View Full Version : 1.8T Discussion
Pages :
8]
9
- upgrade oil filter size for 02a41.8t?????
- Where is the Fuel Pump Relay?...
- Loss in Acceleration (225 hp roadster)
- Which Engine Coolant to use?
- want to upgrade 99 1.8T have questions
- oil in coolent water
- When did you replace your coil packs?
- 1998 1.8t a4 Q problems
- EPC light come on when it gets hot, please help
- Soft lim, lim mode
- adjustable FPR
- How many quarts of oil with filter replacement?
- 1999 A4 Quattro w/1.8T Runs Rough
- APR is pleased to present the VVT TT 225 2004-05 Stage 3+!
- total noob question: what is the cheapest/easiest way to get rid of this extreme turbo lag?
- Does anyone know what these engine fault codes mean (Camshaft A intake and Engine Speed Sensor)?
- N75 Issues
- TT225 pancake valve (06A 129 101 E) on the AEB...
- Boost with APR chip
- KO4 problems pls help A4 1.8T
- Running race gas on stock internals for 28RS turbo kit?
- 1.8T 20v "AGU" engine replacement
- removing crank bolt!!!!!!
- My GT30R PASSAT
- importance of knowing the oil temp?
- Audi Expo 2006 - Come be a part of history again!
- Timing belt at 151000 miles
- Chipping the B6
- Finally! One step closer to 400+hp goal. (movie of test drive)
- Timing Belt Maintenance
- SHOULD i UPGRADE 2 A LARGER OIL FILTER 02 a4 1.8t
- how do i get to the (dv) in a 02 a4 1.8t?
- 1999 Audi A6 1.8 TQ hi everybody I just need clutch kit... Which models can I mount thanks.
- Losing boost pls help!!
- Turbo Boost Pressure..
- instrument cluster and quattro AWD problems
- Injector Flow Rates? Anyone know the flow rates at 3 bar on a 99.5 A4 injector?
- Engine Lubrication
- CEL out of nowhere
- air intakes
- Screw Compressor
- I think I broke it Please help :)
- Blow off vaulve
- timing belt same as toothed belt?
- power boost
- Oil Filter by-pass valve question.
- No more pick-up in my 2001 A4 1.8t
- British Oil sludge 1.8T
- Anyone have link to 1.8T Technical Manual?
- mike 2 pt slow...long
- Engine Idle problem - A4 1.8T APU - B5
- 2 Blown Turbos & still something wrong
- alternator 120amp re and re
- Got my new B6 1.8T... newbie questions
- 2001 225 TT 1128 fault code
- Audi Expo 2006 - It's coming!!!!
- 2000 audi tt 1.8t 180hp
- Gas pedal feels heavy when accelerating any theories?
- MY A4 ENGINE CAUGHT FIRE!!!!!
- Car died while driving and now won't start
- DIFFRENCE?
- Need Some help....Tranny in LIMP MODE again!
- 2002 A4 catalytic needs replacing, suggestions anyone?
- Need my ABS mod rebuilt...suggestion?
- 1.8T Power loss on hill
- Too much vacuum, too much boost!
- the stock setting of the ko3 waste gate
- Catalytic converter change (Magnaflow)
- Dahlbach Cold Air Induction vs. Carbonio
- SEAFOAM / TECHRON EXPERIMENT
- engine stops.
- Help- weird metallic "whine" - wastegate failure?
- USED TURBO DEAD or ALIVE
- used exhaust valves wanted;...
- Neuspeed's ECU Flash Programming Now Available at North American Motorsports Connecticut Location
- umploged coilpack
- X-Post... multiple fault codes, 2001 AWM 1.8T
- k04 Model #??
- Spark plugs
- A4 1.8T experts....
- Anyone Close to the Northwest Arkansas Area Have a Vag-com?
- DTC 16804
- Weird stuff with ATP Manifold... Help...
- HELP - weird 1.8T problem
- Need some advice...
- Best place online for 1.8 tt front strut brace?
- True that HKS ssqv BOV ok to use in 1.8tt
- Help....need engine parts...
- TBA fault, cant reset and cant use throttle
- Knock Sensor is reporting high frequency signal. It is intermitent. Coil pack keeps popping out...
