PDA
View Full Version : Audio, Video and Security Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. Sd cards in RNS-E
  2. Different OEM iPod Connectors
  3. Replacing Concert II+ in 2008 A3, harness/wiring details?
  4. Desion Ice Link with Symphony 2
  5. wiring schematic bose amp?
  6. lines out in Symphony II ?
  7. How To Programme Audi Concert Sterio For Phone
  8. couple of audio questions/ideas
  9. Factory Bose stereo, stuck with PHONE code on display(2001 A4 1.8T)
  10. Stereo popping sound... will a floating ground adapter work?
  11. 6 disc DVD or NAVI
  12. Navigation + AV + camera on the new radio Concert and Symphony
  13. B6 Replacement Speakers
  14. 2001 symphony bose in safe mode, code from the book not working, what next
  15. RNS E NAVI DISC FOR US
  16. 2001 Audi TT Roadster Subwoofer
  17. Sub Install
  18. No power to front doors' switches or door edge lights
  19. Kufatec, CAN wiring?
  20. Instead of a huge phatbox with unneeded huge heatsinks...
  21. toslink / sp-dif / digital out from stock head unit?
  22. Labor Day Specials from DICE Electronics save upto 20% and a FREE cradle
  23. A5/S5 B&O system - retrofit to older models (i.e. C5 chassis cars?). Also, DSP amps?
  24. SOS: I need to replace my Phat Box since it's no longer supported. What other choices do I have?
  25. How do I hook up a MP3 unit/USB drive to Traffic Pro?
  26. Looking for someone to tune/adjust my audio system in Denver or Fort Collins
  27. 08 a4 problem - steering wheel buttons....
  28. Traffic Pro not recognizing Phatbox
  29. Factory iPod is weak!
  30. Considering the pioneer AVH-P4000 for my '03 A4... couple questions!
  31. Amplifier ground point ? Noice problem.
  32. Bose radio for 2001 A4 ... worth what?
  33. Paging Travis@DICE....
  34. 5speed6 NEED YOUR ADVICE
  35. Problem with Audi radio - Delta CC
  36. Discounts from DICE Electronics offer till August 31,2008
  37. Anyone know what sort of connector is used for the sirius antenna
  38. Questions about the Kenwood DNX5120 & 8120
  39. connect sat radio, cdc, player, steering wheel controls all at same time on symphony
  40. Pioneer Avic F700BT in a C5 A6 with Bose?
  41. Bose System?
  42. Dear XM Subscriber,
  43. Video In Motion
  44. Upgrading the audio in my mk1 TT roadster. Any suggestions?
  45. Radio on, but no sound. Assistance request
  46. anyone know of a way to integrate the prewired optional phone...
  47. iPod interface for your Audi Cars
  48. Receiver advice
  49. i can hear my engine
  50. what is needed in order to upgrade speakers and amp but keep stock HU?
  51. So I;m swapping out my ....
  52. Issue with amp install
  53. WTB: Sirius Satellite Radio 8E0....593D+
  54. Help with B5 Avant rear speakers
  55. Navplus is down!?!
  56. Has anyone ever had an RNS-E head unit repaired?
  57. FS: Audi symphony II for $90
  58. New A3 no fog light setup
  59. Amp repair company in NYC metro area?
  60. 1995 A6 Radio and Front door speaker Install
  61. Need more help - The wiring diagram for the OEM CD changer cable calls for certain wires to be
  62. Need help! Screwed up a connection in the back of the Symphony II headunit - how do I remove the pin
  63. 1997 A6 Avant Sub Repair
  64. Steering Wheel control and instrument readout
  65. Sympony/iPod sounds terrible
  66. Getting desperate.....Anyone with an '04 A6 S-line with Symphony II...
  67. Radio not working A6 Quattro 2004
  68. Help me order the right part
  69. Bose in 2001 allroad, just bas
  70. CD changer for 2006 A3
  71. Audi Gamma Bose Radio
  72. Symphony II Saga.....
  73. PLEASE HELP!!!! Strange Symphony II Swap Out Issue
  74. With some fine tuning, just a aftermarket HU and 4 speakers can sound pretty good.
  75. Installed "New" Symphony II but no sound or volume??
  76. Delta CC - can I put a Concert in its place?
  77. BOSE with aftermarket HU
  78. Help!!! Can't get radio out!
  79. Upgrading my Kenwood
  80. Replacing front door speaker '99 A4 (non-BOSE)...
  81. High pitched whine from speakers
  82. Dead radio. Checked the fuses, everythings ok but no power to Radio.
  83. Thoughts on Clarion marine head units (M475)? Looking for input...
  84. adding CDC to symphony/RNS-e with OEM cable help?
