- Common Audi problems?
- 2003 S3 Gearbox removal (8L chassis)
- EPC failure now the car wont start
- Front Grill Compatibility ? Cabriolet 1.8TFSI
- Install license plate holder 2011 A3
- Audi a3 transsmission fluid!
- A3 1.9TDI 16" Alloy Wheels Dimensions
- 09 Audi 2.0t fwd build?
- Clutch Change
- Small Hole in Transmission
- RNSE nav in 2008 a3?
- :: ECS Tuning :: JOM Coilover Sale Extended $350 & Free Shipping!
- engine light
- audio remembered volume
- intermittent throttle body with constant pedal
- Audi A-6 quarto 2003 model, key fob not working
- A3 8L cluster
- 2008 Audi A3 2.0T
- A3 2012 Replace rear shocks and tires are still rubbing w rear passengers
- Audi A3 8P Aftermarket Stereo Install
- Can a front wiper motor be replaced with a newer version?
- Looking For Factory Satellite Installation Instructions
- audi a3 8l key
- Found 2006 A3 3.2L for cheap. WORTH IT?
- 2007 A3 Quattro Rear Axle Removal
- 2006 A3 2.0T
- change of steering wheel
- Auto gearbox leak?
- BOSE System - AMP Wiring Diagram
- Facelift a3 2004 help!
- Audi Phone Holder Feedback Request
- Possible odometer fraud - need advice!
- Possible to make a 2006 A3 Bluetooth compatible?
- A3 tdi S line Auto
- To the Audi engineers...
- About ABS
- Advice on purchase of a 2009 A3 3.2l Quattro
- Audi A3 2005 Speakers not working/dodgy connection
- AUX in mod has no sound output on right channel
- A3 Handbrake warning still applied although handbrake is off
- undercarriage photo(s)
- Audi a3 3.2 liter 2009 ,Revers takes time to get in gear
- Audi A3/2004 - Mass air Flow ?
- 2006 A3 2.0T Fsi Central Locking Not Working
- audi a3 8p 2.0 fsi problem
- Visor Toll Ticket Clip missing from 2017 A3?
- 2007 Audi A3 - Cranking Engine Start Sound
- Mechatronics TCU Rebuild?
- P0299 - 2008 Audi A3 2.0T
- Audi Phone Holder 10% discount weekend!
- A3 key fob reprogramming
- 2015 A3 offside rear pad is down to minimum
- Putting wiper blades into service position
- Crank case breather oil
- 2016 A3 2.0T is burning oil
- :: ECS Tuning :: ECS Paddle Shifter Extensions | Audi 8P A3
- 06 A3 child's lock problem.
- Brand New 2017 Audi S3 Leaking Gearbox Oil
- Custom Cell Phone Holder for the 8P
- Need help please!
- ECM upgrade for PZEV engine?
- Is navi standard on 2017 S3?
- 2015 S3 Calipers
- UNIQUE PROJECT FOR SALE ! - 644 hp / 772 Nm
- NEED HELP. New fuel pump and pump relay fitted. Car still cuts out
- Q7 Headlight Upgrade
- Timing belt a3 8p
- Noob here with a wiper problem. Hello all!
- A3 no lights in dash
- Rns -E Voice Commands Problem
- Driver seat shifting upon coming to a stop
- thinking of buying a used A3
- Navigation button
- rear brakes on 08 A3 quattro; DIY?
- Unhealthy noise
- PLEASE HELP - water is leaking into the boot of my A3 cabriolet!
- Audi A3 Temperature and Idle Issue
- NEW D1s/2s/3s Xenon Bulbs | Front Turns | Error Free Reverse LEDs | Interior LEDs!
- Strange sound from engine
- MPG after 15k miles service went down.
- Temperature Sensors
- 2011 rear badge "TFSI"
- 06 A3 2.0T BPY - Low Oil Pressure then P000A code?
- Shaking A3
- Audi A3 8P 3dr door problem
- how to reconnect split climate controls?
- Redlining a 2015 S3
- Cabrio Tuning Query
- How can I see the current song playing?
