View Full Version : 1.8T Discussion
Pages :
4]
- misfiring under load
- Oil Cooler 1.8t ?
- Need new Engine!!
- HELP PLEASE: Check Engine Light Flashing and Engine Sputtering
- Boost problem with chipped 1.8t AEB
- misfire from 3krpm to 4.5-5krpm
- My A4 won't start. Please help!
- starter motor whine
- B6 Timing Belt Job: trouble all the way, crank bolt won't budge!
- 1.8T cutaway pictures
- wierd stalling need help audi experts or people with exp.
- Dumb question - I'm multi meter challenged
- Codes P0411 and P1432
- Fuel Pump???
- cylinder 1 misfire 1.8T AEB
- Throwing Code P0171 System Too Lean (bank 1) - any suggestions?
- cel... codes inside. please help diag
- RPM jumping
- Stall at Start
- the complete HOW TO connecting rod install... (videos inside)
- spark plugs
- COP Dimensions
- 502.00 Spec, but why?
- Ignition coils- Better luck with one then another??
- Ignition coil blues
- Loud lifter noise, oil pressure light blinking
- Typical oil change and brake change rates?
- Audi tt !.8 vaccuum lines and crank case vent tub
- Please help: My audi wont start...
- Valve cover gasket
- E-Brake Aggraviation & Drag pan replacement
- Use old coil packs as spare?
- idle stumble?
- TT 1.8T starting problems
- cylinder head/piston damage
- Post-timing belt change issue
- 2002 A4 1.8T quatro automatic Mods
- Wiper Positioning?
- Presssure Regulating Valve
- READ this before posting. 1.8T.
- First gear boost info
- Broken ABS sensor
- A4 B6 need help!
- Secondary air injector + foam on dipstick
- OOps sorry!!! Need help Check engine light...
- 2003 1.8T Losing Oil Pressure
- yet another boost problem....
- APR's Spring Into Power Sale March 9th- April 10th
- Are coilpack problems related to just the CP or is there more???
- Spark Plugs this weekend
- Where do I find my sensor for my Headlight Dimmer control A4 Quattro 2002...
- how many miles do they go till they die
- 1.8T recent TB job now takes a few cranks to turn over. Almost like its getting jump started.
- TB Class action
- brrrrrrrrrr im frezzing got no heat!!!!! can u help
- Coolant
- I need a new clutch
- Bad waterpump...30k on the TB...what to do?
- How can I tell if I need an 'H' or 'R' coil pack?
- hood latch stuck.....
- 2004 A4 1.8t Upgrades
- Looking for a detailed "How To" or DIY on the 1.8T timing belt replacement
- suction jet pump
- Inmotion usa
- air or co2
- Ross-tech Throttle angle reported
- Crankcase breather/valve/hose replacement extensiveness
- Just wanted to touch base and let you guys know I should be recieving all the parts today...
- New turbo going in for the right reasons... i hope
- MAF the problem>>>?
- recalls
- tranny problems PLEASE HELP
- $3000 repair and now I need new engine!!!!!!
- Hope this is a really quick question
- Spark Plug gap on 2005 a4 1.8t
- Whats a good reasonably priced VAG to get I also Have a Volvo and Merc to work on..
- Any DIY for CVT fluid change?
- NO HEAT! (2001 A4 Avant, 1.8t)
- unplugged n75 and no difference when I drive it. I also hear a slight leak coming from that
- No boost and smoke
- How far can I go with a 1.8t tiptronic?
- buy fuel injectors
- 1.8T
- Boost Test
- best exhaust?
- replaced some valves
- B6 A4 ECU PINOUT
- need Help Oil on the exhaust manifold, rough idle and no power
- Can I upgrade my TT quattro with a S4 twin turbo engine?
- oil pressure, I think
- stupid question about stock divert valve
- APR Stage 1+
- blown water pump
- Starting to plan big turbo upgrade
- Slight Coolant Leak
- Climate control memory
- After I start my car
- Studer possible problem
- 2005 1.8t A4 What spark Plugs to Use in her?
- Noob needs help from the homies yet again.
- Please help w/ ?"fusible link"? on top of battery.
- Yellow engine light is blinking !
- Electric water pump !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!
- Boost Leak Testing
- rebulding cylinder head
- Spark plug replacement on B6
- sluggish handling?
- Timing Belt Class Action Suit - 99 A4 1.8T
- Intermittent Misfire - CEL clears later
- 1.8T 2004 yellow oil sensor light on and off, where the sensor is located?
- 99 A4 1.8T
- White smoke coming from under battery
- Window
- Crankcase vent parts
- Car Trouble, Need Help
- Diverter Flutter?
- FMIC Installation.
- Need help-electrical issues
- APR Stage 3 Raffle Winner is Announced Today!!
- NEED HELP URGENTLY!
- Upgrading Audi A4
- Searching @1900 rpm
- air filter
- Forged Rods (Integrated Engineering) 1.8T 19mm Pin and 20mm pin Kits
- removing cylinder head bolts
- diagnostic computer plug port
- Auto start for a manual
- Need help! rough idle
- supersprint exhaust what do you guys think? any good?
- New to the 1.8t engine
- T belt, reuse old tensioner?
