PDA
View Full Version : Audi A3 / S3 / RS 3
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81
  1. Audi A3 USB Connectivity Issues
  2. Power window motor.
  3. Audi S3 Cabriolet S-line Bluetooth problem
  4. Spark plugs
  5. Part number for coolant hose
  6. LT: Audi A3 2005 Hole in rear bumper
  7. Strange Start between 50 and 90 C (especially at 70)
  8. Reverse Lights & Internal Audio Dead
  9. A3 Bucking P0321 after water pump replacement
  10. EGR Fault
  11. 2023 Audi S3 Prestige - too good to be true?
  12. Audi A3 8P 1.9TDI 105 Heating problem
  13. Hardwiring a multimedia (charging)
  14. Side mirror unfolded 40 degrees more than normal
  15. Cam wear fuel pump
  16. USB Not readable
  17. 2013 Audi A3 Coolant Leak
  18. One Fan On after Engine Off
  19. Hardwiring a Android Multimedia Device (Carplay)
  20. DSG launch control?
  21. Power cutting out under heavy load
  22. Audi A3 8V 2014 Sedan Xenon To Full LED Headlight DIY RETROFIT (Non US) (RHD) (CXSA 1
  23. No Order Until Allocation Slot for 2025 S3
  24. BR: A Brazilian A3 8L
  25. Need help with Junsun Media Centre
  26. Vacuum Hose diagram
  27. 2006 a3 quattro keyfob fcid
  28. AUDI A3 2013
  29. Audi a3 1.6 petrol bse
  30. Grease on Wheel and Squeaking Noise
  31. Audi A3 8V Auto Headlights Retrofit
  32. BEARINGS AUDI RS3 2.5 5 CIL.
  33. 2017 Audi A3 Performance issues/limp mode? - Need help
  34. UK: Replace Fuel injectors?
  35. Oil mixing 2018 A3 2.0TFSI QUATRO
  36. EVAP recall service issue
  37. UK: Audi A3 21 plate subwoofer defect
  38. 2004 A3 3.2 dsg vibration on acceleration.
  39. 2015 Audi A3 Catalytic Converter Leak
  40. 2006 A3 drivetrain shudder
  41. Turbo lag in S3?
  42. SE: No idea what is happening with my A3
  43. Drive System: Fault 4000RPM Limit
  44. Dumb question about the headlamps
  45. 2008 A3 S-Line 2.0 not running
  46. 07 A3 timing check and cam chain/tensioner replace-few issues
  47. Does anybody know where this fits on my passenger seat
  48. Service Action Code:34L4
  49. Am I leaking engine oil?
  50. New Audi A3
  51. A3 on/off rear camera issue revisit
  52. Vehicle eletronics: fault. Error codes: B1263 and B140A
  53. OBD11 vs Carly vs Carista
  54. Buttons in boot (Trunk)
  55. Ultra inexpensive fix to the Broken clip-latch rear sunshade
  56. Haldex ECU Repair
  57. Can’t rev while coasting in neutral
  58. Changing all the suspension on an Audi A3 Quattro 2010
  59. Too lean at idle fault code 008583
  60. 2025 S3 configurator (US)
