PDA
View Full Version : Audi e-tron / Q8 e-tron
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15
  1. When did US deliveries of Q8 begin?
  2. Outrageous Service Cost - Almost $700.00?
  3. Charging continues past limit
  4. Thoughts on random no lock/unlock via drivers handle
  5. Suspension suddenly not moving with drive select
  6. Charging fails to stop at limit
  7. Charging fails to stop at limit
  8. 2024 Phone Box Serial Number
  9. Engine Start System: Malfunction!
  10. Have you seen your front e-motor?
  11. $1720 for 20k inspection
  12. New owner of used e-tron intro
  13. e tron Quattro vs Q8 battery sensitivity to temperature
  14. MyAudi app (news)
  15. Rumor of Audi Extending Warranty for Front Motor Failure Due to Coolant Leak
  16. Utilizing towing connector
  17. Wet rear passenger side foot well
  18. Offset and width with 20" aftermarket wheels?
  19. PSA: Source of OEM wheels. Alignment question.
  20. Roof Bars/Box options
  21. Rear motor replacement due to leaking
  22. Range Question
  23. DK: Daylight?
  24. New 2024 e-tron - "Audi connect services are not connected"?
  25. Online map update is stuck
  26. android auto with iphone?
  27. 200% Battery Usage all of a sudden
  28. What is this - location services?
  29. 37500 mile update + MOT (UK) + Q4 thoughts + Spend so far
  30. Audi Vs Elon Musk Vs Twitter
  31. Is there a part where I can order the wiring harness?
  32. 90 days until lease end on 21 eTron Sportback
  33. Range Poll for Recall 93U9 Victims
  34. Exit Malfunction Light
  35. Our MMI software is so weird
  36. SQ8 e-tron after 3 months
  37. help!!
