PDA
View Full Version : 1.8T Discussion
Pages : 1 2 3 4 [5] 6 7 8 9
  1. Please help with camshaft positioning
  2. 1.8T - Troubleshooting for vacuum leaks
  3. 99 a4 timing belt and ignition problems
  4. Ideas? Speed Sensor Problem with factory ECU and the speed sensor from 2.2 Eurospec
  5. has anyone tried Pulsestar plugs? their site shows good gains on our engines. they are $24 each
  6. So, you may or may not have sludge. Prescriptive/preventive measures?
  7. 1.8 t oil pressure questions-vag codes
  8. advanced timing help please.code 16396
  9. ECU essentials
  10. compressor
  11. Which forged internals to get.
  12. Engine swap Trouble Starting
  13. K04
  14. Iregular boost
  15. Code P0011
  16. air conditioner
  17. A chain is as strong as its weakest link
  18. Help! with N75 error after engine swap
  19. Phantom P1128. HELP ME PLEASE!! I've read up all over but....
  20. Intermitent No Start
  21. Oil Light
  22. Need Help with my 2001 A4 1.8T
  23. No Boost! No acceleration! I need your help.
  24. Fuel Injectors needed 630cc siemens anyone have a set?
  25. Installing a boost gauge, need help.
  26. crankshaft trigger wheel ABA to ATW?
  27. Timing Belt, time to replace?
  28. 02 A4 1.8T - couple maintenance questions
  29. A/C Compressor question
  30. Optimal Operating Temp. for Oil??
  31. P1136
  32. IN 2?????
  33. Diagnosed: Camshaft adjuster seals leaking on top of exhaust manifold
  34. Adaptation period??
  35. Exalted StageIII 1.8T Turbo Install w/Quick Clamps
  36. Price of a new engine
  37. Help! removed intake mani and made serious mistake.
  38. 2002 TT 1.8T 5 spd -No power - no compression in engine
  39. B5 egine / viscus fan
  40. large bore Intake vs head question...
  41. 2003 Audi A4 1.8T - Ignition Coil
  42. TT timing belt
  43. 2001 TT 225 Misfire
  44. strange noise
  45. Help identify part
  46. shop in so cal that can install timing belt etc
  47. lose timing belt tensioner?????
  48. MAF Sensor #06A 906 461 EX
  49. KO5???
  50. whats the boost levels for a k04?
  51. Where's the best place to get a rebuld head
  52. Audi A4 1.8t 60000 miles service, please help
  53. a4 surging at idle
  54. spark plug question
  55. timing belt
  56. Oil Light On. It has plenty of oil and has done it once while on the highway and...
  57. Misfire service help?
  58. talk to me about limp mode. causes?
  59. Throttle Body Code 17967
  60. i found some oil in my throttle body hose what does that mean?
  61. K04 not anymore?
  62. Help-Car splutter after initial engine start-Ok when warm
  63. car gets crazy when starting hot engine
  64. fan vibration
  65. Starting the car
  66. 97 a4 1.8t blown engine
  67. what spark plugs are people using on there 1.8T's
  68. ECU question! PLEASE HELP!
  69. How difficult to replace breather hose
  70. Broken gauges, help???
  71. Why am I getting such bad mpg and why is my car so slow?
  72. Big Turbo
  73. Need help with torque spec for head bolts...........
  74. Need K03 turbo for 2001 A4 1.8t in good working order........
  75. problem boosting-probably n75
  76. The FAN is blowing!Can't turn it off!!
  77. Global Motorsports Group proudly releases its 1.8t Big Turbo Kit.
  78. Installed my S.Schwing VTDA and LOST my top end..!
  79. 1.8t pulley problems
  80. Am getting a VTDA/should i reset the cars comp..??
  81. kmd dyno tune price offer
  82. Any of you use NITRO with is AUDI ?
  83. Turbo noise problem in longitudenal 1.8 (Passat)
  84. Larger Turbo??
  85. GMG 1.8T built A4.. Power kit.
  86. Spent 12 hours in the garage yeasterday and found some pressure leaks. Can anyone tell me if this is
  87. i have oil all over my plugs and coils because of a bad valve cover gasket. could this
  88. whats stock boost on 99 1.8t
  89. Dump Valve Help???
  90. 1.8T oil pan replacement
  91. 2.7T Throttle body on a 1.8T?
  92. Intermetent sputtering or stalling
  93. transmission problems???
  94. What Turbo Should I get?
  95. should i?
  96. Ecu swap???
  97. turbo issue
  98. Looking for a estimate dollar amount range!!
  99. turbo
  100. anyone have a coil for 2001 awm 1.8T I can buy?
  101. DIY on replacing the fuel filter for 05' B6 A4
  102. intermittent hard starting, rpms shoot up, CEL...
  103. turbo
  104. someone help! boost problems (i think)
  105. dodgy heater
  106. Low P/S Fluid ??
  107. No boost. Done homework. Need help.
  108. looking to relocate my bpv. i know someone did this a while back and had a really
  109. 1.8T Overfill OK?
  110. dump valve help???
  111. compression test gone wronge....?
  112. leaking detection pump
  113. boost issue in 3rd gear
  114. Car hesitates, hardly any power when clutch is engaged.
  115. Cam chain stretch
  116. Coil Pack Keeps Going Bad
  117. Newly chipped 1.8TQ won´t start...
  118. IntAke!!
  119. ABS sensors
  120. 2003 A4 1.8
  121. whomp whomp whomp on front wheel!!
