PDA
View Full Version : 1.8T Discussion
Pages : 1 [2] 3 4 5 6 7 8 9
  1. Affordable Performance help!
  2. 2001 audi a4 awd turbo rough idle but smooth above 100rpms?
  3. 05 A4 avant overheating issue
  4. 1999 Audi A4
  5. 03 A4 1.8t issues with oil pressure sensor
  6. chain tensioner
  7. 1.8 AEB exhaust manifold leak
  8. 2004 audi a4 will not start
  9. 2000 A4 1.8L turbo (manual) smoke exhaust
  10. Audi TT 2002 225 HP 6 speed..
  11. 98 audi a4 1.8t Quattro 5 speed wants to die when ideling
  12. P0171 error 2003 1.8t help! vacuum leak I think
  13. long crank
  14. intake???
  15. Intake manifold vacuume line
  16. What is this thing that has come loose?
  17. No Throttle / Low Idle on Warm Start 1.8t Unitronic Stage 2
  18. car wont start 2003 audi a4 b6
  19. car wont start 2003 audi a4 b6
  20. a4 hazards keep flashing
  21. 2000 Audi TT 1.8T P1545 Issues Please Help
  22. Anti-freeze leak(Bubbling)
  23. 2psi from 1.8t! Need diagnosis help please...
  24. IAT - keep meth nozzle with E85?
  25. Cylinder specification, tolerances
  26. Rebuilding head, how far do I go?
  27. Alternative to using cam chain tensioner tool?
  28. 1997 a4 1.8t sputtering under full throttle
  29. AWM Chassis ATW Motor help
  30. what does it mean
  31. Hard Start when Cold
  32. Overheating Issue
  33. trying to put 00 a4 back together and its not working.
  34. Parting out audi 90 1990 quattro 20v tornado red
  35. anyone with vag-com in CT?
  36. a4 wont go
  37. 2000 a4 atw to awm swap?
  38. TT 2001 check engine light and ESP light on
  39. 2002 Audi A4 1.8t check engine light
  40. need help with timing
  41. audi a4 b6
  42. Oil warning light Intermittent
  43. P0299 - APR K04 - Underboost - An Ideas ?
  44. turbo rebuild or replacement
  45. Not Holding Boost
  46. Buy or stay away: 100k B5, owner says he used semi-synthetic
  47. Alternator makes 14V but battery doesn't charge
  48. Bad MAF? Vacuum Leak? POSSESSION? WTF?Help please!
  49. 99 1.8t turbo surge/stall??
  50. 99 1.8t quattro tiptronic
  51. Strange sound coming from my TT 225
  52. need help identifying hoses
  53. 99 quattro auto not shifting gears properly off and on
  54. should it be going faster?
  55. 98 a4 1.8t misfire
  56. 2012 a4 engine help
  57. Is your Turbo healthy, sick or still has strong power?
  58. Mahle intake/exhaust valves
  59. AEB head - cam bearings
  60. Pinholes/pitting forged pistons
  61. Longitudinal 1.8T K03/K04 header with wastegate port?
  62. Transmission Exorcism
  63. AEB low oil pressure at idle
  64. Timing pull on cyl 1 - 1.8T AMB
  65. 1.8t boost problem
  66. 99 a4 "Slipping", "Jerking", possible misfire, need help
  67. tt 1.8t fwd
  68. ( 1.8 T ) Differences between ignition coils... ?
  69. 2005 A4 1.8T
  70. Help with busted timing belt please. What work has to be done?
  71. 2004 A4 1.8T won't start
  72. Audi Quattro 1.8T radio issue
  73. 2001 Audi A4 1.8 Turbo key blade
  74. AC WARM
  75. no ac
  76. Engine vibrating 2004 A4
  77. Gear problems on my B6
  78. Transmission Problems.
  79. 1.8T AMU swap to 1.8t BEA
  80. B6 A4 - Wiper fluid 'low' signal - wiring
  81. Cruise control
  82. '02 A4 1.8t Turbo lag or Transmission slip?
