PDA
View Full Version : Audio, Video and Security Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. JL audio makes stealth sub boxes for the A4 96-99 will this fit my 2000 S4?
  2. What's a good amp for around $200 that will power two 10's in a sealed box efficiently?
  3. Tested new setup and the tweeter hisses when amp is on... even with RCA's disconnected! (LONG)
  4. sub enclosure
  5. Upgrade 'path' for stock '02 S4 Symphony (non-Bose) system?
  6. FS: Reply to thread if your interested..
  7. Worth the $$ to spend a couple hundred bucks on Phoenix Gold RCAs?
  8. Bose system specs???
  9. Aftermarket head unit and Bose speaker/amps
  10. Subwoofer quesiton
  11. Help.. My Radio reception is bad with new head unit...
  12. Aftermarket Head Unit + Trip Computer question
  13. Alternator Whine Help Please...
  14. Consider selling PPI PC650 50x6 amp and 2 JL 10w4's...
  15. Old laptop for sale?
  16. After Market Head Units
  17. Can a subwoofer be added to the factory Bose system? I found the FAQ saying that this can be done..
  18. Rear speakers need adapters? Make my own? Mount to the deck?
  19. A4 Avant Rear panel removal questions
  20. Changing to eciplise head unit in a S4 can i keep the stock amp?
  21. Where to mount GPS antenna....?
  22. Input impedance
  23. Tweet question @ attenuation
  24. Having problems with my front passenger speaker....
  25. Anyone make their own MB Quart-style adapter?
  26. How to "clean up" my wiring...need advice...X-Post from A4 Forum
  27. Infinity "Basslink X" pictures, anybody?
  28. My new stereo mods
  29. Basslink problem
  30. i have a new head unit and a four channel amp, can i wire it up to the stock "bose" speakers?
  31. A6 Bose rear spkrs
  32. Focal Polyflex HC series speakers for the rear deck?
  33. anyone know how to remove the passenger side kickpanel?
  34. 2000 A4 Pic's of DIN install?
  35. line input to the Bose headuint.
  36. CAN-BUS systems - Changing head unit ???
  37. Can someone tell me what the standard frequency slope is for good sound with all music...
  38. A4 Radio Harness Q's
  39. engine noise problem, help please
  40. how much power does the 2001 bose unit feed the fronts....
  41. My symphony stereo on my A4 went dead. What happened?
  42. Upgrades - NE1 added tweeters to the OEM Bose set up ? (m)...
  43. Question about Pioneer DEH P9300 deck
  44. motorola integration...
  45. the wonders of solder..................
  46. ADS 345is Speakers..Do I need adapters??...
  47. 8 ohm speaker use
  48. Will 4" speakers fit in the a4 front door pannels without mods/adapeters?
  49. Sony/Alpine
  50. Have a few questions about adding a custom sub box w/2 10's....
  51. just got an Eclipse A/V headunit.....................good?
  52. Bose Radio Display Question
  53. Just switched to a rockford fosgate 500a2 amp for my sub and minor problem...
  54. Has anyone tried this
  55. To those who have Focal components
  56. I realize this isn't the classified but I'm thinking about selling my S4.....more
  57. where is located the relay of alarm horn?. thanks
  58. Will I need an adapter.....
  59. Do sealed boxes produce the same amount of trunk rattle as ported or bandpass boxes?
  60. Need advice/help on choosing an aftermarket headunit
  61. I know it's not the best, but want to replace just the speakers. Suggestions??
  62. a/d/s 345is component
  63. Morel Hybrid installs?
  64. Just got an MP3 Playa and I love it!
  65. X-post: I need a concert stereo...please help if you can :-)
  66. a4 delta radio question.......
  67. CD changer installation
  68. looking for opinions on a spare tire installation
  69. Anyone have MBquart front speaker adapters they want to sell?
  70. Anyone put their CD changer somewhere other than the trunk ???
  71. Blau Line-level adapter installed, lessons learned (ground taps worked)
  72. Anyone ever used Aura Bass Shakers (or other linear actuators)?
  73. line input to the Bose headuint.
  74. Neo Jukebox and BlitzSafe
  75. need to see more sub installs!
  76. What do I use to make my sub stay in place?
  77. Who's is this?
  78. rear speakers for 98
  79. 97 a4 delta added cd changer, but it only plays out of left side speakers? anybody else have this?
  80. where i can find better then BOSE 6.5" subwoofer.TIA
  81. Anyone modify the JL audio stealth box itself to fit 99.5 and up trunks
  82. Can I add a Xover to existing factory wiring?
  83. Precision Power Sub Amp For Sale
  84. 2001 Symphony HU, BOSE features On/Off? How?
