PDA
View Full Version : 1.8T Discussion
Pages : 1 2 3 4 5 [6] 7 8 9
  1. Where to buy piston rings
  2. Blown motor or not??? what do you think .. codes as well?
  3. To TT5oul - Engine Noise
  4. Anyone here done a Road Tune?
  5. Short Shifter For Sale
  6. K04 on k03 software
  7. AEB is the best! !
  8. FS: APR TIP - TURBO INLET PIPE - AUDI A4 1.8T B5/B6 96-05
  9. check engine light.
  10. Carbonio Intakes for B5 A4 1.8t - On sale While Supplies last
  11. Hydraulic Valve Lifters
  12. 1.8 T 2004 A4 - WHAT CHIP TO GET?
  13. Are there any Error Code guru's out there? If so, please help!
  14. My bro's car A4 B5 1.8T loss of boost.
  15. 17536 System Too Lean
  16. Engine swap 1.8T
  17. Apexi boost controller
  18. to onkal - engine noise
  19. Vacuum noise under brake padal?
  20. noob chip question,
  21. My POS isn't on my 2001 A4 1.8T's airbox, can anyone tell me where it is please?
  22. 1.8-turbo
  23. clicking noise
  24. Rough/lumpy idle
  25. Will a universal check valve work as an OEM replacement
  26. what's a good hi flow cat that will not rip my pocket wide open ?
  27. BT EBC question
  28. desiling noise still around after i changed the cam chain tensioner.
  29. coil pack replacement
  30. Engine Noise
  31. Engine Flush question and your views about this
  32. burning oil !!!
  33. Reputable Transmission Repair in NYC area?
  34. 2001 A4 - engine advice needed
  35. Camshaft Gear - AEB
  36. A little trouble shooting and or maintenance help please - built motor
  37. deceleration noise
  38. 1.8T & V6 DIY Timing belt change - a -thon DATE: SAT Aug 11
  39. blown 1.8T head -> replace just the head or new motor?
  40. Rebuilt Engine/Timing Belt troubles
  41. AMB 1.8T Q Manual Flywheel Swap
  42. help please; new to turbos
  43. raccoon hurt my car!!!!
  44. Starting and Tick-Over Problems
  45. Im changing the cam chain tensioner today.
  46. Castrol 0w30 vs. Castrol 5w40
  47. Problem with vacuum lines?
  48. What are the cons of "knocking the guts out" of the catalytic converter
  49. Intake, Exhaust, and Valve cover torque specs
  50. head gasket
  51. About to buy the cam chain tensioner, Before i do....
  52. Oil Change Cycle for Rebuilt 1.8t
  53. APR software question...
  54. Second Gear
  55. engine noise
  56. 2000 audi a4 over run cut off valve
  57. Is it absolutely neccessary to use the Audi brand gasket sealant when doing the Cam Chain Tensioner?
  58. check engine light on, issue with O2 sensor?
  59. LIfe Expectancy of Turbo in 1.8t?
  60. Fuel Pump Problems?
  61. Check Engine Light Help
  62. Changing the cam chain tensioner.
  63. who what were when why?!?!?!
  64. I need more power
  65. Cut Back
  66. Possible failure of coil Packs with Audi cars
  67. check engine light stays on
  68. Bypass valve on 99 and 2000 1.8ts
  69. Check Engine Light Stay on
  70. P0011 code
  71. need help... where to buy a good downpipe for 1.8 fwd TT?
  72. what are some top motor oil choices for our 1.8's? <<M1 0w-40
  73. Cars making a Desiling Noise, First places to check?
  74. need your advice!!!
  75. No start and Ignition Module question
  76. Question about head replacement... Bentley manual doesn't show a gasket in one of the holes...
  77. Can anyone tell me what the following codes are?
  78. accelaration problems !!!
  79. Im confused...please help explain
  80. what the diffirence in older vs newer GIAC large injector file ?
  81. A4 Timing Belt Replacement
  82. 99 A4 FWD AEB 54K milesTB Tensioner failed HELP
  83. Buy used engine
  84. Sputtering at higher revs off boost, normal driving...
  85. Need help, searched to no end. Misfires happening at boost over 7-10PSI
  86. Seems like my engine is loose
  87. Engine noise
  88. Stock Turbo Boost Specs?
  89. T104E turbo
  90. Head Bolt Removal
  91. Secondary Air Injection Sensor Code P1411
  92. Gas problem!?!?!?
  93. no power. whats up?
  94. What should i mod on my 2004 Audi a4 1.8tq?
  95. Skool my on high speed fans
  96. THE ADVICE HOUR
  97. Engine Code - Incorrect Airflow ??
  98. Coolant leak near back of valve covers
  99. 1.8t apr stg 3+ turbo kit will miss fire above 10 psi
  100. Plugs and Gap
  101. Correct oil for my 2000 1.8T??????????
  102. How's my 115 block look?
  103. Advanced timing sensor at back of engine?
  104. 1989 AUDI 90 QUATTRO L5 2.30 NG GAS >>> A4 5 Lug Bolt Pattern
  105. Timing belt broke
  106. does this sound right to you?
  107. Dyno and tweak
  108. COLD START PROBLEM.
  109. To chip or not to chip?
  110. humming at >2,200rpm:
  111. A3 1.8T Hot Starting problem
  112. Does anyone have a part number for an aftermarket fuel filter?
  113. No spark on #2 cylinder
  114. No Power, red hot converter rattling from converter area.
  115. Bogging/ Acceleration
  116. AUDI 1.8T TIMING BELT PROBLEM.
  117. Friend's 1.8t keeps getting this p0441 code and I can't figure out what
  118. Weird noise
  119. APR Releases the R1 Diverter Valve!
  120. 2001 audi a4 1.8t quattro... how is the engine diff from the previous a4s?
