PDA
View Full Version : Audi A3 / S3 / RS 3
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81
  1. IE: 2011 A3 - Change navigation system (Japanese > English)
  2. Turbo replacement turns into $10k repair... Help!
  3. 2013 A3 TDI rear suspension question
  4. AUDI A3 Central Locking issue HELP PLEASE
  5. Fault code 00438 Fuel level sensor 2 HELP!!
  6. Black Friday // Cyber Monday Sales on now – Bright error free LEDs @ the best prices!
  7. 2018 Audi A3 Check Engine code P2681
  8. 2006 2.0T FSI - crank, start, die
  9. Buzzing after parking
  10. Audi a3 seatbelt igniter fault code
  11. 2018 S3 steering malfunction
  12. ESC off permanently on OBD11?
  13. 2006 Audi A3 engine FSI or TFSI?
  14. Help needed
  15. 17 inch to 18 inch Audi a3 2015 very little shaking one wheel
  16. Oil Sensor Tap Off's
  17. 2022 S3 tow hook license plate holder
  18. A3 2017 Carplay/AndroidAuto support
  19. MY2022 Audi A3 steering left scroll bar can’t click
  20. No heating
  21. Rare Whining noise S3 8P
  22. 2012 A3 Voltage / Battery Problem
  23. NA: Car indicator?
  24. Door won’t look from touching handle
  25. Looking for advice, 06 a3 overboos issue
  26. 2023 RS3: triple-black
  27. Random cylinder misfire. PCV replaced and still broken
  28. 2015 audi s3 prestige wreck
  29. FI: Dashboard symbol?
  30. What could be wrong with my car?
  31. Metal flick switch under dashboard. What is it? Car shaking when idle. Causes?
  32. Coil light and CEL on - code P0101
  33. Park Distance Warnings while driving???
  34. Left Side Light / Daytime Running Light - Warning
  35. Audi A3 MMI MIB
  36. 2022 Audi A3 Sedan
  37. Where can I find the esim number on my ‘18 A3
  38. 2016 Audi A3 coolant codes
  39. Audi S3 8l 2001 Four Wheel drive problem
  40. A3 8P1 3 Door Hatchback March 2009 remote locking chip code needed please
  41. Fault codes HELP!!!
  42. Front license plate bracket for 2022 RS3?
  43. Advice?
  44. 2015 Audi A3 AC drain tube
  45. Audi A3 etron
  46. 2017 A3 DRL Failure?
  47. Low pressure point for audi a3 1998
  48. 2007 A3 2.0T Front Passenger Door Actuator
  49. Rear wiper wont turn off
  50. 2011 A3 TDI - limp mode and 'boost not reached' code
  51. 2019 Audi A3 subtle clicking noise when idle
  52. AUDI A3 2009 ABS CONTROL module
  53. 2009 Audi a3 speaker issue
  54. ES: Are this wheels compatible with Audi A3 8v sportback 2018?
  55. Clicking/knocking noise while turning wheel and stationary
  56. A3 8P: Seeking hatch side storage options
  57. Click sound under acceleration or deceleration.
  58. RS: Help needed desperately
  59. Audi A3 1.8 tfsi BYT P2293
  60. Battery: 2 amp parasitic draw
  61. 2008 A3 Driver Side Window Issue
  62. Will the new Iphone 14 Pro Max 6.7” fit Wireless phone charging pad
  63. NZ: A3 2016 Head light is turning pink
  64. A3 weird noise when letting off gas
  65. A3 Diesel rear coil springs…what do I need???
  66. Any experts in the Audi A3 community could maybe explain why the ECP light comes on?
  67. A3 (2013) - Swap in power front seat in place of manual seat
  68. Audi A3 8P Clicking/Popping While Turning Wheel
  69. AL: Audi A3 diesel Oil Pressure
  70. Anyone help with this DRL issue?
  71. Need suggestions on which clutch i should buy?
  72. Wheel woes , wobble , and studs and lug nuts
  73. PCV valve location 1.6l BSE
  74. 2007 A - rear window regulator
  75. 2010 Audi a3 sportback- constant unlocking sound
  76. Gas pedal feedback
  77. TPMS control module J502 No Communication please help
  78. Audi A3, central locking and mirror
  79. Audi A3 8P 1.6 AC Problem Help ( Not as others )
  80. 245/35/18 on 2016 A3 Premium
  81. Audi A3 2022 Adaptive Cruise control configuration
  82. Audi A3 2022 35 tfsi - vehicle starting system malfunction
  83. 2016 A3 Harness 5Q0-971-230-FC
  84. 2012 A3 Driver Side Wiper Arm Issue
  85. 2012 A3 TDI lots of warnings, all at once!