- Replacement steering wheel/airbag for 2011-13 8P
- Brake stuck when cruise control on
- PRNDS blinking
- 2017 S3 Audi Connect
- Break & Hazard lights Malfunction
- do I need an X pipe
- Engine Overheating - Strange Behavior
- Windshield Wipers
- 2017 s3 muffler delete and resonator delete
- Body Control Module (right) fuse melted
- $ 100,000: Audi RS3 price in Brazil
- Quattro decal?
- taking delivery of 2017 A3 Prestige
- Front Wipers 2006 A3
- Best place to get a spare?
- OEM wheels size A3 2011 Quattro
- Does the 2017 RS3 grill fit a regular 2017 A3?
- VCDS Headlight switch settings
- (LINK BELOW) Is this speaker and stereo bundle better than my '06 A3 2.0T
- VCDS 15.7 for '08 3.2 quattro?
- ***Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - January 1st - 7th, 2017***
- Audi S3 8P looking for RS3 Front Grill
- Help with coding please
- Looking to buy Audi in IL?
- Anybody running 15" Winter Setup?
- How to upgrade 2010 Audi A3 Sound System
- S-line meaning
- Dashboard off issue
- New A3 key instead of lost one
- Oil leak
- Audi A3/S3
- 15%/20% off Holiday Sale - Free Shipping on all LEDs! Shop now and save!
- 2017 A3 - Android Auto/Google Maps Direction Issue - anyone else experiencing?
- Thank you AudiWorld! 1000 Clearmounts sold!
- !AUDI ONLINE PARTS WINTER RAFFLE!
- F20 fuse 2008 A3
- S3 2016 RECALL on side markers
- 2008 a3 for parts
- Audi A3 1999 1.8T - Starts when cold then dies when warm
- overhead button question
- WHAT DO YOU WANT TO SEE FROM A PARTS DEALER?
- Anyone has experience with Audi 1.4 TFSI engines?
- A3 Turbochargers
- Clearmounts for 8P now available!
- Open Hatch Light and Rear Wiper Problem - not the usual corrosion problem
- Manual gearbox oil change - only 0.5 ltr ???
- S3 8L Axel? Driveshaft?
- First Snow Trip
- Audi A3 07 8P wiper motor shot
- DSG fault code
- 2009 Audi A3 EPC Help
- side view mirror stolen
- A3 is wiggling while driving from side to side.
- Launch control bad for car (S3)? Warranty?
- 8P Quattro Questions
- Custom Cellphone Mount for Audi 8P - CM-Aluminum
- arrow button under trunk lid what does it do?
- Mufflers for 2007 A3 with good sound?
- Apple Car Play
- Front wipers not working.
- Emission dashboard light
- :: GruvenParts.com Performance Parts for Audi !
- Connected battery terminals wrong by accident
- Audi A3 07
- 2015 a3 prestige Quattro brakes failed
- My new Audi S3
- Will this part fit?
- 2007 Audi a3 2.0t
- Can I add Nav on my A3 2015 if it didn't come with it?
- 2015+ Audi A3 Sedan - 3rd brake light removal ????
- control module error
- 15000 miles service!
- 8L pcb under aerial connection
- Audi A3 coding issues
- Audi A3 Navigation issues
- SportShifters.com - SportShifter now available for your A3 (8P) manual!
- Deffective automatic headlight and wiper
- 2008 audi a3 2.0t hesitates to accelerate
- Seats Adjustor
- My new version of the CarL mount just arrived
- !NEW AUDIWORLD EXCLUSIVE PROMO!
- Radiator Fan stuck
- Need no-holes license plate bracket.
- Other Forums?
- Intake manifold removal V6
- Possible to change odometer?
- Rear window connections - Antenna ?
- Cellphone holder - Custom designed (8P) - Clearmounts
- New Battery change.
- S3 as daily driver?
- 2010 A3 multiple Bulb errors on startup
- :: ECS Tuning :: Timing Belt Kits + FREE Schwaben LED Pen Light! | 8P A3 2.0T
- Audi A3 A/C Issues
- Audi A3 LHD 2.0Tdi 16v (8P1)
- Audi A3 wont start on first crank but second is always fine - P3053 00 [039] short?