  121. new turbo for 99 A4 1.8
  122. GTRS problems
  123. No spark on cylinder
  124. 2000 A4 1.8T alternator removal???
  125. Need help w a diagnostic
  126. check engine Icon
  127. Vac Diagram
  128. HUGE 1.8t problems ***HELP***
  129. AGU chipped software, selling
  130. which mass air flow sensor for 01 1.8t awm engine
  131. anyone have the link to the oil sludge fix/repair with pics? thanks
  132. Flashing Break Light
  133. Engine Misfire
  134. Fixed my "cylinder missfire" code
  135. Vacuum check valve, $52?!?!?!
  136. Bentley pictures of replacing the cams on the 1.8t ATC- AMU
  137. engine broken...
  138. Intake - Yes or No
  139. Replaced coolant temp sensor. Thanks for all the great info!
  140. Need a new engine
  141. New or Used Engine and Transmission
  142. Coolant leak
  143. new rebuilt motor or fix existing....
  144. K&N Induction Kit
  145. Rough idle, random revs, cylinder misfire, PLEASE HELP!
  146. shaking/vibration
  147. Decarb
  148. Audi need for speed
  149. help
  150. Save $154.00 on AWE Tuning Stage 2 Clutch Kits!!!!!
  151. Are these extreme TB problems unique to Audi??
  152. What VW/Audi blocks will the 1.8t head work with? Cab it go on a EA831 block from a 924?
  153. I can't decide on at 2001 or 2003 1.8T
  154. Need intake/exhaust valve advice after TB break :-(
  155. APR Customer Appreciation BBQ SALE
  156. what the hell is up with my timing?
  157. loud clutch noise
  158. Engine stumbles when engine bogs down
  159. Thermostat housing swtich & RPM (CAM? ) sensor
  160. What should I expect to pay for a timing belt / tensioner?
  161. coil or plug problem? please advise
  162. 03 a4 1.8t vaccum problems... maybe a valve?
  163. Anyone know what these sensors are?
  164. New or Used Engine
  165. Auto 1.8t conversion
  166. Pic Request
  167. Phisherman Fakes the Funk with Bogus Email Scams
  168. gurgling noise from transmision or clutch
  169. Charge Pressure: Maximum Limit Exceeded
  170. Cam Seal....
  171. ecu question.
  172. Crankshaft Position Sensor location?
  173. Wacky boost problem- 98 a3 1.8T
  174. engine chuging and loss of power help!!!!!!!!
  175. freaking out..
  176. Vacuum leak
  177. excessive oil useage
  178. fuel pump/ gas guage
  179. something broke off in my oil dipstick tube...
  180. Exhaust, Flex Pipe
  181. ABS and Emergency Brake Light on
  182. 1.8T driveability symptoms
  183. How do I find The engine code? Or what engines will fit?
  184. 3.5 BAR
  185. Head bolts for 2005 1.8T AMB
  186. Is it normal for a little bit of oil to appear on the outside of the air induction piping for the tu
  187. bought 2003 A4 1.8t...read threads and scared sh$$less
  188. Engine Tapping / knock
  189. Am I in DEEP SH*T ?
  190. 4BAR FPR
  191. electrical issues
  192. battery Light keeps coming on...
  193. Not starting
  194. No manual mode on tiptronic trans
  195. TB replace for first timer?
  196. Ticking noise?????
  197. What is a Comb Valve?
  198. Persistent Boost Problems
  199. Turbo gone bad
  200. Any suggestions on a good FMIC for a descent price? (Best bang for the buck) Thanks!
  201. Broke my Timing belt on the way to Monday sales meeting...
  202. Big Trouble with 2000 A4 1.8T at 72K miles.. Engine DEAD, need advice
  203. Fault Code help!!
  204. Odd Scratching Noise in low gears on '01 A4 1.8T
  205. Is this normal?? Timing belt pic
  206. supercharger?????
  207. How to give 1.8T CVT more torque??
  208. Don't post here often but...
  209. Engine HP
  210. Is there a break in time for turbos??
  211. check engine light
  212. GIAC self install on B6 1.8T
  213. So i have a case of M1 10w30
  214. Transmission woes
  215. Shall I make the switch to synthetic on a VW Golf Non turbo at 117K? or stck with conventional?
  216. HP question
  217. Vac Leak?
  218. Do you think that a K04 will work fine with the APR stage 1+??
  219. Cut Off Valve???
  220. 1998 1.8L Turbo
  221. Oil Anaylsis cross post (AMU 225)
  222. 2001 A4 QT Battery replacement question
  223. initial acceleration hesitation
  224. Turbos and synthetic oil
  225. cooling problems
  226. 1.8t coil packs
  227. Some problems with the diverter valve replacement
  228. Tech Help: Unknown Fault Codes + Solutions Needed
  229. Turbo Upgrade
  230. what is the proper compression pressure does each cylinder have??
  231. strange turbo lag...
  232. Stage 2 Programing.
  233. memory relay needs to be fixed?
  234. 1998 A4 Shut off While driving on the highway!!!!!!! PLEASE HELP!!!
  235. best turbo
  236. HKS SSBOV question
  237. Constant Dead Battery
  238. Turbo going Bad
  239. turbo glowing red
  240. A4 1999 1.8T - Oil Light...Burning Oil...
  241. 1.8T... removing the cats
  242. What's the difference between a 225HP 1.8T and a 180 1.8T ? Turbo?
  243. APR Boost Gauge
  244. Need some timing belt help
  245. ECS N75 race valve
  246. anyone had issues with ECS adjustable FPR?
  247. in-line transmission filter?
  248. A4 parts
  249. Exhaust Fell off Manifold
  250. 03 1.8t cylinder head
