PDA
View Full Version : Audi A3 / S3 / RS 3
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81
  1. Audi A3 1.6 TDI (2010) Idle/Stall problem
  2. High Gloss Black Dash
  3. Where can I locate front rotor size 2011 a3 tdi s-line
  4. DPF Regen: repeat or delete?
  5. Prospective Audi A3 FWD Purchase
  6. 2015 Audi A3 parking brake issue.
  7. 06 a3 vr6 misfire
  8. 06 A3 8p Trouble Shifting Into Gear
  9. Coasting mode on Audi S3 8Y
  10. Adding a subwoofer.
  11. A3 Dash cam
  12. A3 door wiring rubber boot
  13. A3 Heated seats
  14. Audi a3 bkd smoking under hood and oil pressure light coming on
  15. 2008 audi a3 ignition terminal 30 issue, intermittent no start. No crank
  16. Audi A3 8P not starting with EPC ligth on
  17. DSG Transmission Oil flush procedure
  18. Spacers
  19. Need Help Identifying Part - Seal on Door Bottom
  20. Radiator fan keeps running
  21. Error on Audi A3 1.6TDI (P0341 P2127 P0651)
  22. 2009 Audi A3 2.0 Diesel strange buzzing sound under bonnet st idle
  23. Audi a3 2.0 tdi 2014 long crank before start in the morning
  24. Confusing Parasitic Draw
  25. Seat back bottom clips
  26. A3 8P missfire Roughidle Epc light?
  27. 2015 Audi A3 repairs
  28. LT: Cupholder compatibility between A4 (8D) and A3 (8L)?
  29. Replacing Adjust Motor Actuator
  30. 2010 a3 not starting
  31. Audi A3 - 2017 Oil Sensor Malfunction (HELP PLS!!)
  32. RNJ Performance
  33. Help with codes please (P509A, P4D5B)
  34. Only one code and I dont know how to fix it (17272 )
  35. Audi A3 2009 2.0T oil leak issues
  36. Cuoholders
  37. Overheating
  38. Audi A3 8v hvac problem
  39. Rear Camera Only Turns On When Trunk is Open
  40. 2009 A3 S Line Engine Swap Thoughts
  41. 2012 S3 Installing front springs - Ball Joint & Drop Link question
  42. How can I keep my car’s Bluetooth on but my whole car off? Audi A3 2015
  43. Where can I source this S3 wheel?
  44. A3 8P. ESP/ABS Fault Headlight range finder defective
  45. Wheel question.
  46. 2001 Audi A3 1.8t 8L - Fuel Consumption
  47. UK: Audi A3 2017 - Engine start system malfunction
  48. UK: A3 1.4 white smoke
  49. Audi rs3 engine wiring diagram
  50. UK: Audi rs3 engine wiring diagram
  51. Throttle actuator not 100% on WOT
  52. UK: S3 Engine seizure - what to do?
  53. Cam belt change. When to do it?
  54. IT: Audi A3 8P dual clutch throttle delay
  55. 2015 Audi S3 Clunk Noise in front end
  56. Oil magically disappears and reappears
  57. Chasing down CEL codes on a 2007 A3 8P
  58. A3 2.0 TDI BKD Crank, No start
  59. 2019 a3 rear calipers
  60. Audi A3 Sport (2023) vs Audi Q2 Sport (2023) As the title says, which out of these
  61. A3 tdi fan
  62. Mysterious issues with 2006 A3. Is this limp mode?
  63. Audi A3 8V (stronic) - Weird rhythmic noise.
  64. Want to use Synthetic Gearbox oil instead of recommended Mineral Oil
  65. Temp getting high
  66. 2007 A3 8P ignition barrel, switch and lock
  67. Do you know why
  68. Right front turn signal not working
  69. Audi A3 keypad rubber replacement
  70. NZ: 2006 Audi A3
  71. Hot Weather = Higher auto shift points?
  72. The Audi A3 is better than the S3 (Hear Me Out)
  73. 2016 A3 Cabriolet roof latch clunking sound
