PDA
View Full Version : 1.8T Discussion
Pages : 1 2 [3] 4 5 6 7 8 9
  1. vacume leak, need help
  2. installing a European ECU in my 2003 A4 Cab 1.8T
  3. Turbo inlet pipe 2.0" AEB
  4. A4 B7 throttle boddy fault has me stumped!
  5. APR Stage 3+
  6. 2000 TT 1.8T ovevr heating
  7. 2004 A4 B6 build help
  8. :: ECS Tuning :: B5 A4 1.8T Carbon Engine Covers!!
  9. GIAC out of business?
  10. Timing belt ???????
  11. big question about turbos
  12. A4 1.8t Engine surges in gear, no power
  13. a4 1.8t overboost...replaced n75 still getting 17963 upper limit HELP
  14. My Audi Nightmare
  15. Surging Idle Only While Rolling...Strange
  16. Wheel Bearing Noise
  17. Connecting rods
  18. weak start, rough idle until 3,000 rpm..help
  19. Frankenturbo?
  20. What have I missed?
  21. Boost Problems
  22. Oil guage fluctuates
  23. Changing Timing Belt
  24. :: ECS Tuning :: B5 A4 1.8T Crankcase Breather Hose Refresh Kits!!
  25. :: ECS Tuning :: B6 A4 1.8T Cooling Flange - Back In Stock!!
  26. 1.8 timing service - anything with it?
  27. BOSTON AREA HEAD WORK
  28. 01 TT won't start after driving
  29. Coolant leak into oil...Blown HG or Vacuum issue
  30. A6 Serpentine/drive belt shredded engine won't turn over even by hand
  31. Advice on Turbo set up?
  32. need some opinions with boost surging.
  33. 2001 audi a4 1.8t blown head gasket?
  34. Buying my 1st turbo engine car, what to inspect?
  35. Need parts asap.....
  36. Timing Belt Replacement
  37. A4 Cruise Control Issues???
  38. A4 2 Red lights above rearview mirror?
  39. A4 Fog lights Reset when car off?
  40. I broke the Elbow on the SAI
  41. 87 89 91 Octane Differences?
  42. A4 B5 1.8T, tiptronic Shifting?
  43. 1.8t engine swap is it possible?
  44. 99 a4 1.8t with many codes, running rough, no boost. need help!
  45. Any advice?
  46. Differential oil
  47. P1340 and no readings MVB 090-098
  48. Strange Noise from standstill to first gear (manual trans)
  49. Head Rebuild?
  50. Turbo installation.
  51. Random overheating?
  52. P2181 questions
  53. Fuel pump question
  54. audi TT turns but doesnt start. please help
  55. 2001 Audi A4 Quattro 1.8t AWM Engine Code
  56. MAF Sensor voltage?
  57. Exhaust down pipe removal 1.8 225 quattro
  58. Timing Belt or Chain
  59. APTuning Now a Castrol Dealer - December Specials Inside - Free Stuff!!
  60. APTuning Black Friday Weekend Sale - Custom Euro Plates - APR - United Motorsport
  61. Where can I find Cheap exhaust???
  62. B6 quattro exhuast advice
  63. 1.8T 2003 A4 timing belt snapped help!
  64. 2004 Audi TT 225HP Quattro
  65. A/C COMPRESSOR
  66. HELP!!! 1.8T
  67. Won't Start/ No codes
  68. Help - oil leak w/ pic
  69. cam sensor
  70. Correct temperature gauge/sensor reading
  71. bad MAF no boost
  72. S3 1.8T Sluggish
  73. Power loss
  74. A4 B5 1.8T Wastegate Question
  75. Cam Adjustment Valve Issue
  76. Odd Oil Usage
  77. po688 hard start??? Help please!
  78. Is this a boost leak?
  79. A4 MAF Problem
  80. System malfunction
  81. misfires and smoke
  82. Oil Capacity
  83. Turbo upgrade question
  84. Extreme knocking noise in engine
  85. Need Help - New build will not start.
  86. APTuning End of Summer Service Specials - Timing Belts, & Alignments!!!!
  87. tt 225hp heating up!!