  85. Integrating Valentine 1 audio output into BOSE
  86. paying retail
  87. What are some preferred grounding points in the trunk of an A4 sedan? Thanks.
  88. Motorola Integration?
  89. Anyone run their RCA's down the right (passenger) side?
  90. Will the MB Quart adapters work fine for 5.25 Diamond m551s for the front?
  91. Anyone have a Concert headunit 'spare'?
  92. the cd changer in 98.5 bose is made for alpine or blaupunkt ?. thanks.
  93. I need to see your DVD set up!! I'm planning on putting a DVD in the center
  94. Anyone from San Luis Obispo Area want to meet other audi enthusiasts?
  95. i'm trying to figure out if my motorola v.120 phone...
  96. Dash Kit for 2001 A4
  97. cd changers
  98. Replace factory head unit with after market, but keep Bose + factory CD Changer
  99. '99 A4 front/rear speaker upgrade
  100. S4 Head Unit replacement
  101. do I keep my PPI or get some Xtants.. (more)
  102. a4/s4 seperates? anyone have 3 ways?
  103. 96 A4: installed Lightning Audio 75x4 amp, Blau CD head unit, Cerwin Vega 5.25 comp, CV 6.5 in deck
  104. Opinions wanted on a proposed (PPI/Focal) system... (semi-long)
  105. can I do this?
  106. Need help with wiring a custom panel fro my radar detector!!! How do you
  107. 97 A4 Speaker Wiring Help!!
  108. Anyone have the Escort 8500? What do you think so far?
  109. pics of my system (still not complete)
  110. 98 bose a4 system speaker upgrade
  111. Look in my picture poster gallery for what i have for sale..
  112. Help in restarting '90 100 radio
  113. Anyone make a custom subwoofer enclosure..
  114. ATTN all '96 A4's with Aftermarket Headunits
  115. cd changer is crazy
  116. X-Post: I need some information on an Amp and speakers...
  117. Vent mount holder for cel phone (or eMap)?
  118. How do i take out the rear deck? Is this how i remove rear speakers?
  119. Guys, I need some audio advice
  120. Rear Speaker Distortion From Rear Speakers After Adding Amplifier
  121. Has anyone hardwired thier Escort 8500?
  122. Install of cd hanger
  123. Where in the trunk is the stock cd changer mounted in a 97 a4 with the delta radio?
  124. audi 200 audio problem
  125. High/Low - Blau Adapter Question - Audio Gurus Please Read!!
  126. what is the part# for a 2000 S4 headunit, the BOSE stereo upgrade one
  127. getting Symphony stereo display on Console display
  128. How Deep are the stock speaker locations on the A4?
  129. Mad Stereo Stuff - Complete System - Top Quality Components
  130. help wilth pulling out factory radio
  131. Dealer says the MB Quart Front Adaptors won't fit Focal (more)
  132. 2001 Bose system questions...
  133. Not a single Audi A4 in Kicker's "hooked up" section of their site
  134. Noise fixed! It was a defective line level adapter.
  135. Small home cd player?
  136. Want to add sub/new speakers/amp while keeping.....
  137. looky here.......
  138. I'm gettin a system, PPI amp w/ 2 12's, in an open enclosed box from my friend...
  139. Installed a Pioneer Premier DEX-P9 in my car this week (pics)
  140. audi chorus code
  141. Help, want to add a amp and subwoofer to stock concert unit
  142. 6 disc changer not working... (X-post from A4 Forum)
