suspension drops partially after shutdown
Anyone ever see this? When I shut the car off, I hear the right strut lose air and drop about 12 mm or so then stop. It can sit for a few days without dropping any further.
Upon startup, it raises to position again quickly and the pump runs maybe 5 seconds. That tells me the air tank is still full.
Im thinking the check valve in the air valve controller may be sticking.
AudiWorld Wiseguy
This is normal. It’s the suspension auto-leveling after there is no passenger weight in the car. It does it when you lock it/put the car to sleep. It’s not a leaking strut you’re hearing, it’s the suspension exhaust solenoid valve releasing air.
summitradio (09-09-2019)
glenn_a
16
02-06-2018 06:03 PM
