Pulled codes last night and idea what the heck is going on HELP PLEASE
The codes are as follows
17530,17526,17522,17548,16544,16524,17965,17547,17 545,17535,17537. What the hell is going on with my damn ECU. A friend seems to think that everything but the 17965 are something with the ECU being to rich or something of the sort. And the other is a pressure leak he thinks. But he is not an audi guy so I was wondering what you guys think is going on.If it is the ecu is there anyone that has a ecu that would fit my 2001 a6 2.7t tip so that I can send it back to neuspeed and have them fix it for me. Thanks again Ron
Re: Pulled codes last night and idea what the heck is going on HELP PLEASE
rear o2 sensors bad (1st 6 codes)
charge pressure: positive deviation
running too rich, idle and run (last 4)
Knowing neuspeed chips,it could be an ecu but doubtful. I would probably take it to a specific Audi shop to gt it looked at.<ul><li><a href="http://www.bentleypublishers.com/tech/audi/audi.dtc.table.htm">http://www.bentleypublishers.com/tech/audi/audi.dtc.table.htm</a</li></ul>
I opened VAG-COM to see if it had a 'look-up' feature but no go. I'll scan it for you if you want
I'm happy to hook up and read your CEL codes if you didn't clear them. It will spell it out for you and let you know what they are. Once again I'm in HR if that's close to you. There are others with VAG-COM's around Denver if I'm not very close to you. I'm actually checking Jeff's RS6 this afternoon too. Only takes a sec to do.
Also, just wanted to remind you to change your subject line when replying. Makes it MUCH easier to follow the thread for the rest of it and it's just standard practice.
hey chuck are you busy tomorrow if not I can
Hey chuck what is your actual address to see if I can make it tomorrow. Would you have a chance tomorrow do you think and if so what would be a good time for you. Also what are you looking to help me out with the exhaust welding and taking a look at the ecu for me. Thanks Ron
We can take a look at it tomorrow and see if we can figure out anything
We can at least get you some detailed error code info and makye the list would have some ideas. If the rattle is easy to get too maybe we can weld it up for you. No promises, but we'll do our best!
I'll drop you an email with my addy.
ajg617
09-06-2015 07:23 AM