- 15% off all LEDs Customer Appreciation sale! Free Shipping & Lifetime Warranty!
- :: ECS Tuning :: Protect Your Pan! | ECS Stree Sheilds - $40 Off!
- A3 8p 2.0 bkd quattro missing check light
- A/C radiator fans not working
- Changed the car battery ...
- Audi a3 2005
- :: ECS Tuning :: Grille Up Some Savings | A3 ECS RS Style Mesh Grilles - 10% Off!
- 2008 A3, lots of mods 340HP!
- 2006 A3 Quattro clunk, motor mounts and loose feeling
- Can a 2013 A3 2.0t engine be swapped into a 2006 A3 with standard trans?
- :: ECS Tuning :: The One-Two Punch! ECS GEOMET® Rotors & Exact-Fit SS Brake Lines
- AUDI A3 2005 cd player/interior change
- BIRTHDAY SALE!
- esp
- :: ECS Tuning :: ON SALE!! FK & JOM Coilovers | 8P A3 2.0T
- 2011 A3 with clutch noise - HELP!
- :: ECS Tuning :: ECS Billet Aluminum Engine Oil Dipstick | Audi 8P A3 2.0T
- :: ECS Tuning :: Save 15% On ECS Wheel Essentials | 7/6- 7/14 Only!
- A3 e-tron: Space Saver Spare Tire?
- What model years are there for the Audi 8P?
- Headlight upgrade
- Center air vent diameter?
- Any one knowes this kit for A3?
- 2011 A3 2.0L TDI battery replacement
- Quattro version????
- iPhone charging only when popup-display is up in Audi A3
- 2011 A3 TDI high pressure fuel pump
- Mixed Ignition Coils, can i?
- Audi A3 trans oil mixed with coolant
- Inspection Due
- What to look for in a A3 3.2 sLine
- Can U identify Roof Rack Torque Wrench?
- No heat and a weird popping noise
- 2006 audi A3 AMP
- :: ECS Tuning:: FREE SHIPPING ends 6/28 MIDNIGHT
- Summer Start MEGASALE!
- :: ECS Tuning :: Billet Oil Filter Housing Hook-Up! | 8P A3 2.0T
- :: ECS Tuning :: Forge Motorsport Components | Audi 8P A3 2.0T
- Potential New Audi Owner. A3 model questions. #noob
- S3 2.0 TFSi strange whistle noise when accelerating (video)
- :: ECS Tuning :: Time Is Ticking!| Save Up To 15% On ECS Timing Belt Kits!
- Hi Guys , I'm back
- oil light comes on 2016 s3
- Help me decide please - Coming from '14 is250 - Ct200h f sport OR A3 E-Tron?
- Rear Turn Signal Issue - 8P A3
- Audi A3 DIS
- :: ECS Tuning :: #SaveThePans | 8P A3 ECS Street Shield
- Cam belt tensioner
- :: ECS Tuning :: FSI Cam Follower Awareness Sale!!
- Need torquing specification for clutch replacement
- Audi A3 2006 1.6 FSI Starter Motor Replacement
- Driver seat
- Please can someone locate my EGR valve?
- :: ECS Tuning :: ECS Jack Pad Adapter Kit | Audi 8P A3
- Brake Pads for Audi A3 1.8T Model 2014
- My picture
- Need Help Diagnosing Issue with my 2006 A3 2.0 T
- S Line or E Sport???
- :: ECS Tuning :: Memorial Day Sale | Up to 25% Off RS Style Grilles & Alzor Wheels!
- :: ECS Tuning:: Summer Prep Sale Event! | Up to 30% off your favorite brands!
- FREE SHIPPING through Memorial Day!
- 2007 A3 with trouble codes
- Headlights question
- How to avoid paying for MMi Connect Contract & Set Auxiliary Climate Controls
- Some help needed
- :: ECS Tuning :: P3Cars VIDI For Your Audi!