- WAnted to buy engine...any suggestions?
- misfiring under boost 2004 a4 1.8t
- Strange boost problem??
- Engine for sale
- HELP!
- vw golf mk 2 1.8t abs light question
- 16795 and 17544 - to replace the MAF or not to. Old topic but an attempt at summarizing.
- HELP!! MAF replacement hell... now it won't even kick over.
- timing belt replcement and clutch replacement
- Stalling + intermittent oil light
- Help! Calling all VagCom gurus...
- So. Cal April 29th Dyno Day! Ingolstadt West and WMS will be there with their monster TT's!
- HKS Filter Question for you Techies out there....
- Coolant Flange/Hoses
- how many miles can i expect to get out of this 1.8T engine proper care?
- broken dipstick funnel
- Cam Chain Tensioner Noisy
- gear shifting problems
- Oily c@$p on top of 034 Puck value
- Forge to sponsor SEAT Leon 1.8T in Britcar race series
- Hi, i have a question about the cylinder head.
- Anyone see this before? Cracked exhaust valves on the head.
- Will i be able to swap my blown atw 1.8t motor for a 1.8 from a 2003
- Nitrous on 1.8T?
- Help with B5 1.8 Turbo troubleshoot and replacement
- Engine Sludge
- Plug help on 1.8t
- neuspeed that bad?
- Techtonics Tuning cat-back and down pipe.
- GHL Exhaust
- Need a new clutch Stage 2 preferable what is a decent clutch that fits well
- So, I've got a weird one for you guys...
- Anyone done or know where to get done a tranny swap from auto to manual on a b6 ???
- Coolant problem please help A6 1999 1.8 tq
- audi tt wiring diagram
- Very good article on history of 1.8 in this month's AUDI DRIVER (barnes&nobles)
- Question about using a 03-04 Passat 1.8T short block with a 01 A4 1.8T Head
- Anyone who has played on a dyno what A/F ratio's gave best power?
- Limp mode or?....
- Diverter Valve
- GT28R Turbo Advise
- Alright, I'm doing a boost gauge on my Sister's 02 1.8T passat tomorrow,
- Questions about the basics of the 1.8T engine...
- XPOST URGENT: Who's car was this and what the hell was done to it?
- Few questions as far as heads and stroker kits
- When buying a used VW (1.8T) - what are some things/problems to look out for?
- Has anybody tried Evans NPG waterless coolant?? Long!!
- Thought you guys might be interested...
- Where to start on modding my engine....
- anyone have a test pipe for sale they can overnight me for sat morning delivery???
- New Throttle Body
- Best Chip
- slightly off topic, got a boost gauge for my sister's B5.5 Passat (Xmas present)
- Is GIAC advising against the bigger injectors, FX program for B6 A4 Tip's due to increased torque?
- 99 AEB cutting out randomly,... coil packs?
- 1/14/06 - CT/NY Audi Group Winter Gathering - EPL, Stratford, CT
- I WON!!!!! Stage III+
- 12.8 at 107 plus mph in B6 A4 1.8T Avant. Revo tuned GTRS..
- APR chip=CEL, now only 5PSI, help!
- Water ingestion anyone?
- running rich mixture and oil fuel dilution
- which injectors and software for gt3071r?
- What year did they start DBW in the A4?
- Group Buy in info for Audi A4 1.8T Garrett Eliminator Turbo kit for B5/B6
- how much could i expect to pay for a 1.8t engine with 50k or less on it?
- A4 1.8T engine: what are symptoms of timing belt slip?
- donde estan mis amigos con grande turbo ?
- Repost from B5 forum, need help diagnosing a oil sensor issue.
- has anybody ever had luck with ATK Engines...?
- anyone in need of a vag-com and laptop
- Since a the dp comes after the cat, is it safe to assume that there is no point in getting a big DP?
- MAF Changed but need advices
- B5 B6 B7
- sludging problem with oil
- X-Post-1.8T stock torque revisited
- Help! Can AEB coolant flange fit on a AWM
- 1.8T 2002 A4 B6Timing belt replacement
- 13.47 @ 103 mph in car video. 2004 Audi A4 1.8T QM6, AWE GT28R kit and ER FMIC...
