PDA
View Full Version : 1.8T Discussion
Pages : 1 2 3 4 5 6 [7] 8 9
  1. where do you fill the power steering @?
  2. What chip should I get for my TT?
  3. X-Post - Tubular Manifold Pics
  4. Did a CAPS run & o2 sensor question
  5. Coolant Issue
  6. Audi technicians: here's a unique opportunity
  7. Transmission Tragedy....HELP!
  8. AUDI 1.8T TT INTERNALS HELP!!!!
  9. after getting timing belt changed my car revs and seems to be in a low gear after i climb a hill
  10. Noisy engine
  11. Didn't drive car for a month...
  12. I'm having a weird Idle issue, anyone have any input?
  13. long life Mann filters. . . realy lasting 20,000?
  14. need some answers on ko3 and ko4 turbos??????
  15. Code P0118
  16. Anyone install a APR BLUE SNUB on a TIP
  17. FS: 97-99 APR chipped ECU for NDBW
  18. more hp without chip?
  19. Outside Temp Sensor
  20. anyone have the 1.8t-A4 study guide?
  21. Best place to get adapters??? Need Help quickly please
  22. Is all pink coolant the same???
  23. Wont go into gear? clutch still has feel though.
  24. Difference between an A4 and Passat 1.8T AEB engine head?
  25. performance clutchs
  26. where could i get my car to pass inspection with tinted windows in the north jersey area
  27. Positive Buyer Feedback
  28. Code help
  29. anyone have a magnaflow exhaust system on there 02 or newer audi
  30. Does anyone know if the intake manifold from a 2001 1.8T engine...
  31. BT HELP!!!!
  32. got timing belt done today need help!!
  33. I need a turbo for 1997 A4 1.8
  34. Audi A4 engine parts for sale!!!
  35. New With Audi's- - - -Advice pleassssse!
  36. fuel pump
  37. Chipped ECU, which to get?
  38. Head Hanging low...
  39. ***SPECIAL HOLIDAY EXHAUST PRICES @ ECODETUNING!***
  40. how neccessary is a Turbo Timer in a stage 3 1.8t?
  41. used ecu website?
  42. 2002 1.8t engine oil issue!!!!!!
  43. Problems with new 2003 Audi A4 1.8T... please help
  44. what exhaust is best for my 1.8t?
  45. help me with my boost control valve please!
  46. desperately need help
  47. running TT cams in an 02 audi a4 1.8t
  48. Proper orientation for the dual mass flywheel? Recess for pilot bearing? Replacing rear main seal?
  49. New 2001 A4 1.8 with 134k miles
  50. I loved My first Audi untill today
  51. Loud noise coming from engine when i step on the gas!Help
  52. Announcing the 7th Annual APR Holiday Sale @ Ecodetuning!
  53. APR Holiday Sale and Stage 3+ Giveaway!
  54. Engine Balance
  55. 2000 Audi A4 Quattro 1.8T TCM
  56. New a4 1.8t owner...
  57. Head Gasket or... (I searched endlessly...)
  58. 1.8t big enough?
  59. whining, rubbing noise in 1st/2nd gears
  60. Frozen Turbo
  61. Startup problems
  62. The best repair manual?
  63. K&N Filter?
  64. Water Pump Part Number?
  65. Care dies help please
  66. OIL FILTER
  67. Performance Question
  68. A4 1.8t transmission
  69. remote keyless entrey?
  70. what could this be..............
  71. Coilpack/Spark Plug/Injector issue possible...
  72. Harmonic vibration that's RPM dependant in 99 a4 1.8tq manual AEB, crank pulley spins untrue at idle
  73. sudden loss of power and the car is sputtering..
  74. looking for cams???
  75. 2002 1.8T Passat Wagon brake light
  76. Oil in boost/vac lines?
  77. Cold Air intake
  78. Audi a4 1.8t 2000
  79. Piston Size question
  80. Noise please help!
  81. Fuel being cutoff problem Please Help!
  82. This forum needs a "Sticky" thread
  83. K04, ECU, exhaust FS (B5 1.8t) in classifieds:
  84. Coolant Loss?
  85. is this normal?
