!
- 2013 Q5 Engine Swap?
- 4K Cost of CV Boot & Axel Replacement for 2017 Q5
- 3.2L getting the oil level correct after oil change? How much oil exactly?
- about to reach 100k miles, keep or sell?
- 2013 Q5 Rough shift or misfire?
- 2012 Audi Q5 misfire problems
- MMI oil level accurate while driving?
- Q5 2.0T engine speed sensor?
- Any SQ5s from Los Angeles?
- CV Boots
- Panoramic Sunroof Rattle
- Australian VIN decode request
- IE: best cleaner for 21" diamond cut wheels
- Headlight Ride Height Level Sensor
- Annoyed with Bluetooth
- 2.0t oil leak from turbo
- Losing coolant but can't find a leak
- MMI and new battery
- Anyone have good writeup/video for LM Diesel Purge?
- 2015 Audi Q5 post 95k service
- 2012 vs 2013 roof rack bars?
- Used 2012 Q5
- help Dyanmic control
- Engine Replacement/Swap
- 2015 Audi SQ5 Oil Level Issues
- SQ5 CARBON CERAMIC BRAKE UPGRADE
- I changed my wiper switch & clockspring, now i have a power steering code!?!
- 2015 Q5 TDI S-Line Clutch issue
- Audi dealers going crazy with markups.
- Re map