  61. BA: Audi A3 1.6 BSE Throttle Body Issues
  62. Resistance vs Temperature chart/table
  63. Which fuel pump fits?
  64. Audi S3 8Y 2023 - Uneven Tire Thread
  65. Audi A3 2.0 FSI (8P) - wiring problem
  66. Help retrofit B8 S5 seats in 2007 s line?
  67. Suspension noise and visual fault?
  68. 2021 A3 NAV problen
  69. 2007 A3 8P A/C issue
  70. UK: Cruise control
  71. Navigation update
  72. S3 8P 2007 Won’t Crank/Start
  73. Audi DSG/S Tronic issues, mechatronic or fluid?
  74. Audi A3 2018 Quattro Premium - New tires question
  75. 2012 A3 8P with Check Break Pad / TPMS light on
  76. Audi Connect Issues / Outage
  77. Audi A3 8P 1.8TFSI P0221 issue
  78. 2007 A3 S-Line 3.2, love my unicorn
  79. AUDI A3 STANDARD CLUSTER CODING
  80. Speedometer sensor location Audi a3 8L
  81. A3 8P 2007 EA113 high pressure pump error
  82. Engine revving while in idle or breaking
  83. Active grille shutter stuck on
  84. Mod Suggestions 2009 quattro 2.0tfsi
  85. Survey of A3 Drivers
  86. Audi A3 8P CarPlay with Sub support
  87. Engine Died Thursday - US Driver
  88. Audi A3 8V Removing Door Panel and armrest-handle..
  89. 2018 RS3 - "Fixing" the B&O Sound System
  90. ESP Light G-201
  91. MID PIPE HELP
  92. 2020 Audi A3 S- Sport mode rough downshifts
  93. 8V Needing Mystery Tune Removed
  94. TCM location?
  95. Audi s3 Diffuser Fitment HELP
  96. Taillight cluster question
  97. New Family Member!
  98. Wiper fluid blocked
  99. 2008 audi a3 crank but no start
  100. Audi A3 8V 2017 Saloon reverse camera
  101. Is it ok to use these spark plugs and coils with stage 1 tune?
  102. Unknown engine component
  103. A3 2012 8P - Replacing OEM headlights with AM
  104. Has anyone resolved the Geiger Counter dash noise?
  105. Audi A3 2015 - Update failed
  106. Epc light and now oil leak?
  107. A3 8P 2012 - Disable AFS without DRL
  108. A3 indicator fault
  109. 2012 A3, AC blows weak, blows HOT in high temps
  110. 2015 Audi A3 Overheating / Thermostat / Sensors???
  111. Audi A3 8v 2013 Panoramic Sunroof leaking
  112. Audi A3 8V 2014 Grommet Location
  113. Wireless Carplay Retrofit kit for Audi A3 / S3 / RS3
  114. A3 8PA Sportback Stereo Unit Upgrade
  115. SI: Audi A3 2013 Quattro - Can quattro be eliminated?
  116. Audi A3 2011 random injector circuit errors and limp-mode
  117. A3 2015 P2711 Code
  118. Strange noise that is consistant but dont know where its form
  119. Diagrams sought
  120. what goes here?
  121. Sport Suspension or Not
  122. 2015 S3 MMI removal tool
  123. P2435 error code
  124. Audi A3 8Y Key Malfunctioned
  125. Speedometer problem Audi a3 8L
  126. Speedometer problem Audi a3 8L
  127. OBD reader 2007 A3 - experienced advice please
  128. Audi a3 8v powerfold mirror coding
  129. Honeycomb Fog Light Grills
  130. RS3 rear noise... gone when taking out fuse
  131. 2006 Audi A3 2.0t FWD Hose question
  132. A3 '06 8P Fuse F10?
  133. Advice on A3 1.8T engine rebuild/ replacement
  134. Cluster display issue - unable to start car
  135. PRNDS flashing gearshift codes
  136. Transmission Fluid Pump Module 'A Location
  137. Turbo issue but no limp mode?
  138. 2009 a3 engine bay loom diagram
  139. 2007 A3 8P Codes P0243, P0444, and P0033.
  140. A3 2018 ECU issues after Recall service done.
  141. Ecu swap audi a3 8p
  142. 2017 Audi A3 | top portion of head light went out | see photos.
  143. Bluetooth connectivity with Samsung
  144. Audi A3 1.6 8P key turns to on but no reaction at all
  145. OBD code reader
  146. Hit a Pole in my Audi a3 2021 saloon. Will private garage void my warranty
  147. S3 scratch/restoration work
  148. Knocking noise from my engine, white smoke and coolant smoking.
  149. Install wireless Apple Carplay
  150. Hissing sound & loss of power
  151. 8Y RS3: What is this knocking sound by engine?
  152. Used RS3’s
  153. 20% off our bright D1S / D2S / D3S LEDs! These are brighter than xenon bulbs!
  154. Audi A3 2010 1.4L gear out of control
  155. 2012 Audi A3 2.0t EA888 Timing Chain
  156. Rough stuttering cold start on 2012 Audi A3 8P 2.0tfsi
  157. Audi a3 1.4 tfsi 2008 Power loss on 4th and 6th gear
  158. FI: 2014 A3 1.4 tfsi, can't connect to ecu after changing turbo
  159. Location of TCM / Car wont crank
  160. 8Y 034Motorsport Dynamic+ on locked TCU opinion request
  161. 2015 Audi A3 Misfiring under heavy throttle Any thoughts
  162. A3 engine in s3?
  163. ESP activation, clicking noise, vibrations - investigation
  164. Audi A3 8L part
  165. When I press the gas pedal I hear a ticking noise
  166. 2.0 TFSI timing belt guide help
  167. UK: Multiple issues with A3 Quattro
  168. Intake flap
  169. COMM #
  170. Does anyone have a clue what this noise is? A3 8P 2.0 TDI
  171. How’s the backseat space in the 3/rs3 for kids?
  172. Front Camera location
  173. 2013 Audi A3Q (2.0) ISO part info to replace only leaking flex section in downpipe.