- X-post, before and after pics of BG dynamic Engine Clean
- APTuning APR Chip/Software Sale !!! Best Pricing Ever!!!
- Timing belt inspection, why do it?
- Looking for - B6 1.8T Rebuild Head write up/direction.
- 04 vs 03 TT 225 engine upgrades?
- APR Announces 2008 Holiday Sale and Raffle!
- random misfire- can't find the cure
- Hose Help
- what would you recommend, forge fmic or competition haldex
- Ignition Coils
- Cam Belt broken... HELP!!
- I wanna buy a new DV anyone wanna recomend one?
- Timing Belt Recommended Maintenance Change Question
- Someone help me figure out what is going on.
- clanking engine noise and no power!!!
- 2003 Audi A4 Quattro Battery
- Carb Legal Cold Air for '03 A4
- i just got done replacing my water pump and timing belt
- Correct ECU code?
- Knock Control stats: is this a problem?
- overheating
- Main bearing??
- oil changing in my 1.8t....
- Oil filter tip... I changed my oil, and didn't quite tighten the filter enough... I didn't want to
- boost is up and down
- Help! Location of temp sensor A4 B6 ,1.8T 2003 Quattro Sedan
- Timing belt trouble...or is it?
- Rough idle and no power
- No start, no spark, no good
- Anyone with a spare / used K03 or K04... or K03s. Rebuildable okay. For 2000 A4 1.8tq
- What started out as the low oil light fiasco...
- APR BBQ Schedule of Events!
- Looking for 1.8T engine for 2003 A4 5 speed
- 1.8T head bolts
- alternator keeps dying
- 1.8T harmonic balancer
- Has anyone ever used a heavier harmonic balancer to smooth out the 1.8T before?
- help changing the alternator
- Throttle body
- APR Customer Appreciation Day and Grand Opening
- Grinding noise upon engine start
- head gasket
- APR Stage 3! Can somebody give me some informations?
- Need help Code 16395
- forge pistons
- Bad Timing Belt Inspection at dealer = Incorrect or Deceiving
- Idle speed.
- T-Belt Tensioner same b/w AMB and AWM?
- AWM non-fouler?
- Engine Light
- Which Ignition Control Unit is better? Bosch or Huco?
- performanc cam gears
- clutch stage 3
- Forged Pistons
- Intermittent Won't Start
- Timing belt service interval different between Audi and VW 1.8T?
- engine noise from 2800rpm to 3200rpm
- Camshaft Adjuster Gasket Leak
- How do you test the wastegate properly?
- 1.8t Not starting :(
- what are ways to save my turbo
- Cost to Rebuild ECM/ECU?
- B6 T/B Slipped - Replaced but crank is out of TDC - HELP!
- what is the location of the oriface tube (restrictor) for the ac system?
- i read p0411 secondary air injection incorrect flow
- misfire on #2 , which coil pack is that on an a4? and wtf, does beru not supply the gaskets w/ them?
- Burning Smell ??
- ***NOW SHIPPING*** A.W.E. Tuning DV1 Diverter Valve
- Misfire advice BT with cams
- Audi dead, HELP???
- Turbo Sounds
- intermitant smooth running A4 1.8T quatro 1999
- 1.8T Valve Cover Gasket DIY Anyone?
- sewing machine mod? (xpost with B6 forum)
- A/C compressor replacement
- Stock Clutch Torque Rating
- 2.25" straight pipe without muffler is it gonna be loud?
- P1113 Code
- engine help? slipping clutch? Idle control valve?
- B5 A4 (1.8T) has radical power loss, stumbles - but only for a minute
- why 99 a4 1.8t RUNNING RICH?
- Gpop turbos
- FOR SALE BORLA CAT, APR BOOST GUAGE, K & N, TURBO INLET HOSE, DASH COVER BUTTONS
- Coil Pack
- Boost gauge steup
- Low power
- WTB: A4 valve spring retainer
- Problem With Cam/Timing Belt Replacement
- Flashing yellow oil sensor light?
- Cambelt change what mileage?
- APR Presents Waterfest 14 **Inventory and Activity Update**
- I am picking up my A4 1.8T tomorrow
- turbo replacement advice
- misfires
- New A4
- What are some things that can cause low requested boost?
- APR Waterfest Sale! - Ecodetuning.com
- if this has been covered before...
- AUDI WONT START (CLICK NOISE)
- Should the Evap purge valve go click?
- My engine is making a strange noise. Turbo related? Ideas?
- Reposted here: 99 A4 1.8T Auto Sometimes dies at idle (Long)
- Spark Plugs, your $.02 Cents and feedback
- Clutch issues
- Eliminator Kit Exhaust?
- APR Stage 3 Owner's Corral at Waterfest 14!
- Help finding a boost leak...
- engine shaking at idle
- X-thread... coolant leak... help needed
- Does anybody have the procedure for testing the oxygen sensors and the cats ?
- hard acceleration, car shakes
- boost gauge, reading right???? HELP
- Throttle Body Question
- White smoke on startup (head gasket? turbo?)
- Camshaft position sensor
- Audi 1.8T Coil Prob
- Audi 1.8t has a few issues
- turbo sys DV BOV
- whys my 02 a4 1.8t overheating?
