PDA
View Full Version : Audi A3 / S3 / RS 3
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81
  1. Audi 3 s line 2010 only reads 1 song off the SD-CARD
  2. EA113 vs EA888 ENGINES?
  3. Shuddering and slight drone Audi A3 Quattro 09
  4. UK: 2014 Audi A3 MMI upgrade?
  5. Need help choosing my first car. A3 or A3Q? or BMW
  6. Connector for door locking hose broken
  7. Could an oil change cause idle surge?
  8. Speedo Cluster compatibility
  9. Convert Audi RS3 2018 from US to europe standards
  10. 2019 A3 in production?
  11. Jerky S Tronic Transmission
  12. facebook for audi fans
  13. Odometer readings - Did I get fooled?
  14. Audi A3, 2015, front license fasteners at 45 deg angle?
  15. Help - Corrosion & Replacement Sill
  16. Hello Everyon
  17. fuse locations
  18. 2011 A3 2.0T FSI - part of oil consumption lawsuit?
  19. 2006 A3 DSG - steering wheel upgrade paddle shifters
  20. AC compressor not kicking in
  21. s3 whine noise when decelerating
  22. Rough idle - Audi A3 8P Facelift 2010 2.0 TDI
  23. Audi MMI shuts down then startup again every 80 minutes
  24. How to replace the window driver from an Audi A3 2016
  25. How to replace the window driver from an Audi A3 2016
  26. Electronic parking brake issues
  27. A3 8L window weirdness
  28. HPFP Cam Follower
  29. airbag dissengage
  30. ACC Steps
  31. Comfort mode stopped working
  32. Radiator Replacement
  33. Need help Recoding ECU Module?
  34. Leak from a hose at front of engine?
  35. NZ: ignition barrell
  36. 2019 RS3 order sheet
  37. Audi A3 2007, Bonnet/Hood stuck, cable snapped
  38. 2017 Audi S3 Front Plate mount installation
  39. Drove an R8 V10 Spyder, impressions.
  40. New Audi s3 - question
  41. AC High pressure switch code 819
  42. 2006 A3 V6 Traction Control -?
  43. Bkd engine turbo actuator calibration
  44. 2016 a3 No air or heat coming out of center console vents
  45. Garage door
  46. Enabling rear speaker / amplifier for aftermarket head unit (2010 A3 8P)
  47. APR Tune
  48. 2015 A3 TDi towing capabilities
  49. 2012 AUDI A3 2.0T - LOW OIL PRESSURE
  50. A good bumper guard for the A3?
  51. 1999 A3 obd2 wiring diagram ..
  52. A3 1.8 1998 auto transmission sensor
  53. Audi a3 8l. Guess how is this fuel filter.. Things to replace ?
  54. Audi compartment URGENT HELP
  55. TPMS Malfunction Fixed
  56. RS3: Dealer says brake groan normal?!
  57. Audi A3 8P 2005 2.0TDI immobilizer/cluster fault
  58. Strut Clamp Diameter
  59. Dealer wants $2,100 to replace A3 A/C compressor
  60. battery light on and temp rose
  61. Traction Control light and thud heard felt
  62. ***WannabeRacer.com | Norcal/Bay Area Vinyl Wrapping Tour - July 30th - Aug 3rd 2018*
  63. Coilover Pinch Tab Broke
  64. Need Pinout for the BOSE amplifier
  65. Radio problems
  66. my a3 does not drag
  67. new a3 owner - help please
  68. how to replace the 3rd brake light in a 2006 a3 quarto with a spoiler
  69. 2007 A3 window woes
  70. Dipstick housing
  71. Having Trouble finding the Audi I want
  72. $2300 To Replace Timing Belt & Waterpump - Dealer Price?
