PDA
View Full Version : Audio, Video and Security Discussion
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. CAN Gateway upgrade - Possible with firmware?
  2. Need help figuring out whats wrong!
  3. Bose sound update
  4. Compustar T13
  5. C5 A6 RNS-D loom + ground points testing
  6. MMI and Android problems
  7. Hacking newer MMI MIB3, ssh access?
  8. Special caracters on mp3 files in SD card playlists
  9. MyAudi App says remote start now available (4.19)
  10. Audi Virtual Cockpit
  11. Audi A6 MMI Says Radio Not Installed
  12. Q4 wiring harnes/diagram rear LED backup / reverse light
  13. A6 C7(4G) preface, android Audi/apple carplay
  14. reversing camera
  15. Radio upgrade
  16. Album art disappers while driving in Virtual Cockpit
  17. Keyless Entry Failure
  18. Easy-ish audio upgrade on base A3?
  19. RNS-D Upgrade
  20. SE: re-STRAM CAN OBDeleven a4 allroad
  21. Rear camera on A6 ('20) not working. Throws fault codes. Dealer says no help
  22. Display Control Unit
  23. A6 not recognizing key
  24. Screen upgrade from 2018 non touch 8.2 to 2022 - 10.1 touch
  25. MMI Bluetooth music audio has suddenly stopped working
  26. How can I use wireless carPlay and use celluar data at the same time?
  27. MMI Not working ...Fixed !
  28. Unable To Remove MMI Menu Blocks
  29. Bluetooth connects to car but can’t control songs in the car
  30. 2017 Q7 screen will not extend out of dash
  31. 2013 Q5 Bluetooth Help
  32. Errors after battery replacement
  33. Carplay no lokger working
  34. Album art disappers while driving in Virtual Cockpit
  35. 2007 A3 Won’t start
  36. 2016 Audi s7 HUD replacement
  37. Can’t change song from the knob or steering wheel iPhone
  38. Audi a8 mmi repair
  39. Concert Radio updates
  40. 2017 Q5 B&O speaker troubleshooting
  41. Wired Apple Carplay stopped working
  42. B&O 3D Sound (not Advanced) System
  43. 2021 SQ7 B&O sound system
  44. Wanted PP-VAG 2.6 harness
  45. Full Pinout Diagram for ASK Sound Amplifier Basic
  46. 2018 Q7 Quattro - middle screen will go down intermittently
  47. Subwoofer not working
  48. UK: A4 - Navigation won’t initialise
  49. MMI
  50. Just got back from the dealer for CP removal
  51. 1 Second Audio
  52. Help!!! missing connector installing MIB2
  53. MMI Issue
  54. Audi Software Update - 2018 Audi A5 Sportback Technik (Prestige)
  55. Last letter Of MMI Control head
  56. MMI - Play music from usb-memory or sd-card
  57. 1994 Audi S4 Tail Lights
  58. Way to Tap Output Signal from DVD Changer
  59. OEM Interior Monitor/Inclination Sensor Alarm Retrofit
  60. 2006 A4 Advent Bose stereo looking for Bose amplifier pinout so I can tap into the st
