- Valentine 1 for sale...
- any audio buff's going to the APR BBQ?
- I bought the A/D/S amp, amp kit recomendations anyone?
- Alpine changer/headunit - will it play burned cdrs?
- Any good stereo shops in San Jose?
- i just realized that once i slap my iva in the car the trip computer will look blank....
- Reception problems and more. HELP! (long)
- The reason why my system is SOOOOO much tighter than all of yours.
- Anyone know of a good installer in the Boston area?
- Has anyone try the Bose Stereo bass upgrade II? How is it?
- Installing cd changer into 99 a4 Avant...Is the mounting kit different from sedan? TIA
- Aftermarket HU: How to make it look GOOD?
- Where is Imola.org on web
- STEREO ADAPTER KIT ANYONE?
- Does anyone have a Clarion Auto PC, if so how do you like it?
- Non metalic sounding smooooooth tweeters sought
- Further Audi Nav Plus Map Research....
- has anyone put an aftermarket radio on a 97 a4 with bose??
- New Audio System Ideas....
- 98 A4 changer in a 2001 TT roadster
- Newbie ques-what's the easiest way to add more base to a leased '01 S4?
- A Question to ponder?
- Which size speakers are in AUDI A6 BOSE boom box
- A/D/S
- Hooking up powered antenna adapter
- Are USAcoustic AMPS any good? Just a question of experience and what ya heard....
- Is Nav Plus in US Car Possible ???
- Nav Question
- Thinking about an EQ... need some help guys (other stuff too)
- What do you audio guys think of this idea?
- Anyone have their Audi/Bose stock deck and speakers for sale?? yr's between 92- 94 i think..
- 01 non-Bose rear door speaker Q's
- EQ or not to EQ
- is it possible to bypass the factory amp in the bose 97 a4 with out rewireing each speaker?? thanks
- What sizes are the speakers...
- Any pictures of an aftermarket head in place of a 2001 A4 Symphony
- Help, JL stealth Box, How do i install it In a 2000
- Quick Question
- Mark P, some questions about your Cadence and some other stuff...
- How can I improve the sound of the 99.5 concert stereo and keep all my trunk space?
- Does anyone have the part # for the Scosche Harness adapter?
- hey, has anyone put an aftermarket radio in plase of the bose?? more
- Basic Question: What's flush mounting an amp?
- Is there any info on using CDC inputs for 'Aux'
- what plug to use to by-pass the factory bose amp in a4 97?? can it be done?? thanks
- OK TO MOUNT AMP TO SUB BOX?
- Has anyone ever successfully removed the amplifier from the left rear speaker?
- Is the little box under the rear seat the amplifer....
- Rear speakers on 100S, can I bypass the amps?
- Blau Munchen reception problem SOLVED...and pics!
- Switching 2000 Bose Symphony to standard Symphony
- Where to run power cable through firewall on a 1990 90?
- here is my dillema......(long)
- 1996 Cabriolet Sound System Replacement Ideas?
- Kinda OT: To those who know lots about home stereo's and amps...
- MBQuart Adaptors
- People with the Alpine IVA-C800, where did you mount the brain for the unit?
- mark p, got instructions on how to remove ski sack?
- hey billyt, are you happy with the pioneer?? I looked at that today, what brain did you put with
- Anyone try an Infinity Basslink Sub with a non bose system?
- Question about adding an amp to Symphony HU
- does 98.5 concert system have factory amp somewhere?
- Avoid 'Autotoys' for purchace!!...read!
- how do i know if i have cd changer hookps
- Sorry to post an ad here, but is anyone interested in a set of Diamond 6.5" drivers?
- hey guys, i was hoping yall could help me decide on a screen, i am about to more....
- where can i get JL w3 or w0 and a single woofer box cheap? can a 200 watt amp power either sub and..
- Here's a description ofthe BOSE system in the A4, as posted on their site
- hey mark do you know the best way to get a CLEAN low level signal from the stock head unit (bose)
- Does the blau adapter work on 2001 with bose? please help using stepdown of rear woofers and it scks
- Mark p are you here?
- Avoid Alpine subs,
- Symphony head unit
- Blau Munchen problem...owners pls read
- Noise problem.....Hopefully the PPI PC4100 I just ordered will fix my problems. =}
- ? about subs firing through back seat.
- Are the JL w6 subs, the top performers? Am I misinformed
- In the beginning , there was Alpine....
