Suspension Tuning Discussion Discussion forum for general topics regarding suspension tuning
A8 D4 Air Suspension fault
Old 10-16-2018, 12:26 AM
Ian Mush's Avatar
Default A8 D4 Air Suspension fault
Hi Guys,
I have a 2011 A8 D4 and i have the following problem pop up 36359 Valve for Damping Adjustment Front Left C1040 11 (009) Short to Ground.
So I changed the air shock as the valve is all part of the assembly and the fault still appears and will not clear.
I put my meter across the contact which are a + and _and it read 600ohms the unit I removed 600ohms and the front right which I know is good 600ohms so that rules out a dead short on the air shock.
Also the suspension lifts and lowers as it should. Obviously on the lowering cycle it opens the valves to dump the air pressure allowing the car to lower.
I also checked all visible wiring in the arch and fitted a new Duetshe plug.
Any ideas ?
Thanks in advance
Ian
Ian Mush
New Member Welcome Area
10-16-2018 12:16 AM
SamPer
Q7 MK 1 Discussion
16
01-13-2018 04:34 AM
ElusiveEstonian
02-16-2015 08:13 PM
defacto
12
09-02-2014 05:05 PM
hill0523
12-14-2009 06:21 PM
Quick Reply: A8 D4 Air Suspension fault