  61. Sirius XM Browse Function?
  62. Testing MMI/MIB3 setup
  63. MMI Knob Weirdness
  64. Aftermarket sub
  65. BACK UP CAMERA NOT WORKING
  66. Garmin Dashcam Mini 2 - rearview mirror power
  67. ME: Audi a4 b8 2008
  68. Audi A4 B9 Standard audio system, morsecode noice from front speakers
  69. Help with Bluetooth options -2006 Audi A6 Avant
  70. Waterproof the Bose Amplifier?
  71. Please help with android screen setup
  72. Cheap and effective fix for iPhone/MMI problems
  73. Problem with the Bluetooth
  74. MMI 3G+ WLAN Media Souce -- Who Uses it ?
  75. Component Protection DTC after replacing Seat Controller
  76. Android Auto stereo upgrade
  77. Aftermarket stereo
  78. Did Audi include a CD with them?
  79. background lighting
  80. Looking for a Recommendation
  81. 2007 Q7 Bose amplifier repair service
  82. Adding led light bar to rear of 2007 Q7 to be used as extra reverse light?
  83. UK: Replacement key for Audi A6?
  84. NO: which DAC is going to be used?
  85. 10" Stock Subwoofer Replacement Recommendations
  86. Audio / Sound comes and goes
  87. audio signal cable in A8 2003
  88. Android Auto (wireless) connects only 70% of time. Q3
  89. MMI cable rec?
  90. When did it become impossible to obtain the 10-digit vehicle code from Audi?
  91. EZT Euro Zone Tuning
  92. SiriusXM No Song Titles
  93. Shark Fin Replacement?
  94. MMI3G+ After updating software mmi self restarting
  95. 2013 Audi A3 2.0T Wagon - MMI Alerts
  96. Which VCDS to buy?
  97. 2014 Audi A4 Intermittent Radio Issues
  98. UK: DAB issues after firmware update
  99. 2013 Audi A8L front Bose door speaker resistance
  100. Audi B5 driver door speaker crackling
  101. Circuit diagram for B&O amplifier - AUDI TT 8S 2014
  102. Radio on ignition
  103. New to Audi: audio upgrade options for my A3?
  104. Audi Multimedia player on Q5 8R
  105. 2017 A6 AllRoad Convenience Locks
  106. Q7 4L Audio Install
  107. 2013 Audi A8L radio sound interrupted every 2 seconds after replacement
  108. B7 A4 radio head unit won’t turn on
  109. UK: Audi A4 DAB Retrofit using TV antenna
  110. Interior lighting on the A7
  111. 2018 SQ5 MMI Problem
  112. UK: LOC Hi to low level converter advice
  113. Short to ground on Rear deck speaker
  114. Audi A4 b9 - Subwoofer box install
  115. Audi A4 b9 - Subwoofer box install
  116. Head unit dead
  117. Share The Experience Of Upgrading Wireless Carplay!
  118. MMI 3G+ Software update error (no letters)
  119. CZ: A4 B9 audio is on mute
  120. Best path to 2020+ infotainment in my 2007 RS4?
  121. Problems with TV signal, A8, D4
  122. Audi A4 B5 AVANT stock sound system upgrade to OEM bose system?
  123. 2022 Audi MMI Noises
  124. Suggestion for adding Carplay to 2015 Allroad
  125. Q5 - SiriusXM Artist/Song Alert Option Not Found
  126. Multifunction Steering Wheel Button - Additional Functionality
  127. Rear effects speakers not working
  128. Audi key shell disassembly
  129. Couldn't solve this issue at all - Electric functionality
  130. Help needed on replacement radio for A1
  131. beeping when using center console + static sound
  132. Bluetooth playback beep noise / music skips
  133. First Audi - Issue with Navigation System - 2015 Q5
  134. Red 12V+ wire from BT adapter - Where to connect? audi concert 3
  135. Subwoofer makes acceleration sound
  136. Pioneer radio install. Only front speakers working.
  137. Problem with network and traffic sign recognition
  138. B&O ADVANCED sound system
  139. 07' Q7 Plugged in Sirius receiver, now whole mmi system malfunctioning
  140. AUDI Q2 RADAR SENSOR
  141. Dension GW52MO1 500S BT Firmware?
  142. MMI misbehaves
  143. B8 Non-MMI Lost Funtionality
  144. UK: AMI head unit part number?
  145. BA: Audi A6 - base system to BOSE?
  146. The Jam Traffic assist with ACC speed limit
  147. Audi Connect Not Available - 2019 Q7
  148. Nav Update
  149. Mmi replacement options
  150. Audi A6 e-tron concept - Projectors
  151. Navigation database version
  152. Ipod not recognized MMI