  86. Hello All
  87. Stroker on an AMB - 034efi?
  88. A4 Cylinder 4 Misfire 2001 A4
  89. help please..
  90. exhaust system
  91. Car Jerk When Move Off From Stationary & Roll Back On Upward Slope
  92. broken timing belt
  93. mass air flow
  94. Timing belt tensioner...
  95. x-post: car running rich
  96. Transmission Oil Questions?
  97. What can go wrong96 1.8T
  98. noise after engnie shut off
  99. Quick Engine Oil Question and other things....
  100. engine problems
  101. Guidance.....for the noob (please)
  102. No Boost
  103. does anyone have a pic of where the n75 valve is located on our cars?
  104. What are the common 1.8T oil leak areas?
  105. Building a 2.0L.....20v head or 16v head?
  106. Noise After Shutdown,....
  107. Stage 3+ kit
  108. Spark Plugs? Air/Cabin Filter
  109. Stuff from XS-power
  110. engine light with error code 17544 02/02
  111. Does anyone know if the valve seats on the head can be replaced and if so how hard?
  112. (Sorry if repost)...Audi's new 1.8TFSI
  113. Squeaking?
  114. I've search and searched but can't tell a direction for my diverter valve...
  115. Need help with Evap code 17834 and 16825
  116. VAG near North Dallas
  117. Aftermarket springs for the lifters? Or change the lifters altogether?
  118. 1997 1.8T Turbo Upgrade Kit
  119. Warning Light/ Squaking sound
  120. upgrade for fuel pump??????????????????????????
  121. Paging Fridge and anyone else running haltech stand alone management systems
  122. i know KKK turbine housings are... different... but why???
  123. 1st day of buying 02 a4 w/ pre-owned audi certified - check engine light comes on! Please Help!?
  124. white smoke from the tailpipe
  125. 1.8t Engine Noise after shutdown
  126. Engine just shut down on the highway. Will not start. ECM???
  127. ECU's backward compatible?
  128. EFK belt size for underdrive pulleys (1.8T)- fan pulley delete
  129. K-03 with a K-04 compressor impeller? Anyone try this yet?
  130. how can i fix this problem?
  131. Bad engine problem Need please!!!
  132. Audi A4 Quattro - Stand Alone Engine Management
  133. HELP
  134. performance help
  135. APR Announces H2o International Sale offered throughout North America!
  136. X Post Gap setting on NGK iridium BKR7EIX
  137. Location and replacement of IAT
  138. Engine Pinging - Neuspeed Chip?
  139. VAG Question
  140. oil pressure light
  141. I think my DV is junk.... suggestions
  142. EVAP System Help!
  143. ATP mika gt2871r installed but problems
  144. Unitronic question...I'm a MKIV 1.8T but trying to compare notes...
  145. ROUGH DAY.....HELP
  146. Took some logs today, and timing seems to be a bit off...
  147. WTB: Crankshaft from AWM or AMB (MANUAL TRANS) motor in good cond.
  148. Is it auto or manual?
  149. wanted Ko4 or ko3
  150. Just got a TT, What mods should I consider ?
  151. Oil Sludge 1.8L turbo
  152. diy intake
  153. ECU identification? Pics inside.
  154. When should an audi a4 1.8t cambelt be replaced?
  155. blow off valve? where dose it go an how?
  156. Mist
  157. Are we being ripped off
  158. are these codes for the FRONT 02 sensor?
  159. reliability of 1.8t?
  160. A6 turbo???????
  161. n75 boost pressure regulator noise, a whining or whistling sound at
  162. Mann Oil Filters cheap?
  163. b6 intake where can i get? help!!!!
  164. Size of fuel line on 2002 1.8T engine.
  165. Is this normal? vacuum, boost. after new dv and boost gauge
  166. Leak in the intake tract..
  167. For all those who run their own fuel management
  168. anyone have an ATC vacuum line diagram???