  143. For those who have 62.3i Kappa's in their rear deck... did you need MB adapters?
  144. Stock Bose Amp Info?
  145. Need changer for my Delta
  146. Looking to upgrade Bose system, looking for advice.
  147. Symphony noise update
  148. What's your take on this dilemma??
  149. Can I use the factory Bose speakers & amp w/ an aftermarket headunit???
  150. NE1 contemplating Sirius Radio or XM satellite radio?
  151. Added 4 channel amp, having lots of noise problems
  152. Bose system conversion
  153. Audi TT radio stopped working (concert radio with autochanger)
  154. FS: Boston Acoustics ProSeries speakers/sub and MTX amp!!
  155. After bad experience, still looking to upgrade OEM stereo. Can anyone recommend........
  156. Hey group quick question I have $250-to $300 to spend on a new stereo any sugg.
  157. Uh oh, I've got a problem with rubber !!!
  158. Cross-over point of rear deck 'subs' in A4 with Bose?
  159. sub woofer question
  160. question about blau adaptor used on bose system
  161. Did anybody moved Concert headunit with CD changer to older A4 with delta ?
  162. What kind of little doohickeys will I need to add amp & speakers to non-Bose?
  163. Help, the whole right side speakers of the BOSE aren't working (long)...
  164. I am selling one set of MB Quart adapters for the front door for .....
  165. After having my Neo35 for 7 months i finally got installed in my car...
  166. Homelink Question
  167. cd err1 message
  168. For all of you with alternator whine and the symphony HU...(long)
  169. bose sound system in '91 100
  170. What's the best FM modulator? [If there is such a thing as a BEST one ;)]
  171. Any good pix with an aftermarket headunit? I am looking at a new headunit with a CD player,
  172. OK everyone...please read this and give me your input on the situation.....
  173. Speaker level inputs
  174. General power wiring question (Neo Juke & Passport)
  175. Any interest in Harnesses for the Audi changer/nav/preamp connectors?
  176. Anyone tried the Kicker PSR100 powered sub?
  177. Factory cable for '98.5 A4 Avant CD changer
  178. Avant Bose Upgrade
  179. Can I put in a factory Bose head unit in place of my non-Bose head unit?
  180. A4 Bose rear deck speaker fix. ( If you have a Bose system you will want to read this)
  181. 2001 radio
  182. Anyone use a Blitzsafe adapter on a Delta unit?
  183. reception on a 93 90S is terrible...
  184. speaker questions (delta system)....
  185. Hooking up Aftermarket Deck to Bose System(long)
  186. A4 Symphony hidden equalizer -- thanks!
  187. new a4 concert radio
  188. fuses for amp
  189. Is there an optimum place to mount Xovers in the front doors?
  190. CD Changer skipts when I turn.
  191. what am i getting myself into with my 1993 100? (more)
  192. QUICK: What size are the rear deck speakers in my 2001.5 A4 w/o BOSE???
  193. THANKS for the amp suggestions guys! Here are some pics, etc....
  194. where can i buy cable for alpine changer?
  195. Audio system for sale
  196. If you had $1500 to do your entire audio system....
  197. Anyone hook up an amp/speakers/sub to an S4 with .........
  198. Is there ever going to be an adapter for the 96-97 A4's to tap into the cd-changer for aux inputs?
  199. Those of you with Blitzsafe Adapter....
  200. What kind of amp would I need to handle 3-10"s that handle 250w RMS each??
  201. how much should i sell this stuff 4? (NOT AN AD)
  202. A6 Avant amp question and speakers
  203. mounting hardware for the CD Changer
  204. Has anyone mounted a sub in the spare tire well? any pics?....
  205. i'm looking for the concert series stereo owners manual.
  206. Nubbins antenna?
  207. 2001 VW oem (panasonic) changer in 2001.5 a4 non bose?
  208. Does Blaupunkt make the Audi Concert head unit in my 98.5 A4 Non Bose?
  209. Quick! Need amp suggestions
  210. Help! My radio is acting bizzare
  211. S4 Avant Bose sub woofer and amp location?
  212. If I wanted to get subs in my car, do I HAVE to get a new head unit?? TIA
  213. Subwoofer mountings
  214. Any recommendations on a sealed box?
  215. What would be the best way to spend $300?
  216. Foglight question...
  217. removing delta stereo, help understanding faq...
  218. MB Quart door speaker adapters are overrated in this forum...
  219. Late model A6 Avant subwoofer location and venting?
  220. Mounting Amps upside down? (more)
  221. Opinions wanted on my "new" stereo...
  222. Has anyone got a wiring diagram for the audio bits on the audi a4 (1996)
  223. Repost: Where to buy Basslink in (Vancouver) Canada.. thanks
  224. Is there any faqs to install/connect a mp3 player??
  225. How many people are intersted in getting the MB Quart adapters...
  226. rear speaker wire assignments
  227. Stereo installer had to cut metal to install front components... now the door is rusting!!!
  228. New 6 stack cd changers
  229. what do you guys think of the sony xplode cd player thet folds down and has an active black display
  230. Custom Audio stuff for A4 and other thing gotta sell Anyone interested
  231. how many pre-amp outs?
  232. CD Changer Cleaning
  233. CD Changer Mounting
  234. Help! Anyone know a good shoppe in Orange County?
  235. Anyone have access to front Quart adapters? Rich's SOLD OUT!
  236. Has anyone ever used one of those radio transmitters to use their MP3 or portable CD player in their
  237. Idea I posted in the TT Forum
  238. Revisit Nokia 61XX installation for TT roadster
  239. Does the 98.5 Audi Concert Bose head unit have rca inputs?
  240. Cannot get MB Quart Adaptors anywhere!
  241. Changer that works with delta stereo???????
  242. Thinking of installing Clarion LCD (VRX610). Is there a wiring harness for the A4 to make it easier?
  243. System getting installed today and I'm psyched/nervous...
  244. radio gets no reception!!!
  245. My bud has a 3 year old Eclipse MD changer...
  246. Anyone hook up a NEO MP3 player?
  247. FS: Car Multimedia Components
  248. Touch-screen dvd player
  249. looking for Basslink in Vancouver .. any ideas?? urls?? thx
  250. show me your sub/amp intalls in your A4