- Opinions needed: Turbo upgrade
- Rough at Low Throttle and Check Engine Light (Heeellp)
- A.W.E. Tuning at H2O International September 25th
- keep getting code p1127 manufacturer mas air control
- EuroCode becomes the first official in-house dealer for Neuspeed Optican Powerflash
- Another Favor
- A favor..
- What would the engine run like if the cam was off one tooth?
- a few BT issues
- Neuspeed ECU, socketed or soldered
- Help with chipping a new 1.8T A4 (B7)..
- Anyone else see Javad (034) on Tuner Car Transformation on Speed channel last night?
- throttle body spacer
- how does this look? 1.8T engine.
- if anybody knows a place in north america to get a refurbished cylinder head please reply! TIA
- For those of you running the HKS SSQV BOV...
- check engine light on all summer, have no idea why, please help!!!!!!!!!!!!!!
- x-post boost drop
- Help Before I buy
- Help!!!
- HKS SSQV Blow Off Valve installation?
- maf data logging question.....updated
- anyone running a gt28rs w/an external wastegate? is it a big enough turbo to benefit...
- Where do you find a cold Air intake for 01' A4 1.8T??help.
- Ko4 question
- Can an '01 "CH" ecu from a FWD swap with an '01 "CH" ecu from a Quattro with ESP?
- Turbo Chipping
- 98 Audi A4 1.8T stock top speed??
- cold air intake?
- im wanting the pssshhhh sound, what can i do?
- just random thought, what involved in make a 1.8 to a 2.0?
- The dealer and my clutch...
- 1.8T (DBW) THROTTLE CONTROL VALVE FAILURE SYMPTOMS?
- sorry! here it is...
- link!
- Can anybody give me part# for #4 in diagram,also the Y hose its conected to!
- X-post from the A4/B5 forum.
- Sweet 1/4 mile time from B6 A4 1.8T.. Ran at Waterwagons..
- New owner with questions...
- xpost: AEB intake manifold on ATW head...
- I'd like to compile a comprehensive chip/turbo/valve/intercooler guide... so I need help!
- wanted: aeb long block or head
- Should I have this turbo rebuilt?
- Kudos to ATP Turbo...x post
- Installed a boost gauge today and I am peaking at about 17 PSI
- 1.8 Engine swap
- Vacuum leaks - Vacuum line diagram
- question about valves...
- hey i just got a 2001 A4, i was wondering what i should do to get it perfect condition.
- For all those with Stand Alone
- need "new" used k03 or k03sport for 1999.0 B5 1.8T
- What brand/weight oil do you use in your 1.8T?
- what size injectors with a giac chip?
- Is this bad? According to Prodiag, stock 1.8T Jetta is making more boost than requested
- 98 Oil Pressure Light/Sound
- CEL/ECU fault question
- 5th Annual Audi Expo - Schedule:
- Pullin' my hair out.....(long)
- 9 days 'til Audi Expo! - Have we heard from you ?
- what do u guys think about this TEST PIPE 200$ + ups
- I think i might have a boost leak..
- O2 sensor 2001
- X-Post from A3/S3: Need help with DVs
- turbo Q.
- putting together a spray kit for the side intercooler. temp LCD display help
- PLEASE HELPPPPPP about Clutch Kit
- what do you guys use to clean the MAF on 2001 A4 dbw?....
- Putting in a new Turbo. How do you prime it with oil so it doesn't burn up on startup???
- B6 A4 GIAC KO4 DYno results Race Map and Race Gas..Whoa!!
- Coils: Can anyone point me to a diagram that shows what the four pins...
- Got the turbo out. Here is what I found. Advise Please!!
- Problems at the track with j31
- where can ı find Stroker kit for my 1.8 T
- turbo went out of my brothers 2000 VW Jetta ??+ other problems
- 5th Annual Audi Expo - Come be a part of history again!
- clutch problem...
- atp web page
- Those of you who have swapped in a non bosch maf (ie FORD)
- bov or bpv
- How much does performance clutch cost in germany ?
- anybody have diagram of vehicle speed sensor, i need to replace mine and i cant find it?
- DTC 17522
