View Full Version : Audi A3 / S3 / RS 3
- 2015 audi s3 help me fix this problem
- Audi s3
- 2009 A3 Terminal 30 Left Error
- Audi A3 2015 CRC Error
- 2015 A3 Haldex Earth ground
- Valid A3 decoder vin and PR decoder
- a3 forge diverter valve question!!!
- Cooling fans only on after car is off and ESP light permanently on
- Steering wheel off centre even after alignment
- 2017 Audi A3 lease return with cracked windshield - HELP!
- 2010 audi a3 curved lighting
- 2006 A3 2.0 FSI won't start, lots of codes
- Need Some Info Please (Hose)
- Looking to buy a 2016 A3
- IE: Audi MMI and Sat Nav for Japanese Market Car?
- S3 MMI SD Card videos
- audi a3 oil consumption problem
- My Audi A3 2012 Sportback, Opinions?
- Audi a3 2,0 fsi 2004 cauge problems
- A3 Remap or Not?
- 2009 A3 Fans not working
- Audi S3 shift knob help!
- Spare Tire Spec
- Are S3 stock wheels cast or forged?
- Audi A3 2.0 tdi 2014
- New to me 2006 A3 Quattro VR6 3.2 Questions
- Back to Audi after 13 years
- Help Identify part 09 A3
- Tail light assembly melting on both sidesO
- Avg Fuel Consumption monitor? RS3
- 2011 Audi A3 TDI Reliablity?
- What colors is this RS3?
- Audi A3 Problem
- Audi s3 . Upgrading to 19’ wheels
- 2015 A3 Cabriolet MMI Software Problem
- 2015 Audi A3
- Need new engine, where to buy?
- Instrument Cluster not working after battery disconnect
- Bose not Bose, Bluetooth, etc
- 09’ Audi A3 8p
- HELP !Audi s3 2016 Brake pad and rotor replacement
- getAudiparts.com | Black Friday/Cyber Monday FREE SHIPPING + Promo Code!!!
- performance chip for 2016 s3
- Glove box lid lock latch repair
- 2013 A3 navigation cd
- Combine Black Friday and Movember to Save Lives and Some Dough!
- Matrix Beam Matrix
- Clutch Failure
- 2015 A3 1.8T coolant leak
- DE: Audi A3 2003 8P 2.0 FSI (I need help..)
- Suspension noice clucking+ popping noise
- Headlights Brighten When Breaking
- Car starts and stalls after sitting overnight
- Plastic bits broken on heater water feed - boondcks go-around.
- 2016 Audi A3 Quattro on rev9 coilovers
- Audi A3 8v 2014 clicking engine noise and smell
- 2006 A3 2.0T Multiple Problems
- Rear Bumper Scratch
- Left front lower control arm change, 2006 Audi A3 (8P)
- Dashboard not working
- Cooling fan problem
- 2016 S3 Smartphone Integration
- ZA: A3, Brakes faulty
- RS3 concerns
- audi a3 2009
- Audi A3 S Line 2015 heaters blowing cold on drivers side
- Key and key fob
- Brake wear to 3mm at 30k miles + rotor replace
- Looking to buy 2016 A3 e-Tron. Opinions wanted
- 2005 a3 instrument cluster not working.
- Did the dealer mess up?
- ‘16 S3 8V front seat belt pretensioners configuration help
- Best online shop to buy Audi parts?
- New to the RS3 World, What mods recommended?
- 8p electronics shutting off randomly
- S3 Sedan 8V - strange noises after pothole, normal?
- Rebuilding ‘16 S3. Need people who are smarter than I am.
- Audi A3 8L. Central Locking stopped working.
- Please Help: clutch position sensor issue
- Electrical, blown fuse #9
- 2015 A3 8V, Door marker lights
- ZA: 2012 8PA A3 2.0T Hot Start Issue
- 8L S3 Radio
- 8L S3 Acceleration Problem
- “Run flat tires” on 2018 Audi A3 Quattro Cabriolet?
- 15' A3 8V trunk will not open with handle on exterior of vehicle
- AWE Tuning switchpath exhaust
- Favorite Mod on the 8V
- New tires
- A3 hitch
- Audi A3 8L 1.6 petrol Check engine ON
- Bulb warning light comes on but the bulb is working
- ac fan speed drops to 1
- Belt or chain???
- Front splitters
- Audio system fault.
- Best place for Front Bumper Cover S-Line or RS3?
- New member seeks advice on used A3 purchase...
- 2008 audi a3 tiptronic transmission
- Audi A3 Transmission problem
- NO POWER to RIGHT SIDE PASSENGER DOORS
- Rate my new Audi A3 wrap? I want opinions from the public
- Headlight oscillating brightness
- 2007 A3 8P Timing Chain
- 2019 A3 with no smartphone interface
- S Tronic Slight Jerkiness
- 2013 Audi lights malfunction warning
- Distance on Empty For A3 TDI
- 2006 8P CEL P0302
- auxilary led light bar wiring - need help
- S tronic paddle
- A3 Self-Levelling Headlight Noise
- Nokian Hakkapelitta or Bridgestone Blizzaks
- A3 to rs3 conversion Plus Manuel!
- 2007 a3 bumper cover
- Can one get the A3 (8V) indicators to sound a tone?
- Boost Gauge Question
- 2011 / 2012 / 2013 Audi A3 TDI w/DSG
- How hard is it to replace my 08 fwd dsg gearbox?
- Is a 2019 A3 a good 'reliable' car for the long term ?