  83. Rookie Tuner: Old Engine (with mods) startup advice.
  84. Audi a3 1.8t 1998 Throttle problem?
  85. audi a4 oil light on again help pls:(
  86. Low pressure, now the car will not start.
  87. Misfire on idle and no power
  88. 01 1.8t manual---sounds like a helicopter shutting down
  89. Coolant - what water to use
  90. Audi A4 1.8T making weird "weee" type sound when cranking and doesn't start
  91. oil pressure
  92. Wastegate actuator spring rate
  93. '01 Audi TT - Rattle and running hot
  94. 2003 A4 1.8T - Key will crank, but car will not start.
  95. 2000 Audi A4 5-speed manul FWD not moving forwards or backwards?
  96. ko3 turbo blown
  97. 97 Audi A4 FWD 1.8t Transmission problems
  98. Ticking
  99. passat 1.8 cam chain wear on cam cover
  100. passat 1.8 cam chain wear on cam cover
  101. Burn oil
  102. Car not boosting properly
  103. Cruise control servo/pump/vacuum?
  104. Possible Head Gasket problem??
  105. '01 A4 System too lean issues. Help?
  106. a4 1.8T oil pick up tube question
  107. Car Overheating after replacing thermostat and waterpump. Help?
  108. B6 EPC warning light
  109. ADVICE NEEDED!! Audi TT
  110. Exhaust smell in vents and low heat blowing
  111. car exploding electronics going nuts idk what to do cant drive it
  112. mpg with bigger injectors
  113. 03 Audi Allroad 2.7t blinking engine light/car shake
  114. 2001 A4 stopped running, cranks slow
  115. VVT conversion 1.8T
  116. Seafoam into turbo???
  117. AEB - overheating and spitting coolant out of cyl 3
  118. power steering comes and goes
  119. Hard Starting Cold
  120. Secondary air injection code but different symptoms
  121. Problems
  122. Oil pressure problem
  123. Timing Issues, Cam Chain Tensioner ?? Any Help
  124. SMOKE
  125. Transmission, cluster and water pump
  126. 1.8t wont start ignition problem
  127. Rocket 58
  128. Secondary Air Pump Audi A4 B5 Error Code P0441 Emissions Failure – Simple DIY Fix
  129. weird sound coming from the rear passenger side
  130. Please help we're sound..
  131. :: ECS Tuning :: Schwaben European Essentials Tool Sets!!
  132. Cranks but will not start after AEB head swap, ANY KNOWLEDEGE HELPS.
  133. Injector information Bosch 0 280 158 193
  134. 01 1.8tQ AWM
  135. B5 AEB Problems and story of weirdness
  136. Car wont start on top of numerous other problems
  137. :: ECS Tuning :: Pentosin - Superior Fluids For Your Audi
  138. difference between 1.8t engines
  139. 2001 A4 AWM 1.8T Engine rattle
  140. 1.8 TFSi slow to turn over and engine light is on.
  141. Audi 1,8 engine stops, help
  142. Riddle me this...
  143. TT will not start
  144. A4 B8 CVT transmission noises & vibration
  145. 99.5 1.8T Idle Surge; Ruh Roh
  146. turbo issues please help
  147. 2003 A4 1.8t wont start!!! need help!!!!
  148. Accelerator problem
  149. moderate black soot on tailpipes and oil consumption
  150. A3 2002 1.8T Automatic Cold Start Misfire Under Load fault.
  151. head gasket?
  152. Downpipe w/test pipe upgrade
  153. which is faster
  154. p0321 and p0201-0204
  155. help
  156. timing belt curse, need help asap!
  157. Normal Oil Temp for A4 1.8T
  158. AEB 1.8T data logging - Wideband - Innovate LM-2
  159. ECU-apr blew up----aftermath
  160. Boost Issue, Limp mode, And DV issue. HELP!!!
  161. valve cover gasket problem
  162. 2001 Audi TT Secondary Air issues
  163. A4 1.8 turbo...strange engine noise. Help?
  164. transmission in limp mode?! help vag com codes/log inside
  165. HELP! 03 a4 quattro 1.8t red oil light problem!
  166. 1.8t ticking, and new sound. Help?
  167. ECU test? IS there one?
  168. Hoping for an answer (no ecu communication)
  169. 1.8T AEB fuel rail mod for Bosch EV14
  170. ICM location
  171. :: ECS Tuning :: New Pig® Mat & Dispenser Combo Pack!!
