PDA
View Full Version : 1.8T Discussion
Pages : 1 2 3 4 5 6 7 8 [9]
  1. what manifold to buy for the gt28rs on a B5 dbw?
  2. Clutch for big turbo
  3. Problem with new BOV
  4. n249 and DV
  5. Noise in 1.8/Tip.
  6. what do you think of these codes? (apr)
  7. my fan wont work
  8. Mihnea Custom Tuning in Colorado -- Last Chance
  9. need help finding boost leak
  10. GIAC KO4 results for my 2004 A4 1.8T. Link to my post.
  11. am i the only one waiting for the ATP "Eliminator" for the b5 to come out
  12. 5th Annual Audi Expo! - It's coming!!!
  13. exhuast
  14. Turbo help and VAG log questions.
  15. VAG LOG help please
  16. NEW 2005 PRICING!!
  17. DTC help please......
  18. Vertical Doors/Lamborgini Doors
  19. boost on standard a4 quattro tsport
  20. problem with apr stage 2+ on my 04 b6..please read
  21. cylinder head questons expert advise needed
  22. Anyone selling or know of someone an APR manifold. If so post here or e-mail me. I'm looking to buy.
  23. How much octane do I need?
  24. Buyer's guide for 1.8T?
  25. suggestions needed!!!!!!!!!
  26. 93 programming on 91 fuel at altitude on a 1.8T.....
  27. boost gauge boost controller....
  28. Turbo from audi TT, to audi a4 engine??
  29. Has anyone had luck with underdriving the water pump?
  30. Who sells ferera exhause valves 1 mm oversized not in sets, i just need 2
  31. where do you guys pickup engine hoists or do you rent them for your engine removal projects?
  32. Oil Question
  33. General Questions about the 1.8T engines (preferably late versions)
  34. (x-post from Perf. frm) injector Q
  35. X-post from B5 board....anyone familiar w/ ABD Racing?
  36. MMMM...Donuts!
  37. Floyd Bennet field GTG
  38. Tranny Question
  39. Looking at a K04 From a 225 TT with no wastegate actuator
  40. cam install on 01 a4 1.8t
  41. Looking for a used 1.8 turbo head. AEB Code
  42. Oil feed line Q (x-post from B5 forum)
  43. engine removal question
  44. Hmm,..... early A4 1.8T intakes(150hp) should work on a MKIV VW,...... right? (WTB) if so!
  45. Yippers what say you....
  46. K04 - any tuner is this country have one? Thanks
  47. Recognize this part?
  48. Long shot but figured I woudl ask does anyone have a hi flow cat for sale
  49. Who here has a Stage 3 setup or more w/ high mileage on the engine? I have 163k on my '97
  50. Questions about GT28 RS kit
  51. Stupid Q: APR STG3 nDBW-what size injectors come with this kit?
  52. 1.8T low oil pressure, if oil have >100° C [ 212° F ] under 2000 RPM
  53. 28RS in a 28R package...has ATP gotten it right??
  54. Perf+Tuning X-post...water/alcohol injection...w/o a pump...
  55. Ok Guys the million dollar question for me...
  56. So I'm going to say good by to my throttle cut problems.....
  57. Will these injectors fit in my manifold w/out having to mod the mani??
  58. if i can smell crankcase vapors after a drive in boost, what could be wrong?
  59. looking for easy Performance upgrades
  60. Turbo squealing (long)
  61. Startup Vid with new 034efi...
  62. do they make a bigger alternator for the 1.8T...my alternator is not keeping up with...
  63. Hey..smart ones...look at my post from perf+ tuning if u can.
  64. *UPDATE* Squeaking
  65. Building a head AEB oversized valves ect.. what's the good stuff
  66. chip and k04 question.
  67. EFK & Higher Oil Temps....
  68. engine code translation?
  69. Thick white smoke from the exhaust pipe
  70. Would anyone happen to have a photo of a 1.8T camshaft sprocket -- OFF the car>>
  71. how many people have the samco hose kit?
  72. Surging during part throttle acceleration....HELP!!
  73. Paging Audi2ptzero...(repost from the main forum)
  74. 2001 A4 1.8T / Punctured Oil Pan / Engine trouble
  75. OH boy 3 problems 99 a4 1.8t aeb (ndbw)
  76. Anyone have a central lock pump wiring diagram for an A4? Yippers?
  77. How would one, change the map of pedal travel to acceleration?
  78. Qns on K04 upgrade
  79. Can you help! Passat Wagon Question about brake failure?
  80. What is the max rpm the stock head will take before foaming or valve float?
  81. 1.8 longevity- How many miles without problems?? (posted same on 2.7...)