  85. DIY sub/amp for b5 s4 w/ Bose and stock h/u
  86. Anyone know how the C5 A6 subwoofer is ported into the cabin?
  87. For those that said the Metra kit is one time use only, it can be removed.
  88. audi a6 2.7t deck replacement
  89. Audi 1999 A6 Concert I replacement
  90. Any decent non-nav double DIN HU for 08 A4 w/ iPod and BT?
  91. Sound for backup sensors
  92. Has Nakamichi jumped the shark
  93. 2 questions
  94. Concert II+/III bench power hookup?
  95. Radio not working color code request. 92 100 s
  96. MP3 + Bluetooth
  97. Need some help getting my sub to work....
  98. Will a Symphony II+ HU (B7 MYs) work with my '00 S4 (plug and play)?
  99. is member avincar still around?
  100. audi 5000 speaker cutout
  101. Amp in 08 TT, non Bose, does the amp turn on using CAN Bus or +12v?
  102. 2003 A4 w/symphony II
  103. RNS-E irksomes
  104. Where can I find replacement tweeters for a b5 s4 w/ bose?
  105. Am after a double-din cage and double-din climate control unit for a B5 A4/S4.
  106. pins on Sym II+
  107. 97 Delta CC -- Volume knob dosen't work properly -- suggestions?
  108. New TSB issued regarding Bose systems on 2004>A4/S4 and 2002>2005 TTs....
  109. iPod on new A4 (2008/2009) Concert
  110. Is dension ipod adapter for panasonic radio compatible with Symphony II - (2003 A4)
  111. iPod Adapter for my 2007 A4
  112. X-Post from 8J TT Forum... (replacing bose w. JL Amp / Focal K2s)
  113. A3 alternator fuse
  114. ICE upgrade A6 2005 (new shape) with red screen and basic MMI
  115. Want to go back to stock. I have the Symphony HU but not the OEM rear speakers.
  116. Help!!! Trying to get rid of Static Noise on XM install!
  117. A couple of speaker replacement ideas
  118. New stereo install pics...
  119. 98.5 Avant door speakers
  120. Volume varies by source -- any solution?
  121. Who retails & installs Audisson and Hertz components? ...
  122. Any constructive opinions on u-Dimension??
  123. Guys, I need a reco on a sub.... my plan has fallen apart [updated]
  124. aftermarkt hu question
  125. WTB audi 01 s4 symphony radio
  126. I've STFA, but can't seem to find any installers dealing with Audisson or Hertz near Baltimore,MD...
  127. Has anyone ever installed a sun visor monitor in an A4 or other model?
  128. Bose Symphony intermittent sound??
  129. B5 A4 aux input cable - which one?
  130. Need help with Sirius upgrade in 2005 A6 - kinda long.
  131. Was going to jump on AVIC- F700BT but no im weary...
  132. Bose Amp turn on pin for Symphony II+?
  133. hu cd player, trunk cd changer, sirius, and steering wheel controls.. this possiblet?
  134. What's with Comcast charging for networks shows on ON DEMAND?
  135. WTB: 8E0 035 593 L Sirius tuner
  136. Bluetooth Volume issue-Either too soft or LOUD
  137. is there any way to have a HU that does not need a safe code?
  138. on a symphony 2 radio, what are the power and ground pins? i want to bench test a radio.
  139. Will '05 radio module in '04 A8?
  140. Phatnoise Phatbox 20gig Media Player in classifieds.
  141. Have STF, and have a few questions and opinions requested........
  142. Maximum volume not very loud
  143. 08 A3 Noob Q's
  144. Phatnosie for sale!!!
  145. Need help with HU
  146. Heads Up on Kenwood DNX8120 if you plan to have NavTraffic
  147. Looking to buy a Sirius sat radio tuner 8E0 035 593 F
  148. Looking for great aftermarket car audio company in SoCal
  149. 2000 A4 Bose radio/Cd changer problem...>>>>>>>
  150. Could it be??? Finally, ipod integration to an Audi headunit with CD text capability....
  151. Antenna Adapter?
  152. symphony + amp = thump (on turn off)
  153. Phatnoise Help!
  154. Looking for advice. Need double din unit that has GPS.
  155. 01 A4 Avant with Bose Radio..speaker has static in left front door..is it an easy fix?
  156. I am trying to install an Infinity Basslink onto my stock B7-A4 unit.
  157. Is there anyway to switch off the concert display after a certain duration of inactivity(10secs)?
  158. Antenna amplifier is dead - anyone have a reasonably priced source for these? I don't mind used
  159. Audi 80 tdi 1992
  160. Think I Killed my Head Unit....?
  161. refitting symphony in B5 s4... parts questions
  162. Spare Radio
  163. CD Changer Problem
  164. wicked remedial question ......