  88. tt 225hop heating up!!
  89. Audi B5 A4 1.8t making horrible noises on first start up
  90. Died while driving???
  91. Cylinder 3 Misfire
  92. Random Misfires!
  93. Random Stall
  94. Engine Misfire?
  95. Turbo covered in Engine Warranty?
  96. Oddball 1.8t Setup with k24 (audi 5000) turbo setup. need new turbo- Options?
  97. DIY valve cover gasket removal and install
  98. Squeking noise - rear engine bay
  99. Is my throttle body bad or needs to be aligned?
  100. Timing Belt Question
  101. Idle issue - rev drops ...
  102. Thermostat Cam Adjuster
  103. turbo studer during acceleration...HELP PLEASE
  104. APR Summer Sales Event, Now Happening at APTuning!!!!
  105. CAn you use a universal turbo as a direct bolt on ?
  106. Engine/turbo hisses And I lose power after shifting from first gear
  107. 2002 audi a4 quattro
  108. Do Turbo car need to change oil and filter every 3000 miles?
  109. ALLOY WHEEL
  110. 1.8 T
  111. Audi S3 8L...1.8T + GT35R
  112. 2002 a4 1.8T with hose from turbo leaking ?
  113. Another steering rack question
  114. Low Oil Pressure, Coolant, Engine Malfunction warning lights r on, SCARY PLEASE HELP
  115. No low end power
  116. Coil Pack Versions
  117. Turbo Wanted!
  118. MY TURBO BROKE IN HALF??!!!
  119. Which engine and tranny do I have
  120. Engine performance comparison logging VAGcom
  121. 1996 A3 1.8T - new Crank Case Cover Gasket? see attached Picture
  122. Possible Blown Head Gasket - help to confirm my thoughts!!!
  123. Audi B6 - Left fog light not turning on? HELP!
  124. AMB 1.8T knock sensor torque spec?
  125. B6 1.8t Stock Intercooler
  126. Engine parts diagram
  127. 2001 A4 Quatro turbo engine cols
  128. why do the turbos keep blowing on my a4?!
  129. 01' TT PARTS NEEDED
  130. never ending water pump leak
  131. Interpretation of data log
  132. What is my N75 doing?
  133. Tips for restart after 9 months
  134. Cold engine
  135. Cam Chain tensioner..... of course
  136. HELP PLEASE! Smokey 1.8T!!!!
  137. 1.8t audi a6 99 AEB oil warning
  138. manual swap
  139. UnderBoost Problem... 2004 1.8T
  140. I changed the Mass Air Filter on my TT
  141. Cylinder #4 missing
  142. 1.8T Indicater lights flashing in sequence
  143. Speedometer acting funny.
  144. Coolant Leak... Need help identifing (not coolant flange)
  145. Changing spark plugs.
  146. 2002 a4 1.8t quattro fuel filter
  147. Hose on top of engine is torn?
  148. Intercooler
  149. Lots of white smoke coming out of tail pipe?
  150. 2002. 1.8T A4 Replace Head Gasket???
  151. Timing belt pulley, not tensior pulley..What is it?
  152. AWM auto vs AWM stick
  153. APTuning New Years Timing Belt Install Special for Virtually all VW/Audi Models!!!!
  154. Boost Peaks at 17psi - Am I chipped???
  155. P0420 NIGHTMARE!!!!
  156. iat high output?
  157. A4 B7 1.8t not engine start
  158. 2001 A4 Q 1.8t - misfiring - P0171, P0300, P0301, P0302 - CEL flashing
  159. What triggers 18014 code ?
  160. APTuning/APR December to Remember Holiday sale!!!
  161. Wierd Engine Start up sound
  162. 1.8T A4 wagoon 2001
  163. Starting issue's
  164. 2.0t using 1.8t wirings harness and ecm
  165. Jump with Gear Switch
  166. Name a cool thing you've done to your 1.8T!!!
  167. What is the correct oil pressure for '02 A4 1.8T?
  168. HELP PLEASE DOES NOBODY KNOW?
  169. Electrical Problem
  170. P0303 and P1300 (only and together)
  171. a3 quattro gear box and bmw rear diff help please
  172. timing belt mess
  173. engine swap question ????