  38. MMX Wheels 1P 2P 3P & 4P Forged Aluminum Wheels Master Distributor Wheel Designers
  39. Modified Sunroof Extended Warranty?
  40. New Audi - charging system failure and other gripes
  41. Help me choose brake caliper colours!
  42. Wow! NACS adapter to be shipped by VW?
  43. Charge at 1/2 rate at home?
  44. Must dos with your new e-tron?
  45. Audi e-tron front license plate bracket/holder
  46. Loud fan/air behind dash
  47. Blinkers are not blinking steadily
  48. Anyone lowered their e-tron with MTM lowering links?
  49. NACS to CCS adapter
  50. Where to shop for used e-tron?
  51. Charging cover
  52. Macan versus Q8 e-tron
  53. Scheduled charging finishing early recently
  54. How much off MSRP are we getting these days?
  55. Do you get these "Wrong Way Driving" Warnings from the Nav?
  56. Cracking/Clicking noise from tires on wet roads?
  57. Audi USA Customer Service Email?
  58. Failed seal causing motor leak e-tron 2020 24k miles
  59. Black Optic with 20” wheels for 2024?
  60. Key not detected while driving
  61. Rear Tow Cap Replacement
  62. “Brake Booster Deactivated” on 2019 e-tron
  63. No GPS, SOS functionality or connection to Audi Connect servers
  64. e-tron 2021 maneuvering assistant
  65. Audi Q2 e-tron issue
  66. After Market Running Boards?
  67. Code 2884 on 16 A3 etron
  68. Second key buttons programming?
  69. e-tron battery '21 vs '24
  70. Dashboard factory warranty extension
  71. 55 Quattro badge
  72. additional LED lighting set up/connections
  73. Charging port release
  74. Bye Bye e-tron (again)
  75. Cannot set nor see “Target charge” in app
  76. "Adaptive Cruise Control Unavailable" issue- intermittent
  77. Matrix-Design (P+) vs Digital Matrix-Design (Prestige) headilights - differernce?
  78. Q8 e-tron TIRE UPGRADE (options)
  79. Resale/Trade Value 2019 Prestige?
  80. Audi Pure Protection Warranty coverage change
  81. New Features in MMI
  82. "Locking error in charging system," car will not charge when plug inserted
  83. Camping and power
  84. Auto Parking Brake at Park
  85. Rear Climate Control making noise
  86. Matrix LED Headlight Activation Information...
  87. Windshield Wiper Fluid vs headlight washer
  88. E-tron drivers who use Plug and Charge do you get Pass+ rates
  89. My ambient lighting journey on a 2024 Q8 e-tron Premuim Plus
  90. 2023 Etron Sportsback FUSE BOX
  91. 2023 Etron Sportsback FUSE BOX
  92. Real world range test, ‘21 vs ‘24
  93. Q8 Badge Location
  94. Right door buzz/vibrate
  95. UK: Catastrophic Brake failure on motorway, 2020 e-tron
  96. VCDS code change for REGEN
  97. CPO reinspection timeframe for cars that don't sell quickly?
  98. Fault Code
  99. Traffic Light Info
  100. Bad experience with Audi On Demand over the holidays. Avoid.
  101. e-tron Speaker Sizes | Looking to upgrade
  102. Recommendation. Get a service loaner when bringing e-tron in for service
  103. Nav easter egg
  104. Bumper Paint Code
  105. FI: e-tron DIY Direct/Active TPMS Retrofit?
  106. Snow chains (or similar) recommendation for Etron
  107. Etron Car Scanner app used for Coding
  108. Seeking recommendations for OBD data analysis for 2022 eTron Quattro in US
  109. Software update for increased range 2019 Etron models? Dealer not aware of this.
  110. Battery Degradation Data Points
  111. Service said, "Buy the Q6"
  112. Electrify America Problem Connecting to Q8 e-tron
  113. What is this icon?
  114. Low “purring” sound
  115. MMI Problems
  116. Ceramic brake pads ok?
  117. Are PenFed Audi incentives available at all times? Not showing up in January
  118. Noises when the car is off
  119. Q8 e-tron Fob not lowering windows
  120. Best drive mode for snow/ ice?
  121. New Car time - Please help
  122. Battery range vs percentage
  123. Car Play vs “Phone” function
  124. Purchase reccomendations please.
  125. Audi Connected Key question
  126. myAudi App home screen question
  127. 2024 Q8 PoS MyAudi App
  128. Usb c rear retrofit
  129. Well. I’m back. Finally. 2024 Q8 Sportback
  130. Anyone have their steering wheel lockup?
  131. Audi loyalty incentive eligibility based on social media activity?
  132. Audi Connect Mistake Email
  133. Recall: High-Voltage Battery Module(s) 93U9/23V867
  134. Climate control turns on after parking
  135. PSA: Audi Connect PLUS for $250 per year
  136. Does 93M3 extra range update show on Audi recall website?
  137. Would like some feedback on Q8 e-tron P+ lease offer (involves early lease return)
  138. Changing charging target in the app for early 2019 E-trons
  139. Charging Cable Recall 93U6/23V842
  140. New e-tron break-in procedure
  141. VAG announces switch to NACS in 2025