- Audiophiles.... Choice between two setups.. what do you guys all recommend..............
- Please Help..sort of important for me... I am trying to wire rca cables from my radio back, i....
- Can I hook up an amp and 2 subs to a '00 Bose?
- good install in North Dallas area
- Good 4 channel amp for under $400?
- Replacement Antenna
- Please recommend an install shop in Phoenix Area??
- Poor AM reception -- 88 80q
- (cross post) TT Audio Preview--For anyone interested in hidden placement of an amplifier . . .
- USPS/ebay car audio blues =( Anyone ever deal with getting insurance money back from USPS?
- Gamma CC radio - CD changer compatable?
- Anybody have FM reception problems w/aftermarket radio (more)
- What 10" sealed sub will sound best with only 200W?? a JLW3?
- Off-topic ... 19" rims for sale ......
- Is the Blaupunkt adapter plug and play for a 99.5 Concert radio, or do I have to modify it?
- Question: Where is everyone routing their power lines through the firewall, besides the ECU box..
- Poll: StockHU with RCA Adaptor, What AMP's have you guys been using?
- Stock Stereo (non Bose) upgrade advice, Please...
- VW Bose noise when cold
- How much should the mb quart 5.25 in adapters cost?
- Wired my car...learned a ton....I am willing to share...
- Flickering display in head unit?
- Calling all Double-Din aftermarket radio upgrades....
- how do you remove ski bag in a4???
- my SAFE moded stereo won't let me enter the new code even after an hour - I screwed up the code twic
- Mark P-- question for you
- HELP!!!...How does one remove the Door Trim along the bottom....running wires.
- Please help, researching new system plan...
- Audi Bose W/out cd player
- Maybe you can explain this.....
- Symphony radios...
- Removing Symphony radio from TT
- audi delta with alpine chm-s620 shuttle
- Polk or Infinity? 4's or bigger?
- Hey everybody, check out S4 forum for pics of my Alpine Nav/DVD System
- Can Anyone recommend a good stereo shop in N. Dallas area
- CD changer proble, x-post
- PreAmp XOver vs. New HeadUnit
- 6 channels
- Can anyone recommend a SMALL sealed-box sub ?
- 2001 A4Q Bose w/ Panasonic 8 Disc Changer installed, but can't get to disc 7 & 8.
- attn: Mark P
- Please help....Can I get Preamp outputs from the back of the radio, without installing a converter..
- How can I tell if I have Premium Sounds??
- Cellular telephone
- Looking for good stereo shops in Denver/surronding area. Anybody?
- S4 rear deck replacements (Bose Symphony)
- Any other good MP3 players would work well with the Bose system besides the Neo 35?
- Can anyone point me in the direction of web pages with custom installs?
- How to remove speakers from 90 quattro 20V?
- Audiophiles, HELP! - Advice with Bose system in an S4
- speaker advice needed...
- Random Question
- Cover plate for S4
- shal i put MB Quart componants or coax's in the rear deck??
- Diamond 6 1/2 vs. ADS 336is??
- Diamond Sub Questions??
- Amps - Phoenix Gold vs. Orion vs. ADS vs. Xtant vs. Soundtream???
- Neo 35 MP3 Unit Install
- Aiwa CDC-MP3 installed
- Factory Navigation System
- just got some red stuff from theatre store for my eclipse...
- Bose in 2001 S4
- would it be possible to fit 2 10's under the rear seat???
- Is the Sony XM-2252HX a decent amp to power 2 Infinity Perfect 10.1's?
- Adding subs to Bose
- Second-hand audi radio
- Can you convert 98.5 A4 single DIN to Double DIN?
- a4 rear speakers
- woohoo!! check this out ...
- Does anyone know what's under the hump in the spare tire well?
- 1991 Audi 90 - Problem With Rear Speakers
- anyone replace their bose head unit with empeg ?
- Opinions on the blaupunkt casablanka?
- Can a great set of Coax's in the front sound as good as separates?
- Eclipse 5443 love it-but wish it was red. Anyone know how to change the color?
- Wish me luck! Starting the install in my new 91' 200 20Valve
- They Fit !!!! and Mark P. is a god. =}
- What type of box for my subwoofer?
- Help! Amp install kit question
- Focal vs MBQ
- Esoteric Audio amps
- Search down, scrolled 10 pages no luck need help with phone integration
- Would anybody be interested in a broken CD changer for the Delta radio (expensive one) for cheap?
- Soundhabit?????