  169. Broken Dipstick on 2001 A4 1.8T
  170. Parts needed for AWM crank swap
  171. TT Front end noise while coasting? Help please.
  172. In case noone saw this from the Waterfest gallery... 9.5 second Corrado's engine..
  173. TT engine in B6 A4
  174. oil min indicator light on every 62 miles
  175. weird noise, help!
  176. abs * brake light come on
  177. Boost Gauge hookup
  178. clicking noise??
  179. Where do i get a Outlet hose?
  180. 2001 A4 1.8T Chip Upgrade and Diagnostic Tool
  181. Wire in the Shiftlight on my Audi TT Quattro 225hk
  182. NEW AUDI PARTS
  183. what hoses need to be replaced when running a larger turbo?
  184. ecu swap.
  185. engine problem please help!!!
  186. question about ko4 turbo
  187. Misc. Hose Diameters
  188. Recall 1.8L Crank Case breather hose
  189. Exhaust valve shears on the 1.8t!
  190. not getting enough boost pressure..
  191. t3/t4 or gt28rs
  192. When is the 1.8T most efficient - Vacuum, Boost or at equal pressure?
  193. how do i make b5 1.8t faster but keepong below 400 dollars
  194. bpv n75 valve
  195. do i need to do a software upgrade if i went with the tt225 injectors?
  196. I think i have BIG problem!
  197. Audi TT225 Parting Out *PICS ADDED!*
  198. 99 Passat 1.8T AEB Motor with T3/T4 Turbo - How can I get this to run right?
  199. turbo stutter
  200. Does anyone know this guy? *UPDATED*
  201. NEED 1.8t 99 a4 short block
  202. help please
  203. question about a t3/t4 turbo fitment
  204. Anyone else have the APR/Carbonio intake?
  205. Understanding the 1.8T turbo layout
  206. Does AWD/FWD have anything to do with the engine ECU or thats a
  207. Is there a Built Crate motor available for a B6 A4?
  208. Anyone have a photo of the 1.8T ECU circuit board?
  209. Help with AWM motor fitment
  210. "17967 (p1559) throttle actuator control unit" ............ how o fix???
  211. need help now
  212. fried coil pack
  213. help please
  214. Engine problems...any ideas???
  215. RESULTS
  216. Questions about the GT28RS kit from ATP
  217. what about oil filters k&n or bosch
  218. Forge 007 diverter & N75 valve, or just Forge 007 diverter?
  219. Bad fuel filter- bad Turbo - same noise????
  220. APR WaterFest SALE
  221. i need to change my clutch slave on a 99 a4 front trace anyone know how??
  222. what about cold air intake
  223. Giac K03 upgrade what goes with it?
  224. Odd chirping noise
  225. Best Intercooler for big application/
  226. Intermittent fault - running lean - 17544 - Fuel Trim - Bank 1 (Add): System too Lean
  227. An Exhaust / Turbo Leak?
  228. manual boost control
  229. modifications for a K04 turbo upgrade
  230. REVO K04 upgrade or Milltek K04
  231. Timing belt change
  232. Water injection question
  233. looking to resolve the SAI problem
  234. Do i need to reset the ECU to get rid of CEL? or should it go off by itself when problem is fixed?
  235. X-Post to B6 Forum: Is this wastegate nipple ok?
  236. sorry for the n00b question but is it okay to drive with a can of seafoam added to the crankcase?
  237. anyone heard of an oil pump going out???
  238. 02 audi a4 clutch wear?
  239. anyone running the carbonio intake?
  240. Presure tested the engine tonight, not happy about it. need advice
  241. New GHL exhaust on A4??? HELLLP!!!
  242. OETTINGER stainless steel rear silencer, OETTINGER stainless steel rear and main silencer
  243. suggestions for performance
  244. gas mileage
  245. How can you break a rod in a 1.8T?
  246. Impossible?
  247. Terrible MPGs
  248. N75 Wiring
  249. short shifter?
  250. any body in edison,NJ area w/ vag com have check engine?