  142. 2024 Audi e-Tron range diminshed to 217 from 277 miles
  143. Carbon Fiber Mirror Caps
  144. Removing the rear diffuser - anyone know how?
  145. Could not execute charge. Charging system locking error
  146. 2024 Q8 E Tron Control Module Failure
  147. FM HD Radio Signal
  148. New Audi App Store
  149. Car Play/Radio behavior
  150. Tire pressure warning
  151. when to charge my Q8 etron in the winter
  152. Upgraded to a '22 e-tron S!
  153. Is the low efficiency of Q8 e-tron anything to be bothered about?
  154. Audi Connect Prime and Audi Software Services
  155. 2022 Audi eTron sunroof leak
  156. Lease vs Finance
  157. 2020/2021 e-tron Sportback Prestige
  158. [US] Matrix headlight activation
  159. Regenerative Braking System
  160. Vandalized e-tron
  161. Femtocell For Vehicle Connection at Home
  162. Owners with 100k miles
  163. No Lug Cap Puller, No Problem!
  164. Contacts for Extended Warranty Purchase
  165. New Q8 e-tron coming soon.....dilemma
  166. 24 Q8 Etron SOS red light error
  167. New Subscription options on Q8 etron
  168. Latest Consumer Reports data reveals poor EV reliability
  169. Goodbye trusty ‘19; you’ll be missed
  170. ChargePoint Charger Setup Question
  171. Illuminated controls
  172. Dumb Key Fob Question
  173. No Boost on Q8 over 80mph?
  174. Does anyone have a Navigation update file?
  175. Mostly useless cupholders in 2024 Q8 e-tron prestige launch. A
  176. Help—e-tron won’t release L2 charger
  177. Getting 2021 etron versus 2023
  178. MyAudi down again?
  179. myAudi Down Again?! Must've taken a crap on itself..
  180. Virtual cockpit difference
  181. To charge with timer, or without.
  182. e-tron and AudiCare
  183. 22/23 E-tron S range still 208?
  184. P2884 Malfunction - New Transmission Required?
  185. new Audi EV (Q6 and A6 e-tron) models will be delayed
  186. Virtual Cockpit keeps going back to Date/Time screen
  187. Audi Navigation Question
  188. Etron charging change
  189. Charge Point Issue
  190. Home Charging Question
  191. Do you remember the old "software update days"?
  192. Is AM frequency band not available in 2021 e-tron?
  193. EA Credit ?
  194. Drive select mode for snow & ice?
  195. 2021 e-tron - indirect ABS senosrs or in tire TPMS sensors?
  196. Lowering or raising 24' e-tron?
  197. What's your favorite view for the various screens?
  198. 2019 e-tron and Lidar
  199. Doug DeMuro review of the 2024 Q8 e-tron Sportback Prestige
  200. Touch up paint for black paint on wheels
  201. e-tron/EV Personalized Plates in the Wild
  202. Which third-parties do you trust for e-tron tire installation in Southern California?
  203. BMW iX?
  204. Recommendation of California/OC dealership /salesperson
  205. PY: OEM AUDIO SOUND AMPLIFIER Cuality
  206. Traffic light info not working: 2022 P+
  207. Interesting conversation with my Audi Tech
  208. Auto lock?
  209. MyAudi app connectivity with vehicle issues
  210. Home Charging Question
  211. UK: No stainless steel footrest on RHD models?
  212. 12 Volt Battery ?
  213. Passenger Side Noise- At Wits End
  214. 4 year report
  215. 2024 Q8 eTron Consumption Screen
  216. Virtual cockpit - no options to change between classic, sport and etron
  217. How to Create "Vehicle" Favorites?
  218. Regenerative Braking System
  219. Newbie here...
  220. 'Audi Phone Box delete' question for '22 owners
  221. Apple CarPlay and Android Auto - on startup they disconnect other audio
  222. New Owner - A Few Questions
  223. HV Battery Health check ?
  224. e-tron Unlimited Off Road
  225. Screen protectors
  226. 2024 Q8 eTron suddenly brakes on highway from incorrect speed limit
  227. Proximity/US sensors ghost alerting
  228. Battery Failure
  229. Remote Climate Control features not working
  230. Plug and Charge Feature
  231. Major warranty work at first service - pressure temperature sensors
  232. What model year E-tron do I have? Discrepancies between CarFax and window sticker.
  233. Only 90kW Charging on Electrify America 350kW Station
  234. Maintenance/Warranty Question
  235. NMC or LiPO4 batteries?
  236. Chargepoint home charger question
  237. Current Audi Care price?
  238. Porsche Macan EV test drives week of Oct 9
  239. 12V Battery Replacement
  240. Front License Plate holder
  241. Anyone tried to negotiate their lease payoff?
  242. Is the keyfob shell / casing removable?
  243. Q8 e-tron as flagship EV after Q6 e-tron arrives next year
  244. Scheduled charging?
  245. UTR 2.0 in US
  246. rear passenger door not unlocking
  247. Charging to 100%, 20 min later vehicle reports 98% battery
  248. MMI Themes
  249. 80K miles and my local Audi Dealer gave me an offer on my car
  250. Lousy EA chargers at new location!
