PDA
View Full Version : Q5/SQ5 MKI (8R) Discussion
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66
  1. key no longer opens door
  2. dpf problems with my sq5
  3. Condensation in headlights of 2014 SQ5
  4. 2013 Q5 Cel. Bad idle and wouldn't start
  5. Extended Warranty
  6. GE: Imported Q5 to Europe from United States - MMI RELATED
  7. Replacement Jack Needed
  8. Thinking about buying a 2013 Q5 3.0T
  9. Convenience Key Defective Issue
  10. iPod Question - 2013 Q5
  11. Fan blower gone wild
  12. Audi Major Maintenance?
  13. PARKING SENSOR RETROFIT?
  14. 2015 Q5 2.0t engine knock when towing
  15. Bluetooth headunit upgrade
  16. NO: 2011 Q5 2.0 TDI - EGR error
  17. How to identify a factory/OEM tow hitch?
  18. Rear Caliper Question 2015 Q5 TDI
  19. DENVER, CO Q5 2012 HELP w headlights
  20. 2010 Q5 3.2l salvage rebuild
  21. 2010 Q5 3.2 rattle on start
  22. 2014 sq5 rear wiring (reverse/taillight/hatch sensor)
  23. Front Dash Speaker Upgrade
  24. Power steering stopped on 2014 SQ5, need some suggestions as to the possible causes
  25. Journal camera for Q5?
  26. Audi q5 coding?
  27. help me identify this part? rack & pinion 2014 SQ5
  28. VagCOM coming up with "20136 - PCV Valve Malfunction" P05sE 00 [109]
  29. EPB and Service reset tool?
  30. B&O Speaker Faults
  31. Towing European Horse Trailer
  32. Engine Mounts?
  33. 3.2 Coolant Drain Plug
  34. Winter Tires and wheels for Q5 With 20" wheels step down to 18"
  35. Q5 YAW Sensor
  36. Driver Side Mirror help
  37. Fault 01020 no heat at idle
  38. Fault 01020 no heat at idle
  39. Looking for Genuine OEM Parts
  40. Feeling a "crack" underneath my feet at front right axle
  41. 19 qts of oil drained out of 2009 Q5, that has a 6+ quart cap.
  42. Tailgate latch replacement problem
  43. OBDeleven newbie
  44. Is the Q5 "good" for tall people?
  45. 2010 Q5 side assist retrofit
  46. A7 wheel fit on Q5?
  47. 2010 Q5 Front Floor Mats
  48. Anyone here successfully installed cutouts on their 3.0T Q5?
  49. Transmission cooler?
  50. No heat on idle
  51. Wiper Blades
  52. Drivers sideview mirror *whistles*
  53. need help, purchase?
  54. 2014 Q5 TDI Water Pump replacement
  55. Bull/Push Bar
  56. Power switch under steering wheel function?
  57. Map update 2013 Q5
  58. Opinions on 2012 Q5?
  59. 2017 SQ5 missing button on steering wheel
  60. 65,000 mile dealer service recommendations
  61. Dead pedal too far away
  62. 2015 Audi Q5 2.0T - Timing Chain Tensioner & Guides
  63. Picking it up tomorrow...
  64. 2014 Q5 Folding Mirrors Stuck
  65. 2014 Audi Q5 Parking assist sensor disable due to missing trailer hitch
  66. Vin look up
  67. stain all over the car
  68. Aftermarket transmission fluid cooler anyone??
  69. Oil pan removal procedure 3.0L (2013 Q5)
  70. Door Swap between years, anything I should know?
  71. Thoughts On 2013 Hybrid?
  72. FS: 2014 Q5 TDI Daytona Gray / S-Line / Sport / B&O / Nav 78k miles $24,500
  73. Paint damage question
  74. AUDI Q5 MMI 2G (SYMPHONY) UPGRADE!!?
  75. 2013 Q5 2.0 Tire Recommendations?
  76. Audi Q5 B8 Review: Everything you need to know
  77. Only one key fob allowing keyless entry
  78. OIL DIPSTICK
  79. Nice script for accessing green screen on 2015 MMI 3G+
  80. Parking assist not working
  81. Help Installing Remote Hatch Close Module
  82. Fuel gauge issue..stuck on full..I'm so done with this car
  83. Westfalia Trailer Wiring Install
  84. Transmission Fluid Change q5 2017?
  85. Help with MMI, Keytag, Audi Connect and MyAudi app
  86. availability of q5 trailer hitch?
