PDA
View Full Version : Audio, Video and Security Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. Are they still producing updated nav info for RNS Navigation Plus?
  2. Need help troubleshooing speaker cutouts
  3. Dip Switch Settings on Dice i-audi-r ?
  4. Sound goes soft then loud then soft and on and on
  5. Paging Sir Duke Avincar the third
  6. Thinking about a new or used double din head unit...looking for thoughts/impressions/suggestions..
  7. need help choosing-pioneer avic d3 or kenwood dnx7100
  8. Where to source adapters for stock h/u to add external amps - B6 & B7
  9. 2004 A6 AM Distortion
  10. B6 A4 head unit problem: the right speakers do not work when in CD mode, but they do work in radio..
  11. BOSE RNSE Upgrading Sub (B7 A4)
  12. I've STFA, I bought a used Symphony II to replace my Symphony I
  13. Any ideas on how to install 5"1/4 speakers in front doors
  14. If only DICE can make an HD Radio Interface for Audi, It even integrates IPods with TEXT Support!
  15. Parrot CK3100 volume issue with Bose Symphony
  16. Paging Avincar -- new Alpine headunits
  17. Ipod adapter for the car, that will work with bose system
  18. A6 Stereo Improvements
  19. Retrofit bluetooth in RSN-E equipped cars..
  20. How to wire up front door components on A3
  21. Tweeters or Midrange more important?
  22. Getting Symp II radio out of allroad...
  23. I installed some Alpine SPS-17C2 6-1/2" 2-way car speakers up front and I can't tell a difference...
  24. Suggested improvements for Audi symphony for my B7 2007 cabrio....
  25. do any of you know where i can buy this LG wall mount projector in the US?
  26. SUBWOOFER
  27. Dice unit: which switch to enable ipod mode (instead of "dice" mode?
  28. Icelink question - how do I split out video?
  29. 6 x 9's?
  30. my ipod integration in a 2007 A4 with OEM XM
  31. in car computer and touch screen questions
  32. In-dash Suggestions????....
  33. CD Player Stopped Working
  34. Ipod adapter for 07' symphony II+ , Bose radio
  35. Who runs a separate battery for the stereo system?
  36. Anyone have a Hawaii nav disc?
  37. What 5.25" Components are you guys liking for all types of music @ 150w RMS/ side?
  38. Paging avincar...install pending...
  39. RNS-E SD Card Reader formats
  40. When overcast skies FM radio gets 2 stations total!
  41. Paging Sir Lord Avincar
  42. symphony II cd error
  43. Looking for a good stereo shop around San Diego, CA that knows what they're doing
  44. How do you hook up BT Parrot Kit in car with Onstar?
  45. Anyone know how to fix a punctured cone on a subwoofer?
  46. 1993 100cs radio
  47. Need help! How to remove b-pillar trim panel??
  48. On my '00 S4 I've determined that on certain songs that I'm getting vibration, not from the rear
  49. Delta CC telephone mute + speaker connector
  50. Upgrading PhatBox to 40GB -- files corrupted
  51. Looking for a good amp to run a 10W6 (400W) on factory Bose...TIA
  52. N-Bose Symphony 2 B7 - Can I rewire the rears directly to an aftermarket radio?
  53. On the Sym II, what is this weird yellow connector next to the antenna connector?
  54. Have cut down the interferance but not fully.
  55. needing help with hookin subs up with stock headunit
  56. My Audi's trunk installation
  57. Audio system testing
  58. MMI, bluetooth and TV install help in southeast?
  59. how much do 20gb phatboxes go for these days?
  60. Can I use my 2003 VW Jetta Phatnoise with my new 07 A4 3.2?
  61. Interference and Safe Mode.
  62. VSS & FM Antenna - Avic Z1
  63. RNSE install is just about complete..Special thanks...
  64. mmi problem after installing a sub onto the factory bose system
  65. iNNo in my TTQC?
  66. Difference between symphony 1 and 2 and front door speakers
  67. Dynamat/Sound Deadening Pro's.... Opinions Needed.
  68. Sirius Satelite Antenna Routing
  69. Can just sub be upgraded on '06 A4
  70. radio eletrical problem need HELP!
  71. Need some help with radio install.
  72. Impressed with symphony headunit, but not speakers (longer than I wanted)
  73. Upgrade symphony system (Add Amplifier)
  74. For those wanted an update, JL H.O. Box, Power1000 25 to Life, Surprise ending! Help needed!
  75. Audi Concert problem..
  76. Would this work?
  77. Radio Controller Module Convert to/from Bose
  78. Radio Stuck
  79. Radio Stuck
  80. Aftermarket Single DIN Navigation Unit Install
  81. Help - Concert with Icelink Plus
  82. Any "car audio" forums where I can get recommendations for local shops to get some work done at?
  83. Need help with Eclipse CD player and CD changer
  84. 2006 A4 Bose Wiring harness HELP
  85. Pioneer double din units with nav what are there differneces
  86. concert 2 help.