  86. memory stick not playing
  87. Troubles after retrofiting MFSW and CC Audi a3 8p
  88. Finally found source of constant coolant leak (I think)
  89. does anyone know where this harness goes
  90. SE: Change engine in A3 1.6 8P 2007
  91. Audi A3 8P1 2007/11 Squealing/grinding/scratching noise
  92. MY22 A3 Sirius XM Issues
  93. Audi A3 sport back side skirt
  94. UK: A3 1.4 TFSI Not Starting
  95. Engine swap
  96. GR: Considering buying an A3 1.8T (2nd hand)
  97. Air Blower n alarm siren issue
  98. 8P front bumper questions
  99. UK: True Tune Audi S3 2017
  100. What is this
  101. 2016 A3 Premium dual sub and Amp install. HELP!!
  102. UK: 2006 A3 2.0TFSI Please help Misfire at idle
  103. How to Enable S Performance Screen on Virtual Cockpit
  104. Problem with wiring/fuel system?? Pls help
  105. Audi A3 can’t toggle music
  106. A3 2010 doors wont unlock
  107. A3 8P7 cigarette lighter staying on
  108. Blue 2015 S3 Left Rear Door Needed
  109. 2022 A3 or A4
  110. 2010 Audi A3 1.8TFSI idling/misifire issue
  111. Taillight connector wire colors pin out
  112. 2018 S3 wheel search
  113. 2016 S3 middle AC vents not blowing air ... at all
  114. How/where to connect red/black wires from BT audio adapter?
  115. '22 A3 Sunroof tint not possible?