  87. Hello from South Australia/Adblue/Mods
  88. PSA: Be careful buying Advanced Auto Parts batteries
  89. Dealer Says Replace Spark Plugs at 39,000 Miles, REALLY ?
  90. 2014 Q5 TDI and 22ft Airstream
  91. PL: Q5 8R USA/EU conversion no lights in the bumper when the flap is opened
  92. MN: Best winter tire option?
  93. Arm rest repair kit
  94. P2404. Replaced LDP. No go. Now what?
  95. 2012 Q5 Anti Freeze Strength
  96. Can i bleed master cylinder??
  97. Confused over "Tow bar - preparation"
  98. Stutter in 2nd & 3rd PCU/ECU issue...?
  99. Should I buy a Carly?
  100. P0299 Under-Boost :( 2012 2.0T Any Help please
  101. Does anyone know how to lube the tracks of the pano sunroof? 2016 Q5
  102. 2015 3.0 Rear Brake Back Caliper Mount Bolt Strange?
  103. Pulled the trigger on a RSNAV box for my MMI
  104. Will the 3.0L TDI suffer the same fate as the 2.0L oil consumption
  105. 2014 SQ5 crippled by a puddle
  106. Thinking about changing wheel size on SQ5
  107. Q5 engine replace
  108. Disappointed with Brembo ceramic brake pads!
  109. Left side engine mount code...
  110. How to lift the cargo floor panel 2013 Q5 Hybrid
  111. P0461 Fuel Level Sensor
  112. Recurring mice issue
  113. front axle
  114. Rear Wheel Bearing Replacement Thoughts
  115. 2015 Premium Towing
  116. 2010 Q5 3.2L Battery Issue
  117. Looking for advice on OEM Roof Racks (Crossbars)
  118. 2017 SQ5 Sunroof Wind Noise
  119. 2015 Q5 2.0T Buying Advice
  120. Head rebuild and timing woes
  121. Need new shocks - OEM leaking
  122. Upgrading backup camera
  123. Barracuda / Roof Rush Bike Carrier
  124. Bogus Craigslist posting
  125. Common oil leak points
  126. 2014 Q5 2.0 - 108k - Burning a quart every 500 miles
  127. Ac recharge
  128. Audi 8V steering wheel airbag wires TT
  129. 2017 Q5 radio upgrades?
  130. RSQ5 grille (pre-facelift) installation
  131. Lowering springs
  132. Q5 Running boards
  133. What would you do in this situation!!?? Scammed
  134. FOR SALE... Q5 BROWN CARPET SET.
  135. AC Evaporator Failure Q5
  136. 2012 Q5 Turbo assembly replacement
  137. Considering a Q5 Diesel, Thoughts?
  138. Honeycomb grille for 2014 SQ5
  139. Audi 2010 Q5 3.2L turbo/supercharging
  140. CN: Audi designer's dual-use design for your consumer cards.
  141. 2011 Q5 2.0 143K Miles - Am I on borrowed time?
  142. CarPlay upgrade from upgrademyaudi.net
  143. Nice set of VCDS and Green menu tricks!
  144. Audi Q5 2012 3.2 Bad creaking sound - help!
  145. 2014 Q5 - Where is the fuel pump control module located
  146. 2014 2.0t Q5 cam position phase -4.68
  147. Bluetooth Audio Options for '14 Q5 w/o Nav
  148. MMI and navigation update.
  149. Rear camera retrofit
  150. Climitized Cup Holder P/N
  151. Audi Q5 Spark Plugs Replacement
  152. Need help with brake pads replacement..
  153. Looking to buy a Q5
  154. CN: A NEWCOMER HERE FROM SHANGHAI, JUST WANT TO SAY HELLO WITH MY Q5 PHOTOS.
  155. Can’t start 2010 q5, no power to ignition.
  156. Coolant Fluid Leak
  157. Faile Side Assist
  158. 2015 diesel: Side Assist Stopped Working
  159. Illuminated Rings
  160. WDH on 2015 Q5 caused reciever to get loose
  161. New, got few questions
  162. JB4 Tune for B8/8.5 3.0t
  163. Audi Q5 sound system upgrade
  164. 90k mile check up
  165. 2017 Q5 - Carplay Add-on?