  87. i want to change the ground location of my symphony HU
  88. xm wire run to center consol?
  89. PhatBox software (from PMM 1.87 to PMM 2.30) update problem.
  90. Anyone have stock B6 tweeters they want to get rid of ??
  91. Does anyone replace the stock rear woofers on the B5 S4 with anything better / more powerful?
  92. Satellite Radio (XM) for 2006 AUDI A4
  93. need help from you stereo experts
  94. Cannot upgrade Firmware on Icelink Plus current is 2.05- Anyone using it with RNS-D?
  95. Audi upgrade for Bose CC ?
  96. Need to replace the crappy aftermarket stereo that came with my 04 Tahoe
  97. Anyone know where I can get an antenna end...
  98. Does the concert head unit require a code? I was just curios since some have repoted not needing
  99. Single to double din conversion, has anyone done this? I have a 99 a4 b5
  100. USB to OEM head Adapter
  101. Looking to purchase an Apline Blackbird...any thoughts... The only reasons why i want to buy this is
  102. New HU on a BOSE system
  103. installing Kenwood sub...power?
  104. Never thought a Concert I could sound so good - Thank you Helix AAC !
  105. What Ipod Video Firmwares are supported through the Dice Integration Module?
  106. 1999 A6 Concert with Bose, AllData says Speakers are 4 Ohms
  107. Need to replace Phatnoise cable - DIY options??
  108. Nav System Suggestions???
  109. C5 A6 - Phatbox will not fit in Glove compartment.. Shroud cannot come off because
  110. Upgrade HU in '04 TT w/Bose
  111. AVINCAR
  112. Need help with amp install...
  113. Aftermarket Head Unit Upgrade Help Needed
  114. How many of you run power cable through ECU box to get through the firewall?
  115. teddybgame
  116. Help, can't get radio out and keys are in the slots
  117. Friend of mine has a few blown speakers in her A4. What are the optoins?
  118. Does anyone have experience with this NAV unit?
  119. Can the symphony radio play mp3 format?
  120. Strange headunit problem..
  121. Question about Bose amp before installing new hu/tv
  122. New audio system? Please anyone who as done that need your input! :)
  123. 99.5 A4 CD Changer Trunk Brakcet - FREE
  124. Any S/W patches exist for Gen 3 iPod to make it work with AMI?
  125. rear speaker problems in '99 A4 non bose
  126. delta cc locked
  127. Need to replace my stereo 90 qv8
  128. Any planned touchscreen capabilities for MMI in the future?
  129. i have a s4 b5 body i whant to change the rear deck speakers they are rattling
  130. radio stuck...what next?
  131. Looking for a new battery. I killed my Optima Red Top by accidient.
  132. RNS-E Installed Perfectly!! Anyone want a DICE?
  133. Mp3 Wma Wireless Fm Modulator
  134. Powering a switch
  135. Problem with aftermarket Stereo on B7 with NAV and BT
  136. I have a rare opportunity to buy some A/D/S 325is components(in Box), don't know how they compare
  137. Problem after installing aftermarket stereo
  138. 03 allroad steering wheel control question
  139. Can you put a 2002+ radio into a 2000 C5? Is it plug and play or can not be done? Thanks ;)
  140. iPod on a 2007 A4
  141. My Audio Setup
  142. B5 Symphony Radio Vag coding will bose or debose your stereo
  143. blown speakers need some help
  144. Looking for custom B5 S4 kickpanels
  145. got this deck going but im struggling with the Ebrake overide.
  146. help wireing my Alpine deck
  147. dock nano in icelink craddle, but ipod remains paused and won't respond to any input...any ideas?
  148. NAV Locks after installing newest 2007 DVD
  149. does the icelink only read 100 songs per playlist?
  150. n00b a3 wiring question(s)
  151. Can someone shoot me that link to the Symphony 2 radio wiring diagram
  152. Anyone familiar with the Alpine W200 interface... would like to make some changes
  153. How to do audio out from aftermarket GPS to Symphony head unit with auto mute
  154. ? about Audi Navigation/Bose system
  155. Looking to use the stock GPS antenna (or receiver) to hook up to my PC. Questions...
  156. Radio signal on new headunit
  157. rear speakers...
  158. Deck Kit ?? and Radio signal question
  159. upgrading a bose symphony to aftermarket amps/speakers, do i want bose setting or non-bose?
  160. JL Audio High Output Boxes (H.O.), Is it worth it? Has Anyone Heard what they can Do. Please DO TELL
  161. Wondering if anyone's done this...
  162. Audi ipod adapter problems
  163. Will these ebay speaker adapters work?
  164. Does B7 Nav+ permit bird's-eye view?
  165. 2003 Rear Speaker Loss after Ipod Adapter Install. What happened?