  174. Fuel Pump Buzzing...Thoughts (kind of long)
  175. Trouble changing Cam Chain Tensioner Gasket
  176. please help
  177. starter motor squeal (from A4 forum)
  178. Crank Position Sensor
  179. Stalling Issue?
  180. Any Tips for Oil?
  181. FML timing belt problem PLEASE HELP!!
  182. N75 Valve (058 906 283 F) Behaviour & Boost Plot
  183. Belts question
  184. Transmission problem?!
  185. Water in Pancake Valve
  186. Oil squirter fouling piston skirt with stroker kit.
  187. Are helicoils ok on turbo manifold?
  188. N75 wastegate actuator valve explained/symptoms.
  189. Missing Sensor?
  190. Revo Technik Spring Sale Marth 27th - April 11th 2010
  191. Looking for used intercooler for b6 1.8t
  192. Thermostat
  193. MAF Failure yet again any idea why?
  194. Installing Cold Air Intake
  195. MAF Replacment -- What kind of bolt is that?!
  196. timing belt replacement!!! PLEASE HELP
  197. 2001 A4: Is Fan Pully bolt reverse thread?
  198. Trouble finishing this project
  199. VW TL 774D vs. G12
  200. My 1.8T suddenly seems to have lost the "T"
  201. 1.8T coolant issue.
  202. DIY Oil Pan / Sump Removal
  203. Oil Leak - valve cover / Cam seals
  204. Tech Help - Breather System components
  205. need help with cel
  206. Flushing my rad and changing the thermostat.
  207. www.nikeec.com wholesale Christan Audigier hoodies jacket nike air jordans max shox
  208. www.nikeec.com wholesale coogi t-shirt nike air jordans max shox gucci dunks air forc
  209. manifold to cat glowing red
  210. No Heat....again and again
  211. Which hose from intake for boost gauge?
  212. 1.8t blown - what can retrofit?
  213. Coolant level low after timing belt service
  214. Just switched ECU for GIAC ECU... Why won't it start?
  215. Audi TT ac compressor - issue with harness
  216. Cress71
  217. A4 1.8t Service and heater blower question
  218. Tranny Slip After Battery Disconnect
  219. 1999 a4 to 2001 a4 engine swap problems
  220. Help Please
  221. shakey idling engine
  222. Noisy engine after tming belt change
  223. APTuning/APR Holiday Sale Has Begun, Nov. 23rd-Dec. 31st!!!
  224. Requesting assistance with a few codes.
  225. Changed coil pack Car won't start
  226. Hard shifting/delay shifting
  227. Retardation on B5 APR Stg 3
  228. crank shaft removal
  229. is the turbo working?
  230. a question about transmission
  231. Turbo install tech guide??
  232. Dump Valve Question
  233. Is something missing in my engine--see picture.
  234. 1.8T won't hold boost
  235. PCV Diagram 1.8T Engine
  236. Need Some Help
  237. WTB: K03 or K04 for AEB 1.8t -- Want to close deal TODAY if possible
  238. plug wires
  239. A4 with unbearable vibration at idle... any suggestions?
  240. 1.8T engine tick at idle
  241. Engine Problems - hesitation and rough idle... any ideas?
  242. P0299
  243. Overheating issue.... Cant figure this one out
  244. GT3071R Pump Gas Dyno
  245. Replacement Engine
  246. *Revo Technik continues to expand its authorized tuning network with 4 new dealers.*
  247. What better/cheaper?
  248. Oil Pump Replacement instructions?
  249. boost gauge installed, TTc225, only -5 to 5 psi
  250. A4 1.8TMISFIRING??