  166. AE: Q5 2 litre petrol turbocharger issue
  167. Statement and a question!
  168. Need help
  169. Fuel Pump Relay Location
  170. MMI and Text messages - Issue with Iphone8
  171. High pitch noise Audi Q5 2011 2.0 TFSI
  172. OE Battery Life?
  173. Cost to clean secondary air injection system of carbon buildup?
  174. I screwed up my MMI
  175. Anyone sold or traded in a neutered Q5 TDI?
  176. 55K service recommendation in SOCAL/SAN DIEGO
  177. High Flow Turbo Inlet Hose Question
  178. Passenger HVAC dampers do not move - Q5
  179. Seat Memory Module
  180. Time to get rid of my 2010 Q5 3.2?
  181. Mice in cabin
  182. SQ5 TDI Gearbox maintanance
  183. Larger display screen?
  184. Reversing sensors not working
  185. Aluminum rear bumper vs steel Draw-Tite hitch
  186. Rear Hatch Remote Closing
  187. Q5 Quattro light steering
  188. Q5 Radiator Fans Not Working
  189. Does anyone know where this part goes?
  190. VC: HELP MMI DEAD 2009 sline
  191. Roof Rack bars with sunroof
  192. Rear vent installation
  193. 2015 Q5 Wheel and tire question?
  194. Recommend a tool for trans temp and adaptation?
  195. Q5 AMI cord
  196. Introducing OEM Q5, SQ5 Post-Facelift LED Taillight Packages...
  197. 2014 Q5 2.0 Acquisition - Just Got Dealer History (new chain, guides, turbo)
  198. UK: SQ5 alloys?
  199. 2014 Q5 TDI
  200. 2015 Q5 Timing chain Fail
  201. Buying Advice: 2013 or 2014 Q5 2.0?
  202. New owner... new problems🤦🏻‍♂️
  203. Lease buyout- canada
  204. Name That Part!
  205. Audi connect: freedom pop connection issue
  206. Help! Coolant Temperature Sensor location
  207. 2013 Q5 2.0 Brake Caliper Torque
  208. Audi Q5 Door replacement thread
  209. Roof rack for 2011 Q5
  210. Looking for a solid SQ5 shop book that has interior door details
  211. Pass doors banged up, replacing help
  212. A/C Compressor Died (Parts Shortage?)
  213. 2021 Audi Q5
  214. 2020 Q5 Front Seat Cushion
  215. Keyless pushstart works but not really.
  216. Hazard lights turning themselves on while driving
  217. Q5 Wheel spacers?
  218. electrical rear lid not working?
  219. Engine coolant slow leak
  220. Idle at 1300 rpm ??
  221. 2016 Panoramic Sunroof Issues
  222. Parking System Plus with Rearview Camera (ERROR)
  223. 02111 - Motor for Window Regulator 012 - Electrical Fault in Circuit
  224. Giving away unused roof rack and near new floor mats
  225. Q5 Tdi oil capacity variance
  226. Snow screen/Pre-filter
  227. Thermostat replacement 2012 3.2
  228. Reliability post ring and tensioner replacement
  229. DPF Issues
  230. AC Control unit replacement
  231. 2016 Q5 3.0L - Gasoline Question
  232. 2015 Q5 - possible vacuum leak?
  233. SQ5 exhaust tip covers Carbon Fiber
  234. 19" winter wheel setups ... photo/reference thread
  235. Fan noise
  236. Side view mirror retro fit
  237. Service Due Light Reset
  238. 2016 Q5 Rear Shock Repair Cost
  239. 20" Wheel Offset/Dimensions?
  240. AU: Control arms and engine mounts?
  241. Front control arms and engine mounts. ​​​​​​​
  242. 2010 Q5 Meyle Rear/Lower Control Arm Not Fitting
  243. Rear parcel/privacy shelf -- where do you get one?
  244. Rear light alert disable (possible?)
  245. Rear sensors with hitch style bike rackE
  246. 2016 BLUETOOTH q5
  247. Mirror puddle light
  248. Cylinder4 Loss of Pressure?
  249. Mystery model designation?
  250. Q5 oil drain - sucking waste oil into the tank