- 8L A3 1.8T: Cruise control and aircon issue
- Audi 8P/Rotor Size
- EGR testing BGU engine
- Egr delete question
- Audi A3 2.0 tdi 2011
- Audi A3 Key fob
- Audi A3 Parts Question
- A3 8V 1.4TFSI S-Tronic irritating sound, gearbox?
- HPFP repair kit: What the heck are these?
- 2008 A3 1.8 TFSI stalled while driving
- 2011 Audi A3 TDI **SWIVEL LIGHT**
- Map updates wont show up on myaudi site
- Clutch pack? Mechatronic? And how can one be sure?
- 2019 A3 Wheel Size
- Fuel Blockage
- Mass Air Flow(MAF) sensor problem
- Fuse Location
- Audi S3 IE Stage 1 + DSG Tune Review and Install
- reset warning lights
- Audi RS3 Drive System Malfunction P0000
- 2003 Audi A3 2.0T Base A/C Compressor
- Car does not respond
- RS3 all season tires
- 2007 Audi A3 Symphony Aux cord
- UK: How to tell if a car is quattro by the number plate?
- Engine cuts power briefly, then reengages?
- Audi A3 1.4 TFSI cylinder 2&4 misfire
- anyone know how to remove PCV valve?
- Whining Sound
- A3 Bass/Speakers Upgrade
- Buying advice for A3 3.2
- Exhaust Manifold Heat Shield Removal
- 2009 A3 Sportback TFSI 1.8T Audio help
- 2013 Audi A3 5 Door Wind Deflector Issue
- Need Help - 2012 2.0 TFSI Quattro Rear Brake Piston Stuck
- Audi A3 Wiper Issues
- 2013 Audi A3 - P2568?
- 2016 S3 - brake service... both pads & rotors??
- RNS-E With Universal BLITZSAFE Interface help
- Seat Removal - Help Please
- S3 8L no power @ high revs
- Bent shifter? A3 8P
- Pretty Violent shudder when accellerating
- 12V Cigarette Light LED Color Question
- Small oil leak and pcv valve
- 2006 A3 No Crank (New Battery)
- Huge oil leak after valve cover gasket repair-first major repair
- Fuel Gauge not working
- Please help
- Audi A3 Exhaust X-Piping
- A3 8P Fuel Pump Problem?
- Water inside the driver side
- 2018 S3 front grill badge
- Audi A3 ISSUES WITH LIGHTS
- S3 Brakes question about odd looking item
- problem with manual gearbox, please help
- Breaking 2008 Audi A3 1.6 petrol
- Is this a good gift idea?
- Dash lights/gauges and AC issue
- turbo built to non turbo motor
- Bang and Olufsen upgrade
- Oil pump diagnosis
- Side bulb problem.
- 2007 Audi A3 no air blowing at all
- Looking to buy/borrow Iroz flash tool cable
- A3 8V 2 wheel drive alignment specs
- 2008 A3 Auto - Changing gear at 60kmh Slows Right Down
- Question - perhaps dumb
- 2009 a3 Headlight problems.
- help with replacement piece 2007 A3 Sportback
- First time Audi owner
- Audi A3 01M TRANSMISSION PROBLEM
- 2007 Audi A3 2.0 turbo oil pan replacement question
- 2015 Audi A3 2.0T. Quattro not working.
- Looking at buying an A3 2.0 diesel quattro 2014
- Window washer level warning, no sensor
- 2009+ 8P 2.0T owners feedback request
- Problems with my 2011 Audi A3 TDI S-Line!!!!!!!!!
- Swapping CR140 ECU for CR170 possible?
- Does someone own A3 2009 2.0T USA version?
- Audi A3 - A/C Problem
- 2009 Audi A3 8P1 brake light bulb specs
- A3 1.6 fsi 05 failed mot Emissions help please
- PLease Help. Alignment problems
- 2009 A3 automatic hatchback makes bad clunking noise when engaging/disengaging drive
- Central locking and windows now working
- vibration when not accel until clutch depressed
- Where can I get a replacent engine(2008 A3 2.0T)?
- 2007 A3 S-line Dual Zone Climate but no A/C???
- Audi Rs3 8p
- Please help me bonnet wont release
- IS12 to a bigger Turbo Question
- Help! Can’t get new expansion valve seated.
- RS3 vs A7
- Audi Concert speaker wire connector - HELP!
- '06 Audi A3 2.0 Tdi 170 BMN P1269 / P1266 Implausible Signal
- fuel injector flow rate
- Wheel help
- ABS/ Braking problem
- ABS activation during brake bleeding?--2010 A3
- Help with Rain Light Sensor Wiring
- 2012 A3 Sportback puddle lights
- My alignment numbers don’t make sense
- Buy a CPO Audi A3? Resale Value?
- new guy needing help with a knocking noise.
- getAudiparts.com | Genuine Audi Black Rings Sets!
- Rear Brake & Rotor Replacement
- Ordering an RS3
- Audi A3 1997 1.9 TDI Steering noise
- MMI
- Weird issue but giving wrong code
- Audi A3 2008 Sport, adding break fluid
- Oil pressure light still comes on after repairs
- Rear Speakers not working
- 2015 A3 2.0 Quattro - ECT Sensor HELP!
- Light wiring
- Looking at an '11 2.0TSI quattro
- Various inop light messages
- Engine noise cold start
- A3 8P Body Kits??
- print out the engine ECU data
- Clearmounts now on sale for $29USD! Order your today!
- Carbon Ceramic Squeaking/Humming low speed.
- Wiring diagram
- ticking/rattling noise on decel or after rev
- 06 A3 Motorhome Dinghy?
- Noise from time chain housing
- 07 2.0t manual shave cylinder
- Help with Coolant Hose ID