  116. Bluetooth hands free not working
  117. Oil leak diagnostic, please help
  118. Oil leak diagnostic please help
  119. Parasitic Drain BUT not found using two multimeters
  120. Cold start noise
  121. IE: Audi A3 2010 1.6 diesel heavy steering, cut out/not starting, dashboard lit up )
  122. Front license plate bracket options 2018 S3
  123. Audi A3, 8P 2.0, 100kw, injection cut-off on cylinder 3
  124. Audi A3 juddering
  125. How to turn off the drl when headlights on
  126. 2022 Audi A3 B&O Speaker Upgrade
  127. Audi A3 wheel Damage
  128. P2440 code secondary air valve 2010 A3
  129. UK: A3 wiht no rear wiper arm: how to install one?
  130. Audi A3 2002 a/c not delivering cold air inside
  131. Weird engine noise?? Need help! (Video)
  132. UK: A/c not blowing cold air inside car
  133. Intermittent fault with passenger side wing mirror
  134. short to ground codes
  135. Unable to fill gas tank
  136. A3 8P immobilizer triggered and won't disable
  137. Strange rattling / knocking from about 1500 to 2000 rpm (2.0 TDI 16V CR 103kw, CFFB /
  138. Thankyou
  139. New Dipped Beam Control Module Installed
  140. Bmn converted Bxe A3 n75 woes
  141. Issue on cluster replacement
  142. Audi s3 radio issue
  143. 2011 Audi A3 with CBFA Waterpump
  144. Oil leak from Turbo
  145. Code: P256300
  146. UK: A3 2.0 sportback S Line SPEC QUESTION
  147. Audi A3 8P Needle sweep
  148. Dampf/weißer Rauch aus dem Auspuff (Mit Bildern)
  149. Audi door light switch A3 8P1 (09) help needed
  150. UK: Knocking sound...please help identify
  151. DE: Vapor/White Smoke (With Pictures)
  152. Passenger seat belt stuck
  153. Audi S3 8V Drive Shaft Flex Disk
  154. A3 2016 Driver side reverse/signal light not working with trunk closed.
  155. Audi a3 p2108 fault code
  156. Rusted keys. Now saying gear box malfunction ​​​​​​​
  157. How to remove plastic that covers wires from back of the car to the trunk audi a3
  158. Strange vibration at idle A3
  159. 2020 a3 APR Stage 1 ECU and APR Stage 1 TCU tune
  160. Honeycomb Grille?
  161. Add haldex to A3 1.8T 8P (2010 model year)
  162. Audi A3 E-tron 2015 MIB2 retrofit
  163. Gearbox fault
  164. 2015 A3 Doesn't recognize it's in Park + error msgs in dashboard
  165. Auto EPB when gear put in P on 8v
  166. TR: DQ200 questions
  167. A3 2015 (65) Headlight Malfunction?
  168. 2010 A3 replace grille
  169. Advice on Getting Parts (Intercooler/charge pipes)
  170. Ambient lighting?
  171. Brake upgrade
  172. s3 diffuser with big fins
  173. To RS Quattro front grille
  174. H&R Street Performance Coilovers?
  175. Add Aux/Sirius XM to 2007 A3 Symphony
  176. Stage 3 APR
  177. MMI Box Potential Replacement
  178. MMI Box Replacement
  179. Paddle Shifter?
  180. UK: AUDI A3 1.8TFI 2014
  181. Brake warning light (!) and now check engine light 2011 audi a3
  182. Crossbar end caps for Sportback
  183. Concern about Suspension on New A3
  184. Model number for headlight
  185. IMMO problem / SAFE no start
  186. getAudiparts.com | NEW Genuine Audi Dynamic Center Caps Sets!!
  187. Oil Pump Failure?
  188. Audi A3 Transmission Issue- Please Help Me
  189. Fuse box replacement
  190. Audi a3 switched dials
  191. 2010 Audi A3 transmission questions
  192. OEM or Aftermarket Secondary Air Pump?
  193. rebuild higher model s3
  194. UK: Audi A3 front bumber
  195. RS3 large thumping issue
  196. 2015 Audi A3 soft beake pedal
  197. Need help regarding Audi A3 2014 air baffles
  198. All systems become unavailable
  199. A3 engine oil
  200. UK: P0472 - 000 Signal to low MIL ON fault code
  201. Head unit audio quality
  202. 2006 A3 Tail Light Wire Harness Connector
  203. Dsg issue
  204. Wheel and tire fitment.
  205. G42 air intake sensor.
  206. AE: Gearbox malfunction you can continue driving
  207. S3 8P OEM part number for the thermostat
  208. 2021 Audi A3 TFSI e volume wheel/control not working.
  209. Audi A3 8P Subwoofer Replacement/upgrade?
  210. 2022 model have spare tire?
  211. 2011 A3 want to swap Audi Nav unit for CD changer unit
  212. MA: Sensor capteur de niveau d'huile défectueux
  213. 2022 A2 horse power reduction
  214. S3 8p stage 2+, what next?
  215. Calibration for Rear Windshield
  216. 8p Roof rack
  217. 2022 Performance parts
  218. Audi a3 s tronic stutters ,misfire?
  219. Helps in relaxing your body and mind
  220. Fault code audi a3
  221. Fuel gauge will only read to half when full
  222. Regular coolant warning after having clutch replaced.
  223. 2016 A3 Fault code P00B7
  224. 8P 3.2 dsg vibration under acceleration
  225. 2018 RS3 15k miles DSG pump?
  226. Coolant hose part numbers
  227. Idle Rpm in sport mode
  228. Audi s3 8L parking sensor issues
  229. 2015 A3 Backup Camera Issue
  230. Low oil pressure mystery
  231. 2017 S3, 48k miles, $33.5k. Buy or no?
  232. 06 A3 2.0T - Buy or Not? Engine Noise Diagnosis
  233. 16 Audi S3 Strut replacement
  234. Audi RS3 Review
  235. TT Cockpit in S3 8V facelift
  236. 2006 Audi A3 headlight issues
  237. 2006 A3 Parasitic Drain Diagnosis Help
  238. S3 8p Stage 2+ issue
  239. Drivetrain issue
  240. false mileage
  241. Aftermarket headunit - music gets 2x louder after a phone call (Android Auto)
  242. UK: From the OBD no communication help needed please
  243. ESP sensor location Please help!
  244. 8V S3 intermittent starting issues
  245. Honeycomb Grill
  246. AU03 DAZ - Private Plate For Sale - Open to Offers
  247. UK: Can my engine handle a remap?
  248. Bluetooth Module
  249. Headlight levelling sensor/sensors
  250. 2015 A3 sunroof issues?