  74. Audi A3 2006 automatic won't activate D drive
  75. Rain Sensor
  76. Fuse issue
  77. 2018 Audi A3 Pre-Sense Malfunctioning
  78. Spare Key/Key Fob lost-Deactivate?
  79. American message board members.....
  80. 8p a3 Running lean with CAI
  81. Suspension leg replacement (Audi A3 2013)
  82. A3 8P (WAUZZZ8P97A162598) G65 SENSOR CABLE MELTED
  83. Audi A3 8p 2.0t Cranks but doesn't start P0016 and p0327
  84. UK: Engine fans running loud on idle, help!
  85. UK: A3 radio - intermittent on & off
  86. UK: Audi A3 8V (2018)
  87. rearend hit and run
  88. S3 8P(1) Transmission identification code and viability
  89. S3 8P(1) Transmission identification code and viability
  90. 2003 A3 Coilover Trouble
  91. So many errors all at once.
  92. SCR options
  93. S3 8P Cluster not working
  94. Audi A3 Transmission issues? orrrr...
  95. How Program Command
  96. Cold cranking issue, Audi A3 1.6 TDI 2014
  97. 2008 audi a3 1.9 tdi hot start problem
  98. Audi A3 2015 Sline Steering Wheel Issue flashing button lights
  99. Audi A3 transmission issue
  100. RS3 Apr stage 1 Tune
  101. RS3 Apr stage 1 Tune
  102. Time to change timing etc belt Audi A3?
  103. Won't Start after Slipping on Brake During Start
  104. Greetings from SuperSprint Italy
  105. 8p audi a3 vibration
  106. 2017 A3 Quattro oil leak
  107. Replaced audi A3 2010 abs needs long coding
  108. stabilization control system(ESC) Problem
  109. UK: 8P 2.0TFSi quattro issue
  110. Audi A3 8P
  111. 2013 A3 2.0T FWD hvac issue
  112. Audi A3 8P ECM Relay? No Signal/Communication with ECM - Intermittent
  113. Clunking noise on front wheels when no weight on them
  114. WINDSCREEN REPLACMENT £620 WTF?
  115. Fusebox Wire
  116. A3 light bulb warning (bomb with X across it)
  117. Reset tire tpms sensor
  118. 2017 Audi S3 - Pulls Right After New Tires & Alignment
  119. Audi A3 8V Saloon Rear Window Regulator.
  120. 2.0T A3 - Car won't start unless I put in some throttle
  121. A3 fuel door won’t lock
  122. APR stage 1 with downpipe
  123. How to remove front license plate holder?
  124. Leaky 2007 Cabriolet
  125. Replacing key and cylinder - what do I need?
  126. OEM Battery for Only $108
  127. Bluetooth Issue
  128. Rs3 Drive Malfunction contact Dealer
  129. Does A3 come with Auto-hold?
  130. 2011 A3 Retrofit Backup camera?
  131. A3 wagon signal/marker lights in bumper?
  132. New to Audis, need help identifying (possibly missing) engine components please!
  133. A3 diesel conversion?
  134. Looking to upgrade A3 8P 2005 board computer
  135. *****A3 8p 6spd Manual Weird Noise Plz Help *****
  136. Cannot get timing aligned
  137. Random part with tape
  138. 2006 Audi a3 8p 3.2 looking for fuse box no.3
  139. 2007 A3 S-Line 6-speed MT Value?
  140. Audi A3 8P V70 Motor
  141. Wiring diagram showing various circuits
  142. Change coin tray to cupholder
  143. Suspension parts list
  144. Repairing Rear End/Suspension
  145. SAI Pump relay location? Error 17841 - Audi A3 2005 8p
  146. P227000 8VS3
  147. 1.8 bucks when on the throttle
  148. BA: Question about 2 buttons on board computer?
  149. 2015 A3 AC pressure sensor
  150. mess after replacing ECT and oil change HELP..