  174. 2015 A3 Quattro 6 speed auto DSG
  175. Electro- mechanical parking break
  176. Drivetrain Malfunction leading to check engine light
  177. EPC light came on (2016 Audi A3)
  178. Upper timing cover bolt won’t tighten to collar
  179. What is the hot part?
  180. 2018 A3 Headlight issue
  181. What is this 1.8T hose?
  182. 2015 Audi A3 Power Seats (SimRacing)
  183. Is there an alternator fuse on a 2016 Audi A3?
  184. 2001 Audi A3 8L A/C Pressure sensor location
  185. A3 8l ICM wiring diagram
  186. 2011 A3 2.0 TDI blowing black smoke
  187. "Tyre Pressure Cannot be stored at this time"? help!
  188. Is the USB fast charger PD100W+QC3.0 compatible with a 2017 Audi A3 cigarette port?
  189. anyway to fix center brake light? my A3 Quattro still runs good..
  190. Water ingress boot hinges ?
  191. Where can i find a light part for a Audi A3 E-Tron 2017
  192. Audi a3, mmi unit does not come out
  193. 2016 A3 Interior Handle Replacement.
  194. Audi Grille Question
  195. Transmission issue? Car won’t move in drive or reverse
  196. Audi A3 2020, doors compatibility
  197. ‘20 audi a3 Electronic Parking Brake not disengaging
  198. Removing Rear passenger side trims
  199. 2016 Audi A3 Quattro 8V Fuel Issue
  200. Flashing gear indicator
  201. Changing Steering wheel
  202. Install Cams and Time
  203. Wipers rest position.
  204. 2020 Audi A3 Oil level system malfunction! Please contact service
  205. No lights working on the boot it self.
  206. Armaspeed Luminous Paddle Shifters
  207. metal clip audi a3 2018 s-line
  208. B7 S4 Recaro to 8p A3 S-Line Retrofit
  209. ENGINE WON'T START - A3 2.0TDI quattro 140hp
  210. Part number problem
  211. Front registration plate stuck
  212. 2009 Audi A3 8P - Parts Car - $1,500 OBO
  213. Side(left) mirror is not heating
  214. A3 gas mileage
  215. Christmas Holiday Sale
  216. 06 A3 2.0T FSI (8P) ECM Power Relay Fuse Location??
  217. Audi a3 Quattro 8P tunning advise
  218. Mirror Phone/Video to MMI?
  219. Fuel System Issue (p0089)
  220. Car won’t move in neutral
  221. Weird heating problem??
  222. Connector in Glovebox in Audi A3 2015 1.4 TFSI Saloon
  223. Rs3 matrix water flow issuise help
  224. 2010 A3 Error Codes 7E8 and 7E9
  225. Audi a3 2002 1.8t aum engine
  226. 2021 Audi a3 steering juddering when turning at low speeds
  227. Audi A3 8V showing P0475, P0477 and P0477 HELP
  228. 2015 A3 Right side light/daytime running light
  229. getAudiparts.com | Black Friday/Cyber Monday '23 Savings are Live!!!
  230. BLACK FRIDAY SALE,, SuperSprint Italy
  231. Crank End Bolt and Sprocket (that timing belt goes around)
  232. 1057803 antenna for keyless entry system in trunk open circuit fault audi a3
  233. 2.0t Fsi boost gurus
  234. 2012 Audi A3, TDI, Immobilizer issue
  235. 2013 A3 footwell lifghts?
  236. UK: We’re do I post for a rs q3 8u technical?
  237. Help Pls: Fault codes P2279, P0507, P2187
  238. License plate light screws
  239. Bought a 06 A3 2.0T front wheel drive from police auction
  240. Install New Oil Pump Chain
  241. 2009 audi A3 2.0 tfsi
  242. OBD2 readiness for NMHC catalyst on a TDI
  243. 2009 Audi A3 cranks but no start
  244. ***CALLING ALL MK5 GTI / A3 GURUS***
  245. G235 location on CJAA
  246. A3 door sensor removal
  247. UK: Audi A3 1.6 tdi 2016
  248. Replacing Oil Pump
  249. Audi A3 2009 8P drivers door and rear right passenger door not opening with fob
  250. How to know if the transmission is DSG?
