Coilpacks?
Coilpacks?
OK, all the talk of failing coilpacks has me thinking a "emergency coilpack kit" (as some here have created) would indeed be prudent...
I searched the forum to no avail - anyone have a suggested source for coilpacks (2000 180Q, engine code ATC) and tools required/installation instructions...
TIA
TIA
Replacement instructions on my Fotki, but for the pushin type...............
<ul><li><a href="http://public.fotki.com/blackfnTTruck/coil_pack_replacement/">Coil Pack</a></li></ul>
Try this link. I think you have the '2-bolt' type. You will need a 5mm hex socket end or ball-type
allen wrench.
this link is for the AMU 225 motor, which requires you remove most of the bolts to get at 3 and 4 cyl.
<img src="http://www.loomknitting.com/auditt/images/coilpaks1and2.jpg"><ul><li><a href="http://www.loomknitting.com/auditt/coilpak.html">Coil-Pak replacement</a></li></ul>
My 01 225 had bolt type my friends 01 180 had push in type
Its very easy on a 180! 20 mins if that.
I just did my 225 sparks and coil about 1 hour hardest part was getting all the crap out of way and working the coil packs in 1 2 around the charge pipe.
I usually buy the 4-pack from ECSTuning, but you may find a lower price if you
shop around.
Also check
<a href="http://www.autopartswarehouse.com">AutoPartsWarehouse</a>
<a href="http://www.worldimpex.com">World Impex</a>
<a href="http://www.clairparts.com">Clair Parts</a>
Also check
blackfnTTruck
26
05-07-2006 07:06 AM
Bob Petruska
12-16-2002 09:57 AM
"so you're foofighter"
12-08-2001 08:51 AM