  165. Has anyone tried using this? Would it work for my B5 A4? I am trying to replace OEM with 5"
  166. OEM Symphony II head unit swap.... Need help.
  167. wow. major dimming with JL 500/1
  168. Rear Speakers cut out when I open the boot: 2003 A4 Cab
  169. Still cant get the Concert out of my 98.5 dash...
  170. Head unit problem! Please help.
  171. suggestion for compact room speakers?
  172. b5 a4 stock stereo upgrade help
  173. A few updated pics of B5 S4 stereo install...
  174. Chorus stereo compatibility across Audi models
  175. Need help diagnosing a sound output issue after re-coding a bose symphony II to non-bose...
  176. Anyone with experience with a GROM iPod adapter for their car
  177. factory subwoofer, who's kept it?
  178. Lost Radi code
  179. Dash, panel, and radio removal tools: source? TIA!
  180. Does cargo box hinder Sat radio?
  181. subwoofer upgrade
  182. Having trouble keeping my old-school a/d/s amp cool...
  183. '06 A4, Non-Bose, Need advice with how to go about putting in a sub.
  184. I finally got around to taking some pictures of my stereo install.
  185. looking to install aftermarket head unit. is there any wiring adaptors..
  186. looking for recommendation for a head unit as close looking as stock concert
  187. Do I need a Radio Ulock code for the Bose Symphony II stereo
  188. what is Disk Error 1 on a Concert Head Unit?
  189. Recommendations/Ideas for Audio Upgrades
  190. PSA regarding integration of iPhone & IceLink
  191. D3 Trunk ground for MMI?
  192. square into a round hole? D3 wiring harness help!!
  193. trying to undo a hacked install... pictures please!
  194. B7 A4 - special tool for removing interior trim?
  195. Ground
  196. Need MP3 Player help with my Audi A6
  197. Parot MK 6100 & Iphone ?
  198. Cross Post. - project I cant finish.
  199. Audi Concert III vs Pioneer ?
  200. 1993 90 rear door speakers.
  201. Full stereo install + Blinder laser jammer in an A6...
  202. Radio Not Working 2001 A4 1.8L Avant (SAFE ON DISPLAY)
  203. adding sub and amp, need wire diagram for 05 a6 bose
  204. Symphony II pre-out harness?
  205. Can Someone Help?
  206. Fiberglass sub enclosure question...
  207. Sub install - Need help
  208. kenwood dnx7120...
  209. Alpine IVA-W505 vs Kenwood DNX8120 and Passport 9500ci vs SRX
  210. Been forever since I posted here...
  211. AMI with Ipod/iphone - Extension cable out of AMI area?
  212. Installing AVIC D3 in 2008 A3
  213. Audi A4 B5 model Rear speakers connection
  214. XM info still displays after Blitz install...can I get rid of it?
  215. where to buy stock a3 bose symphony?
  216. I really want to get the dice ipod connection on my b6 s4 but...
  217. Parrot CK3000 Evolution and a 2003 Multi-function Steering Wheel
  218. Finally putting another head unit in my S4. What cables will I need for it?
  219. Charging issues with new subs and amp.......only 1200w rms
  220. XPOST: My car is finally back together, not an audi but you Audio guys might like alot of pics
  221. Adding a sub to a B6
  222. Xpost question from awot
  223. 2008 canada s4 w/ factory inst sat, symphont radio
  224. Good Installer in North NJ
  225. 2007 audi a8 cd player
  226. Reflow of amplifier components (help MacSub!!)
  227. want to mount antenna inside dash without cluttering up dash...little confused on these instructions
  228. would this be a good anti-theft solution for D3?
  229. Terk Spliiter SIR SP
  230. Ok so I just installed my audio system... I need help tuning this thing
  231. Avic D3 install help
  232. '04 symphony II questions...
  233. is there such a thing as a HU that has an interface with a cell phone to
  234. Ipod integration for B7 A4/S4???
  235. Poor sound quality when using 10disc CD Changer
  236. AVIC-D3 Color Question
  237. Any opinions on DICE iPod adapters?
  238. HU recommendation for Concert 1 replacement
  239. Pioneer Avic D3 install in a B6 S4. Thanks 5speed6 !
  240. Can anyone tell me what the max mounting depth is for the front speakers in an '07 A3?
  241. Will an 'H' sirius box work in place of the newer 'L' box?
  242. STEREO GALA SYSTEM
  243. Bentley manual/ Electronics
  244. 2003 A4 B6 Radio Reception Issue
  245. Having read the archives on proper grounding I'm still a bit confused so...
  246. anyone ever buy from sonicelectronix.com ?
  247. X-Post fron C4 forum...Need pin locatios for Phatnoise connector
  248. waiting to install d3, jl 500/1, 12w6. dont want to cut corners
  249. head unit questions......
  250. Follow up to my Concert restore project, HU is not working now, long...