  122. throttle body resetting after replacement
  123. check engine on and running really rough or hesitating
  124. torque specs for oil pan
  125. Engine Replacement A4
  126. Anyone have a cam chain tensioner I can buy?
  127. DTC 302
  128. Premature Head Gasket Failure
  129. A4, B6, 1.8T, 6speed WHATS THE BEST INTAKE?????
  130. ICV valve on 97 1.8T
  131. Engine Replacement
  132. Maintenance
  133. NEED HELP!!!!
  134. Bore out a 1.8T
  135. alright. could this work??
  136. x-post: limp, replaced vac lines, n75 resistance good, plugged the wastegate line from the n75
  137. 1997 1.8t. Cat broke loose from the manifold/turbo.
  138. Bank 1 (Add): System too Lean
  139. OE Parts
  140. A4 B5 turbo oil inlet size
  141. 1.8T new owner A4 cab
  142. BIG savings during A.W.E. Tuning's Week Three Holiday Sale
  143. stock exhaust..big turbo
  144. A.W.E. Tuning Holiday Sale Week 3 Is Running Till Christmas!
  145. K03 turbo
  146. Cam Differences
  147. engine revs when changing gear
  148. Oil Pressure Alarm Issues...updated
  149. APR Motorsport Vacation Raffle Today!
  150. torque specs foe the connecting rods end cap and flywheel
  151. need help!
  152. looking to upgrade to K04, a couple questions....
  153. 2wd to 4wd????
  154. 1,8T IGNITION COIL/Help
  155. k04 turbo????
  156. ATW vs AWM
  157. friends string of bad luck...
  158. genesis injectors + unitronics + gtrs. 415cc or 430cc? 2001 AWM motor
  159. What's the part called that connects the rod under the throttle to the rubber boot?
  160. 03' A4 water pump leak...
  161. need help reading my block 3
  162. fan keeps kicking on..
  163. Cold weather rough idle - 100rpm drop
  164. newbie engine problem
  165. noise coming from '98 audi a4
  166. i blew my second block in 66K
  167. Fluctuating Temperature Gauge
  168. where is the best place to pruchase a gtrs elim turbo and hardware?
  169. Just fixed Coil pack!!!
  170. alright... what is the thought on o2 sensor simulators\bypassors
  171. HELP 01.5 A4 1.8T won't start
  172. No Spark Cylinder #4
  173. 1.8T (Jetta IV) Throttle codes... again... any other possible causes
  174. 1.8 turbo
  175. APR and Eurocode Holiday Sale!
  176. APR announces 2007 Holiday sale and Raffle!
  177. Boost issues -- possible culprit -- part # 034129101B
  178. What is this??
  179. ABS pulsations
  180. Help!!!! Oil splatter
  181. South Fl Auto Tech available for house calls
  182. Cam position sensor.. how to's
  183. need help.. Car is surging bad with unitronic software
  184. Newbie needs help Coolant Flange - bottom hose
  185. Cam Timing on 2001 Audi TT (225)
  186. 2002 1.8 T Coolant leak below back three headed breather hose..Coolant Flange on 2002?
  187. Engine Sludge Identification Help Please!
  188. Is my water pump belt to loose?
  189. Cross Post: Need help with a Cam Positon Tensioner gasket job gone bad. Throwing code 16727
  190. What else should I do with timing belt and waterpump
  191. 2001 A4 1.8T triptronic with boost problem.
  192. used 1.8t question
  193. apr stage 3 b5 a4
  194. Help! Timing belt question.
  195. Boost problem!!! Please help
  196. Rad Hose replacement
  197. white smoke!?!?! noob... please help.
  198. Cylinder 3 random misfires
  199. 1.8 to 2.0
  200. trouble diagnosing problem, help please
  201. chip
  202. Anyone know were to buy these at a reasonable price, or an alternative?
  203. Mystery Oil Pressure Light
  204. Power issues please look at my vag-com plots
  205. Strange Starting Problem?
  206. Newbie got funny warning light flashing, no handbook though!
  207. APR Motorsport to bid for 2008 Koni Challenge
  208. Please Help
  209. Engine Light - OBD II says #1 & #3 misfiring
  210. 1996 Audi A4 quatro
  211. down pipe
  212. Possible bent valves.
  213. acc idlers
  214. LOOKING FOR A GOOD AEB HEAD
  215. engine probs, slow start...then jump in rpms and acceleration...
  216. Secondary Air / Combi-valve
  217. ECU chips and also badges
  218. Overheating
  219. have I destroyed my transmission?
  220. just found this listing
  221. Is there a write up regarding pressure testing a 1.8T engine?
  222. Whats stock boost pressure?
  223. Help with crank exchange
  224. Using AEB head on AMB?
  225. Timing Belt screw up - Help Needed
  226. engine noise after mis-shift...
  227. car won't start
  228. APR and Jim Ellis Audi present Petit LeMans Customer Appreciation Weekend
  229. intake for dummies
  230. Slugish lack of power Problems!!!!! but no code
  231. Anyone tried this module?
  232. To TT5oul Update
  233. 9 quarts of oil was in the engine now its making a weird sound ! ! !
  234. Introducing Clutchnet Corporation as a new banner advertiser
  235. 1.8T Surge in boost pressure.....
  236. Turbo noise question. Please help.
  237. Cat Conv Question
  238. thoughts on 15W-50 Mobil 1
  239. Could use some help diagnosing a boost? issue on an 01.5 AWM (epic long)
  240. is it the Camshaft OR crankshaft position sensor?
  241. to ONKAL update
  242. 1.8t engine noise started out of the blue (please help me!) video included
  243. APR H2O International Sale Begins Wednesday September 18!
  244. turn signals
  245. I want to replace the vacume lines on my car. What sizes should i get and where should i get them ?
  246. Belt stripped, engine destroyed; Other replacements/Where to buy?
  247. Coolant Leak, back of engine
  248. How to fix this leak?
  249. P1127 VAG 17535 CEL Fixed
  250. yellow engine light