  151. Audi A3 2022 - 30tfsi Technik
  152. A3 8P 2012 Euro Front Licence Bracket Facelift?
  153. IL: Audi A3 - Very high oil consumption
  154. Audi a3 8p facelift
  155. 8P: Power Folding Mirrors via Remote Coding
  156. audi s3 8v knocking noise
  157. A3 Cabriolet window not dropping for door opening/closing
  158. Tailight animation without basic animation
  159. Help diagnosing oil leak
  160. Engine light, no throttle, idle at 1100rpm
  161. Cooling system/Heater Support Pump issues
  162. Parking sensor fail after wheel spin on ice
  163. Audi A3 P0322 crank shaft position sensor (05 plate)
  164. DPF obstructed on a dieselgate A3 TDI?
  165. ME: Audi A3 2020 HELP! HELP!
  166. 2016 Audi A3 sunroof not closing
  167. Where is the radiator drain valve on 2015 Audi A3 premium?
  168. A3 2010 cabriolet boot access
  169. 2020 Audi A3 Electrical Issue
  170. 8 CAM SHIFT ACTUATOR FAULTS
  171. 2011 Audi a3 2.0tfsi oil issues
  172. 2010 A3 front right ABS harness replacement - request for tips and tricks
  173. Cluster reference
  174. UK: A3 No revs, oil pressure and coil lights
  175. High fuel consumption Audi A3 8V 2.0 TDI QUATTRO
  176. Audi 8p 2007 S3 High idle
  177. Carbon ceramic discs REFURBISHMENT
  178. S3 xenon headligh to non S
  179. UK: Horroble MOT Failure?
  180. Check Engine Light on 22K car??
  181. Need help finding a replacement diffuser for a 2014 A3 S-Line Sportback.
  182. Interior alarm issue with disabling
  183. % OFFER - Carbon Ceramic Brake Discs
  184. Audi A3 8P 2006 1.9TDI knock noise
  185. NEED NEW SPARK PLUGS/COILS
  186. Misfires, Weird Idle (Please help)
  187. S3 8v Upper Radiator Hose, Coolant Shut Off Valve
  188. UK: Random overheating, temperature does down quickly to 90 deg
  189. A3 Rear Diffuser
  190. 2015 Audi A3 premium plus 1.8 window regulator replacement
  191. Horrible noise when switching from N to D
  192. 2014 A3 8V
  193. BNS 5.0 Navi - Help
  194. 2017 S3 suspension malfunction
  195. Need a radio tutorial...
  196. Aligning Rear Window after Regulator Replacement
  197. Loud Squealing noise after 40+ mins of driving
  198. 2006 A3 Rpm lag/stutter
  199. Interior Blower intermitent fault even with new motor and controller.
  200. UK: Misfire and start stop A3
  201. Not sure what this part is! I need help ASAP!
  202. A3 mpg
  203. Audi A3 8P 2.0T EA888 Timing Chain Failure
  204. A3 key fob replacement and reprogramming
  205. GR: A38p1 2.0Tfsi quattro
  206. UK: A3 BONNET WONT OPEN
  207. NZ: 2006 A3 S-Line 2.0 (83K on the clock)
  208. bump/jerk when giving gas
  209. Clogged center console & feet air vents
  210. Parking Lights won't turn off after ignition off and key out
  211. A3 8V ambient lighting retrofit
  212. 2016 A3 backup camera
  213. Audi A3 8P 2.0 TFSI (CCZA) underboost
  214. Mag ride calibration
  215. UK: S-line 2011 2.0 TDI now on 96k mileage?
  216. UK: VCDS MAF, EGR & FUEL Temp Issues - AUDI A3 BMN 170 07'
  217. 2018 Audi A3 Rear Quarter Panel Trim Removal
  218. Name of a missing part?
  219. 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
  220. Looking at 06 A3 - need help
  221. Audi A3 8P Passenger door lock
  222. 2005 (Facelift) Audi A3 1.9TDI reverse lights not working
  223. ZA: Front Tow Cover replacement Rs3-S3 bumper
  224. A3 8P can’t switch to Sport Mode
  225. Audi A3 Car enthusiast needs HELP!!!
  226. 2015 A3 Premium Wirring type noise while ac on
  227. Audi A3 Front Bumper License Plate
  228. 2015 A3 questions
  229. IT: belts beep sounds with belt inserted
  230. Media settings keep being reset
  231. Not able to open rear door (from inside or outside) of Audi A3 Sportback
  232. 2009 A3 Door blade trim
  233. 2006 A3 - wiper no power
  234. Audi A3, steer clear?
  235. VCDS Adaptive, DPF Replacement
  236. Dual coolant temperature sensors?
  237. 2012 A3 Quattro Hesitation
  238. How to Use Launch Control in the 2022 Audi RS3
  239. Enable RS Screens on Virtual Cockpit | 2022 Audi RS3
  240. Detailed look at the interior of the 2022 Audi RS3
  241. Android Auto Random Disconnect
  242. Rebuild Suggestions
  243. ReDisc - Carbon Ceramic brake disc refurbishment & repair
  244. Audi A3 2017 pre sense fault
  245. 2016 A3 Back-up Camera not working
  246. 2010 TFSI A3 Help Identifying Leak/Seal From Top of Engine
  247. A3 bulb warning light
  248. Audi a3 1.6 2001 radiator problem fan
  249. A3 2.0 tfsi in limp mode.
  250. Where does this part go?