  73. Touching up the rust bucket
  74. Fix for seat belt light not turning off
  75. Rear wiper Moyer part number
  76. Alloy max size on audi a3 05
  77. 8L Wiring Diagram Needed
  78. Rns E temperature very low error
  79. RS3 8v common issues?
  80. S3 2015 wont recognize P gear so i can’t lock car
  81. 2007 Audi A3 vibration issue
  82. 2016 A3 2.0T Premium with S line styling and LED light package , has the TFSI engine
  83. Retrofit cruise control on 8P
  84. My 2015 S3 amp died do to salt build up
  85. cvt vs dsg
  86. 2018 RS3 vibration issues
  87. Need Help Deciding Rim Guard Color
  88. Car choking when accelerating and giving fault codes
  89. 2016 Audi A3 2.0T Side Skirts
  90. 2015 A3 High RPM at low Speed
  91. Remove ECU tune?
  92. Audi A3 8v problem with MMI
  93. 2007 A3 ignition keys not working
  94. Car turns over but won’t start
  95. Rear shelf part number - 2012 A3 5dr Sportback 2.0TDi
  96. Reprogram w/Just One Key
  97. Cabriolet issue
  98. 2017 & 2018 US Production Numbers (As of 5/23/18)
  99. Does an RS 3 have a "dynamometer mode" setting?
  100. New 2018 Audi A3 owner
  101. Removing Electrical Connectors
  102. EPS light on and loss of power of Audi A3
  103. Roof rack for s3
  104. Starting Mods for 8V A3 2.0t?
  105. The new RS3 is just amazing! Full Review Video
  106. Whooing Sound at 65-75mph 2016 A3
  107. Power steering failure - Red warning light
  108. Help please - dropping subframe
  109. Rear window tinting
  110. 2016 A3 Coolant Light
  111. Audi A3 sport 2013 paint code
  112. Odd clicking sound
  113. Audi A3 8L (1996 - 2003) boardcomputer
  114. Thinking about buying a 2015 Audi A3 TDI
  115. A3 2011 FWD 2.0 TFSI CCTA 8P ECT Sensor Location
  116. A3 saloon boot locked
  117. Lowering Springs
  118. Strongly Considering a 2007 A3 3.2L Q
  119. Audi A3 8PA Concert III telephone bluetooth diagram/pinout
  120. Tail light issues
  121. 09 A3 Brake upgrade with OEM VW parts?
  122. 2007 audi A3 purchase help
  123. Misfires after 3 hour mark then doesn’t stop
  124. Question on S3 Wheels
  125. A3 - Setting Default Virtual Cockpit Screen?
  126. 06 A3 Tail Light Issue???
  127. How to fit parking brake switch in console
  128. Drivers side window controls not working - 2015 A3
  129. Gearbox codes
  130. Navigation
  131. SiriusXM A3 8p trouble
  132. Brighter D1s/2s/3s Xenon Bulbs | Front Turns | Error Free Reverse LEDs
  133. Coolant temperature sensor keeps going out
  134. Hub 4 or 3 hole
  135. Audi A3 8P 1.6 hard to start when high temperatures
  136. 2009 A3 transmission "lurch"
  137. Audi A3 Amp, Equalizer and Sub installation
  138. Help
  139. 2013 A3 TFSI Sline Quattro, honeycomb grille find
  140. Audi RS3 HomeLink
  141. 2002 Audi A3 1.8t
  142. 2018 RS3 Owner’s Manual
  143. RS3 vs S5 sportback Decision..decision..
  144. getAudiparts.com | Genuine Audi LED Puddle Lights Sets!
  145. getAudiparts.com | Genuine OEM Audi Parts + FREE SHIPPING on Most Orders $299+!!!
  146. Audi A3 8l ABS light comes on, gear linkages
  147. Is this a stock GPS / Radio head unit?
  148. A3 TDI Warm Weather starting problem
  149. need help with codes P0456, P0442, P2101
  150. Spare Key won't start car
  151. s3 wheel spining
  152. Vibration at low speed 1st to 3rd gear
  153. does an audi a3 201 progressive sline have leather seats?
  154. will a3/s3 rain guards fit rs3?
  155. will a3/s3 rain guards fit rs3?
  156. MMI bugs
  157. Brake Pad and Caliper Clean
  158. Revs go up, but acceleration isnt as it's supposed to be.
  159. Audi A3 2.0 tfsi 2009 black edition help
  160. Audi S3 add navigation package to progressive trim
  161. Lean off idle
  162. Weird Lemo Connector in the B-pillar interior panel
  163. In the market for used 2015 S3....
  164. 2016 a3 2.0t is going to be at 55000k soon.