  166. What is the difference between the Bose Symphony II and the Audi Symphony II?
  167. X-Post. My experience to date with the Dension GW500 MMI iPod interface
  168. Can you hook up two amps to one cap?
  169. Will the ConcertII headunit control a CD changer or iPod interface?
  170. New Symphony.
  171. I need help unlocking my factory stereo
  172. Has anybody installed one of the new Alpine headunits with red illumination?
  173. Headrest monitors (wiring)
  174. Colour RNS-E
  175. Diamond S600 Crossover Question
  176. Aftermarket single din head unit pics installed in my B7. (Minor BWW)
  177. All I wanted was a radio......
  178. Upgrade paths...
  179. Interface adapter for Delta CC to Alpine mp3 changer.
  180. proper gain setting for icelink and symphony radio?
  181. Sub Porting Question, C4 S6.
  182. Does an A3's Bose CD Changer play WMA CDs?
  183. Best Buy Techs are S*&$#)
  184. Sirius to buy XM...Might be a good time to buy the cheaper XM module..
  185. Any suggestions for a portable GPS?
  186. General update
  187. OT... any one in upstate ny with a used MPC to get rid of?
  188. RNS-E MFSW Control Mod Group Buy???
  189. Has anyone upgraded the audio on a (B6) 2004 A4 or S4?
  190. WTB Sirius module for 2004 A8L
  191. Is it possible to get a B5 Symphony II faceplate
  192. Speaker part numbers.....
  193. VW Icelink
  194. Upgrade for 2005 A6
  195. Is it possible to install a Concert CD head unit in a early year '98 a4?
  196. Symphony II w/ Bose & DICE for iPod - poor audio quality
  197. Does anyone use a TomTom GPS to control an iPod?
  198. Need to Borrow Radio Removal Tool...
  199. Cabriolet Ideas?
  200. Dension icelink gw400 work with in dash cd changer on 2003 A4?
  201. Phatbox installation for 2002 a4
  202. Can I swap the original Delta head unit from my 96 A4Q 2.8 with a concert2 CD player form Europe?
  203. My rear speaker is blown
  204. icelink ipod cable, where do you buy it, or does anyone have an extra?
  205. Power Antenna Replacement - Help
  206. X-Post on Nav issues
  207. 3 questions about my new A4's audio
  208. Those with the 8500 x50 (or people with electrical experience)...
  209. would an aftermarket HU install affect the functioning of the central convenience module?
  210. Glovebox cd changer turns off after 45 mins!
  211. im close to finding out why my amp is shutting off.
  212. A3 RNS-E in a S4
  213. A8Q audio/speaker problem...
  214. Bad wire or bad speaker?
  215. Whats involved in addinga sub to the stock Symphony radio in 2000 S4?
  216. ICE-LINK Help: IPOD plays but radio buttons no longer work.
  217. Has anyone run a DLS W712?
  218. Ayone here have any experience with this line of Blaupunkt Subwoofers?
  219. Component Speaker install Bose 2002 A4 B6
  220. HELP - Phatnoise Installation
  221. FOR TEDDY B or others: 2 questions
  222. any way of getting rid of- or turning down the effects of the
  223. XM Radio Installation
  224. Lessons learned with updating firmware on icelink
  225. help - recalcitrant symphony ii unit
  226. Shameless plug for TeddyBGame...
  227. stock speaker question....
  228. Concert 2 assembly after market on A4
  229. anyone have a panavise for a 2001 S4?
  230. Strange things afoot with Concert I
  231. ipod question - installing a 5G ipod in a 2000 S4
  232. a few noob battery questions
  233. Retro Patch Cord for 98-99 models with Delta radio
  234. Any thoughts on the Blaupunkt Keywest MP36 head unit?
  235. B5 2001 S4 Avant sub questions
  236. Symphony 2 and Ipod and Bluetooth
  237. Griffin Smart Deck and Symphony 2
  238. problem with deltta cc
  239. Ipod Ice Link Plus Cable Needed for Symp II
  240. i need bluepint for compustar 2wss-as?? help my 2001 s4
  241. Custom Subwoofer help
  242. Has anyone hooked up the ADR V1 interface via the CANBus yet????
  243. My new setup, any suggestions?
  244. Where to buy DLS in the states?
  245. iPod interface for RNS-E...NEED HELP
  246. Alternator rebuild, whats the most amps i can get out of a stock casing?
  247. where is a good ground in the B5 trunk? and what kind of washers are conductive if i need to use one
  248. MiniDisc Changer
  249. looking for a way to integrate Sony Ericsson phone with car deck in order to play MP3s and
  250. Sony 12" XS-L123P5 Ported Box Question