  172. Car starts but dies if rev'd past 1500 rpm
  173. AEB head
  174. Buying 01 A4 quattro 1.8t. Service lights on. Advice please!
  175. tt water pump, timing belt ?
  176. Audi A3 - Wont Start - Possible Fuel Problem
  177. Clutch Replacement
  178. Fuel pump 1.8T AEB - does 2.7T fit?
  179. HELP - strange surging on hard throttle - 2001 TT (AMU engine code)
  180. Please check out this video if you know about 1.8t squeals (not accessory belt area)
  181. C2 Motorsport stage 5 AEB tune - anybody running?
  182. Weird Shutting Off Problem
  183. ScanXL for AEB logging
  184. Knocking sound
  185. Swap Manual 1.8t aeb to Auto both 99 a4
  186. Is this oil in my coolant, cracked head plus p171 error
  187. Radiator leaking coolant?
  188. Starting problems
  189. Who is the manufacturer of Godspeed manifold, intercooler, etc
  190. [ 2002 Audi A4 Rattle ]
  191. B5 A4 Quattro 1.8t AEB Chirping Noise while decelerating
  192. 2001 A4 1.8T no start...code p0321
  193. Weird noise after replacing Head...
  194. Looking for experienced mechanic to rebuild the engine on 03 A4
  195. Giac PC16 - fuel pressure, O2 readings
  196. Engine knock AEB - narrow down the cause?
  197. Seafoam to gas and oil - now buttom end knock?
  198. Spilled engine oil on timing belt cover and others...
  199. Coolant temp!
  200. Please Help Strange Limp Mode...
  201. 1.8T AEB - Giac PC 16 - fuel pressure, part throttle behavior
  202. 2004 A4 B6 - Tunning
  203. :: ECS Tuning :: D.I.Y - VIN Decoding!
  204. AEB head swap on AMB Motor
  205. How to check a wastegate valve on a 2002 a4 1.8 t
  206. 99 A4 - 170,000 Maintenance
  207. P2400 code
  208. low oil pressure
  209. WHAT DO YOU THINK ABOUT THIS
  210. 2000 Audi TT Transmission
  211. bosch 440 w/3bar vs. genesis 415 w/4bar
  212. Check engine Light Help please!!
  213. Help for missing parts for my 2000 A4 1.8t
  214. 97 1.8 A4 running hot
  215. 1997 A4 1.8t running hot
  216. Looking for ecu
  217. Audi TT Quattro 1.8t Engine swap question
  218. 1.8T AEB Giac PC 16 - boost 'pumping'
  219. 02 a4 wont start because of code issue.
  220. GATES BLUE TIMIMG BELT
  221. AEB - PCV tube/hose under intake manifold
  222. Runing on 3 cyl after cold start
  223. Wanted : 2003 a4 1.8 exhaust resinator
  224. :: ECS Tuning :: Schwaben Tools - Back In Stock!!!
  225. Larger MAF housing for 1.8T AEB
  226. Hard to start after valve job
  227. SPEC Clutch fail twice
  228. Misfire on 02 Audi TT 225...
  229. 2001 TT Coupe 225 / My over heating scenario.....
  230. TIMING BELT SHREDDED... WHAT NOW ?
  231. Quick Question
  232. dialing in fuel pressure with Giac PC16
  233. Need Help!
  234. 01 1.8t stalls almost immediatly
  235. O2 sensor
  236. 2003 Audi A4 (1.8T) Engine Wiring Harness Diagram? Anyone have one?
  237. Misfire germlin!! I need some serious help on this one!
  238. Radiator replacement 2004 TT Quattro
  239. Cruise control vac line: where to connect?
  240. 2002 TT 225 Roadster Timing Belt
  241. AWM engines for sale?
  242. a4 wont start
  243. Bank 1 lean error, troubleshooting please!
  244. What is reasonable repair timeframe for head replacement?
  245. 1.8T Turbo System Discription
  246. doors keep relocking them selves
  247. 1998 A4 1.8T AEB - Upper O2 sensor choices
  248. AMB 1.8t Thermostat
  249. K03 to K04
  250. AEB head for sale