  153. Amazon Alexa on 2021 models
  154. 2018 A3 CarPlay not working sometimes
  155. 2015 Audi Q5 B&O audio system, quit working
  156. CarPlay Playlist displayed in Virtual CockPit
  157. Increase Audio Quality/Loudness
  158. MMI 1100 - 4E0 906 961 H iso
  159. Help: A4 B8 no sound
  160. Component Protection Fail
  161. A3 8V apple carplay update Ali Express
  162. Remote start recommendations
  163. 7 digit SKC or Pin
  164. 2016 A3 1.6 TDI - Bluetooth music issues
  165. Looking for subwoofer box
  166. Stereo upgrade
  167. Siruis XM Favorites Greyed Out - 22 Etron
  168. AU: 2011 Q7 map upgrade
  169. APK menus all missing from green menu
  170. Good Bluetooth Aux Receivers for the car
  171. Is there a system for sale that can add CarPlay to a 2013 RS5?
  172. Apple music integration is here
  173. Bluetooth - Multi device question - 2022 Q5
  174. A3 stereo swap
  175. 2021 Audi Q7 MMI: “Your data connection is deactivated” every time
  176. Mmi issue
  177. Bluetooth
  178. OEM Size aftermarket radios
  179. Looking for advice regarding MMI Box
  180. Adaptive Cruise Control
  181. Wired CarPlay issue - Audi A1 Mk2
  182. MMI monochromatic display video signal protocol
  183. "No sirius satellite installed" on mmi but sirius says otherwise 2007 Q7
  184. AUDI SOS - NO 911 [DO NOT DELETE] - This bluetooth...
  185. 2021 SQ7 AudiConnect Wi-Fi Error
  186. How can I shut off "Navigation Not Active" message
  187. Audi a8 2019 rear Seat remote doesnt conncect with mmi
  188. Audi S3 8l central locking issue
  189. No back up camera?
  190. 1994 A6 Radio problem
  191. MMI is dead ?
  192. RNS-E + door lock on/off random
  193. Thinking of adding an IDataLink Maestro RR to my 2010 Audi TTS
  194. FI: Issue installing new aftemarket rear speakers to A6 C4
  195. 2017 A5 MMI Display Upgrade
  196. PL: Issues with radio
  197. 4g module etron
  198. Instrument cluster.
  199. Where's my Sub Q5
  200. MyAudi & unlisted country
  201. 2016 A6 speaker upgrades
  202. No MMI/NAV/RADIO D3 S8
  203. No sound from speakers after buzzing.
  204. 2018 Q5 alarm
  205. XM Radio/Convenience Package
  206. Navigation showing me in the Ocean
  207. Audi A5 MMI 3G High AMI not working
  208. Alarm Siren
  209. B&O Advance after 2020
  210. Audi A4 climate control lights went out
  211. AUDI Q7 MMI radio button opens media
  212. UK: Help please. I keep buying the wrong part.
  213. What is "Keyless Go access/ignition system" ??
  214. Audi A3 2010
  215. Mmi retrofit
  216. Audi A6 Multi faults intermittent
  217. Disable Subwoofer from factory amp
  218. 2017 Audi A3 Etron Carplay Not Showing
  219. AUDI RNS-E NAVIGATION UPDATE AUDI TT 8J 2007
  220. UK: Audi A5 (2016) - MMI unit resetting every 20 seconds + Radio not working at all
  221. Scrolling through SiriusXM stations in MMI
  222. MMi Crashes every 5-10 mins, No Bluetooth. B8.5 S4
  223. Fxing Audi A3 MMI Unit
  224. Lost Audi A6 2010 Key, took it to dealership, now has electrical issue?
  225. 2013 Q5 Dead Radio
  226. Quick Charge Pro
  227. CD player Issue
  228. Bluetooth Not Working After CarPlay Install
  229. A wireless adapter that allows me to download any APP on my radio
  230. A4 audio upgrade
  231. Copy to jukebox failed
  232. Did any Audi Q5 owners get the right wireless adapter for your CarPlay
  233. 2013 Audi Q7 front camera connector
  234. Audi Q3 2015 UK model Canbus Pinouts
  235. 2021 RS5 Full Audio Upgrade
  236. SK: Audi Sound System (not BO) A4/A5 B9 specification
  237. Concert 2 AUX CD changer emulator
  238. 2018 Q7 MMI Reboots While Driving
  239. Aftermarket sub for my audi a4 b8
  240. Cracks in door puddle lights
  241. Radar Detectors
  242. upgrademyaudi.net down???
  243. Adding sub
  244. Sirius artist/track alert option not found
  245. Upgrade 2021 sQ7 Sub?
  246. SQ8 - Both Main Screens Completely Black, Not Working
  247. Upgrade from small wireless charger to large
  248. MMI menu missing items
  249. Aircon not working for A8
  250. Factory Amplifier Info