  165. getAudiparts.com | Give a little TLC: Genuine Audi Car Care Products!!!
  166. Error code and fix it.
  167. 2006 Audi A3 Issues - Need Help Please
  168. Oli Filter Pointers
  169. 2015 audi a3 key fob battery dash reset
  170. RS3 Good price
  171. 2015 Audi A3 engine noise dealer falsely diagnosed
  172. Stupid Question
  173. Temperature appearing under time on dashboard
  174. RPM Wobble at Idle 06 A3 2.0T
  175. Audi A3 Grill Fit
  176. Any Help Out There?????
  177. Question for s3/rs3 owners over break in period
  178. New Audi A3 1600Km problem. Please Help.
  179. '06 Audi A3 Steering Rack Torque Sensor Failure
  180. A3 Electrical Problem
  181. 2009 2.0T: Strange Cold Start
  182. Lean off idle
  183. Lean off idle
  184. remote windows operation
  185. Rough Idle
  186. Audi A3 2012 Roof bars
  187. S3 fade indicator upgrade
  188. Problems unlocking 1 door with central lock
  189. Questions regarding buying a used A3
  190. RNS-E Navi Pro Plus
  191. oil in collant even after oil cooler change BMN 170 tdi
  192. Quad Exhaust for A3
  193. Rotors and brake pads
  194. How to fit reverse camera in my Audi A3 Hatchback car.
  195. S3 COOLANT LOSS AND THERMOSTAT-CAR DOWN-NO PARTS AVAILABLE
  196. Passenger innter tail light led problems
  197. Sunroof stuck open, its snowing/raining
  198. Timing belt or chain
  199. M3, Boxster S, RS 3???
  200. NEW! ECS Street Coilovers for the 8p A3!
  201. A3 Speed Limiter?
  202. Blow Off Valve for S3!
  203. AudiA3 1.6 2002 locking car
  204. Snow performance methanol kit compatible with Burger motorsport JB4?ma
  205. S3 Lowering Springs Vs. Coilovers???
  206. About to purchase s3
  207. Audi a3 8v static noise over bluetooth.
  208. 2006 Audi A3 vibration issue
  209. Please help. Problem with boot/rear lights
  210. ABOUT TO PURCHASE A3
  211. 2015 Audi A3 unitronic tuned weird cold start issue
  212. 2013 A3 TDI S-line 8V Xenon Plus - Replacement Low Dim bulbs
  213. Engine Coolant
  214. Why cant I find the amp?
  215. A3 1998 1.8T Fuel pump fuse blown
  216. UK: A3 59 plate rear tail light not working
  217. 2011 A3 torque for the bolts for brakes
  218. 2015 S3 Window Trim replacement NEEDED!
  219. Cabriolet hood problems & coolant leak
  220. A3 2002 and 2005 Oil cycle
  221. hood micro switch
  222. A3 Steering Wheel
  223. Aftermarket Radio and rear speakers not working?
  224. Audi A3 SPORTBACK TDI 1.6 2014 Which headlights do I have?!
  225. Blower/heater/cooler
  226. Blower/heater/cooler
  227. Audi A3 Special Edition 2011 Bluetooth radio
  228. 5 tires in 7500miles
  229. The Best Audi Cellphone Mount! Discount Code Available
  230. Golf R brakes
  231. 2015 a3 misfiring and stalling
  232. White gunk under oil cap help :'(
  233. activate sirius Audi B8
  234. Audi A3 front passenger door fault
  235. 2018 Audi RS3 problems/malfunctions
  236. Alarm and lock only happens on flat ground
  237. Recommended Tire Pressure 19" Wheels - S3/A3
  238. Audi A3 pre-purchase inspection question...
  239. Rear view camera for an A3?
  240. NEW 2006 A3 2.0 owner-need opinions on mods-PICS PLS
  241. glove compartment rattling
  242. Loss of power
  243. back up camera for 2014 R8
  244. Bumper corner popped off a little
  245. Fixing xenon lights ( Audi A3 2002 8L1 132kw)
  246. fusible link?
  247. Recommended blind spot mirrors for A3?
  248. '15 A3 headlight replacement?
  249. How often should I charge my battery?
  250. ecm cost for audi a3 diesel?