  82. new handle
  83. thoughts, suggestions
  84. 1.8t Engine Problems--Loss of Oil Pressure
  85. 98 A4 Quattro 1.8l Thermostat
  86. does anyone know where can i get Lemmiwink software?
  87. 1.8T gurus out there....perf+tuning x-post
  88. Help me wierd problem with car starting
  89. I wanna hear of the most potent combos people have found NO KITS
  90. N75 valve hose routing...Help!
  91. New hardware is in :)
  92. APR pinging issue when transitioning from vacuum to boost under load
  93. PES turbo upgrade questions
  94. $500...
  95. significant egine chatter @ startup?
  96. HELP! Misfire from unknown source.
  97. Differences between GIAC PC_16 and PDK16 K04 programs?
  98. hey guys, my friend just bought an '03 1.8t VW Golf Gti. Do you know what kind of DV comes on that
  99. question about turbos and exhaust manifolds
  100. cheapest place to find 225hp tt injectors
  101. anyone know the 12 digit number on the dahlback custom..
  102. Achtuning holiday special Free Shipping* on any item** until Friday 12-17
  103. what is a good turbo timer to get?
  104. any one running: ported stock manifold with ko4?
  105. 180 TT quattro knock sensor question, searched, posted on TT and perf+tuning forum, no help....
  106. Inline 5cyl to 1.8L turbo
  107. New Toys are here. Time for some fun...
  108. Ignition advance people who know....
  109. Streetwerke is now open for business.
  110. these dev forums are pathetic...
  111. Service and Insurance
  112. Fuel efficiency
  113. On a 99 a4 1.8t with throttle cable (not drive by wire). I am having problems with the throttle.....
  114. here we go PERF+TUNING x-post TJM got back to me turbo option?
  115. Sweet mercy, how would this spool on a 1.8T?
  116. Southbend Clutch Group Buy is ACTIVE!
  117. 2.0 conversion
  118. Calling all APR stage 3 and stage 3+ 108ttq's
  119. T-belt breaking was actually cause by intermediate shaft seazing
  120. clutch upgrades for 1.8T + big turbo
  121. APR Stage 3 on a 2005 Audi A4??
  122. Will Our MAFs work as a Blow Through After Turbo?
  123. DTCs 17965 & 17705... what's easiest way to check for leaks?
  124. Oil Sludge
  125. who has this manifold?
  126. Anyone using Mobile Tuner to increase boost?
  127. question
  128. TT225Q whats the best down pipe back exhaust?
  129. Post write up on my custom stock air intake mod
  130. searched....found a few things but not much....ATP who has it? the GT28RS hardware only kit.......
  131. Anybody have torque diagrams for a completely stock 01 1.8t w/ k03 and 93 octane fuel?
  132. I have an A4 1.8T...
  133. Need diameter for 1.8T MAF for 98 A4 nDBW.
  134. Does anyone know anything about the extended warrenty VW/Audi is offering 1.8Ts?
  135. sweeeet. i'm a lil late but i found this place!
  136. Mobil 1 (M1-204) Oil Filter Warning - All Audi applications for this filter have been revoked per
  137. so it has to be asked. WHAT IS THE BEST CHIP?!!!!
  138. which intake is best, which chip is best, which BOV is best, and which spinners are best? TIA
  139. are the stock k03s from the b5 s4 any diff in the a4? b5/b6 1.8t?
  140. why is the header a VW 1.8t badge?
  141. Poll: when will the number of posts here exceed the number in the 12v development forum?
  142. I have a 2001.5 1.8T with FrontTrak.
  143. What the hell is this place??? Development forum??
  144. DO NOT USE VW MAF
  145. Nice little place.
  146. Huzah, now we don't have to hear winey 12v V6 questions!
  147. woohoo...nice to see this forum...
  148. Sweet...some place else for me to postwhore....
  149. ne1 have dyno graghs for a giac KO4 kit?...
  150. So can we get nDBW 1.8t forum.....
  151. great, another one I have to keep checking, think this will be as slow as the sports forum?
  152. Change the logo type...
  153. I heard I could chip my 1.8T A4 into a 5 second car!
  154. yeah! i posted under #20 1997 A4 was first car w/ the 1.8T right?
  155. Finally.
  156. Which BOV gives me the coolest sound?
  157. Welcome to the 1.8T forum