- AM Reception Sucks So Bad, I'm Considering a Ford!
- Can a Sony headunit control a factory fitted CD changer ?
- Want to replace speakers in my 2000 S4. Suggestions?
- new system plan....
- What's the difference between code 000115 and 000211 on a A4 1.8T stock head unit?
- Anyone know if Scosche makes a head unit adapter for 2000 Non Bose Symphony?
- What have you used to remove the 2000 Symphony (Non Bose)
- St Louis A4, what exactly are the problems you're having?
- mounting aftermarket battery in 96 A4
- How do i install a SUB on a NON-BOSE concert radio?..................more
- Symphony Radio Codes
- my site
- Where is the problem in the Delta system?
- MB Quart Adaptors Suck!!!
- Looking for stereo info on 1991 Audi 200T...anybody?
- Anyone here have a problem with their cd-changer coming loose?
- Anyone who has installed a handsfree kit for their phone.
- Does the '01 non-Bose system have pre-amp output? possibly RCA?
- To change factory head unit or not..........
- installing cd changer
- Factory stereo locked???
- Audi TT Radio Interference
- Wanted: CD Changer for 96-98 1/2 A4
- can any of you tell me if this setup looks good?
- yet another dilema, please help
- Anyone use 4-ch Rockford/PPI/PG amp for subs AND components?
- suggestions on box setup please!!!
- Mark P, anyone? should i directly connect all my audio equip. to stock harness remote line?
- RV2.7T - Speaker sizes in 2001 A6
- HOW MANY SPEAKERS IN 2000 S4 AND WHAT SIZE?
- Just received newsletter from Bang and Olfsen..they showed new ICE at Paris Show...anyone with info?
- Fixed the rattle in the rear deck.
- porsche system
- Is there a dash kit for the 01 a4 yet or should I just give up? Thanks.
- Hey MarkP, question about your fake faceplate
- News Flash - Symphony sucks in my '01A4tq
- did anyone integrate guages (boost and etc) with their custom system/faceplate?
- selling sony es amp almost brand new 7547
- Clair OEM cd changer??
- Removing rear speakers?
- Factory CD Change Unit
- Focals vs C D Tech for front doors?
- Aiwa CDC-MP3 min-review
- GALA, mine seams ineffective
- rear door speakers
- Bose subwoofer control in 2000 A4 Avant
- Is tweeter failure common?
- I got a new headunit although trip computer now does not display, stereo..is there a way it would ?
- Does anybody know the URL for Focal ?
- Alternator whine on 90 quattro 20v
- 6.5" speakers on the front door panel???
- Blau Munchen on the way...
- Where are you guys grounding your amps?
- Alpine System In a TT
- wifes cabriolet needs a new stereo. What choices have I with red backlighting
- Install tips for Kenwood Excelon 915?
- What are ways of stopping rattle besides dynamat, its just too much $$
- CD Changer Inputs as "AUX"?
- JohnP, what is this wonderous system that use the stock head unit. I may have to reproduce it.
- Opinions on this speaker vs. separate components?
- Optima batteries Red top vs. Yellow top(deep cycle)
- Does anyone have Diamond and Phoenix set-up??
- Where to find the best price for Phoenix Gold Amps & accessories?????
- Where to find the best price for Diamond Audio Speakers?????
- What are the best 8" free air subs ?????
- how do two free air 10w6's sound as a setup in a A6?
- Mark P, I sent you 2 e-mails, did you receive them??
- Where can you buy xtant amps at a discount?
- CD Changer for '01 a4
- Should I spend more money on my car system ?
- Does anyone have any problems with burned cds and base response
- I love having my sub face out towards the rear but how can i get rid of some of the rattle....
- JohnP, PapaJohn, others: Using Blau harness and stock rear speakers
- Integrating an amp with factory head unit.
- Anyone have experience with mailordering stereo? (more)
- C D Tech or ADS Speakers?
- IVA C800 vs P907 opinions anyone?
- 98-99 Stereo head unit sizes Single DIN?
- What is the name of the head unit in a '01 A4 with Bose(Delta?)
- Look for Greg White with question about his splicing into changer controls. You Around?
- CENTER CONSOLE??
- CENTER CONSOLE??
- Really cool gadget for your sound system for sale (more)
- Factory Cd changer for sale in Toronto.
- Head unit depth
- Mark P that is a amazing box..
- Neo Hard Drive Install Question! Urgent help needed where to Patch In!!
