- CABRIOLET trunk lid finished.
- Can anyone show me what's behind this? 2005 A4 B6 Sirius & Symphony II
- Need Sirius Tuner For XM
- S4 symphony retro-fit for B5 A4??
- Anyone know the Bose crossover freq for the door speakers on the 2001 A6?
- Anyone here running an Infinity Kappa Perfect 6.1 Mid-Range Component System, I have some questions?
- Anyone ever use a Dietz 16106 double DIN trimplate?
- Headlight switch fix and airbag light
- Helpme figure THIS ONE out...
- How to write SD cards for Nav system
- Besides the obvious dealer answer.. where can I get the screws the speakers are held in with on a B7
- So i hooked up my Icelink, but now my radio doesn't have any reception. How do I fix that?
- audi 3 plugs to US sony radio plug
- A4 audio upgrade options?
- Concert II Question.
- FS: Peripheral SVEN4 Line Output Converter
- OEM Sirius install on a B7 A4 with Symphony II question
- Is the concert II a single Din unit?... Can a concert II be swapped into
- ipod oem kit
- Need help with amp choices....
- Anyway to install Icelink Plus and a Sat radio Unit? '02 A4 with Symphony II
- Rear Speaker and Display not working
- Phatbox disconnect...has this occured with anyone else? This is the second time it's happened......
- looking to swap my sirius for an XM if anyone is interested
- Excellent article on reducing cabin noise
- SAT NAV - DOES ANYONE KNOW???????
- How can I fix the rattling door speakers? Anyone?
- Couple questions related to adding SAT/Phatbox to a TT
- Car Stereo Advice (Help)
- I would STFA but I don't know what to look for. Bose head unit.
- Looking for feed back about G-Net Video Module experiences
- Monster iCruze
- 95 audi 90 rear door
- My Alpine head unit dims when the bass hits....
- Ideas on how to upgrade my sound system
- Is there any harm in locating crossovers in the trunk? Reason is...
- 2004 Allroad XM radio install
- Questions on upgrading Audio system in my 99 A6 Avant.
- Compiled list of upgrade FAQs/Dos and Don'ts?
- Another audio question...
- I have a delta radio on my 97 A4 and i tried putting a tape into it,
- Please help, Installation help
- will a symphony 1 fit into my '97 A4q
- I know there's an XM antenna built in to my B7..... but is there a GPS as well?
- Left Channel missing on Symphony II/Bose
- Bose Headunit Upgrade Question
- XM for Sirius swap
- New wheels and update on flush mount sub enclosure...
- Infinity Basslink install problems...
- x-post Replaced the stock A6 Bose tweeters with Audax silk domes
- Best way connecting speakers to an amp
- Bose radio in 2000 A4Q..keeps changing stations after turning off and then back on?????
- Coming soon. . .POWAH!
- OEM ipod kit install 2.0
- a3 speaker size?
- Best way to run new speaker wire through door on a B7?
- No Bose after headunit upgrade
- what do you guys think of this HU for my A6?
- 1997 A8 with Bose which AutoLeads harness PC 9408 or PC 9410?
- install Symphony 4B0 035 195A (A6) into 2000 B5 A4
- Noobie question - help building modest audio system. how about the following..
- Factory Sub removal on a B7
- What do I need to replace a Concert Unit with a OEM unit with the SAT button in
- navi for 2006 a3
- I wish that audi would have just...
- X Post - New Subwoofer technology and it is good!
- Anyone know how to take out the center console on a B7? I've got all the screws I can find... out...
- Icelink/iPod - left channel problem. Please help.
- Need some input on this sub/amp setup...
- Working on a new system...(need more outside opinions)
- TT installers..How did you run the power wire to the back of the car?? under the car only option??
- vwnavi.com not selling - any idea where else to buy dietz parts from online?
- B6 component speaker choices....
- (x post) B5 s4, I get a CD ERR 3 message when i select my cd changer, anyone know what this is?
- is there any way to replace the subwoofer in my A6 with an better aftermarket one?
- I need help, dose any one have a stock cd changer part # 4do 035 111
- Guys, is there a tech writeup for replacing a front door speaker on a B5 S4? I searched...
- headliner removed, now how do I get the antenna base off? Amplifier/filter in the way and I don't
- Wiring an aftermarket headunit to the Bose system...
- need help before I buy an AV adapter for nav+ (paging ted?)
- Hey guys, STFA and I couldn't find a write-up of any hardwiring installs for ipods.
- Sirius SAT Radio Install - Need a quick answer
- Audi Speaker
- Need help with Phatnoise voice prompts.
- 97 A8 cd changer
- ISO DIN Chassis...
- here is some old school ish hehe.
- Navigation 2006 S4
- Any reviews / opinions on the new audi ipod adaptor?
- Where did I go wrong... install OEM ipod kit fails... help!
- Phatbox CD Manager
- Need Help With Installing Subs...
- new nav for a3
- blaupunkt me-3 or similar available online?
- My system is done :)
- Anyone have a wiring diagram or pin diagram for the ABS module on a B7 S4... for the J104
- Source for parts... need pins, plugs (iso mini)
- Radio removal tricks???
- iPod and SAT radio - another way to get both
- Anybody know what this plug is called?
- A4 2000(b5) Symphony I upgrade to Symphony II
- Will there be any future versions of Nav+ for our A4 consoles (b6, b7)?
- Is there any way to get 6x9's in the rear deck of B5 A5 Nov 2000 without cutting?
- Finally finished my fiberglass/plexiglass amps/sub enclosure
- Problem with rear speakers! very weird!
- I just got a 60gb Video I-Pod in black for my birthday! How do I...
- alpine cda 9847r replacing concert in 97 A8
- Need some subwoofer help... 2000 A6 2.7T
- any one running an adapter to connect a aftermarket head unit to the factory steering wheel controls
- For a B5 car with full aftermarket stereo, what battery would be suggested ?
- NE1 want to trade XM receiver for Sirius?
- C6 A6 with Bose
- Switching factory HU from Sirius to XM?
- Subwoofer Construction Questions..............
- 4000 Quattro 12" subwoofer enclosure
- xpost from B5 forum
- what aftermarket HU are you running? I'm still debating on what HU to get to go..
- CD Changer fading in and out
- Sirius artist names and other info not scrolling on Symph II Non-Bose/Non-NAV
- Symphony II question
- For a BOSE Concert HU is there one model number to identify it?
- How easy is it to install a Clarion into a 97 A4?
- Audi A4: 1996 - Which wire is ignitive live? - for CARK 112 (CK-W1) Bluetooth car kit
- Icelink problems in 01 A4
- need help wiring a tsunami FL-LOC600 line output convertor
- Need help finding a speed pulse wire on the B7.....
- I think I broke my PhatNoise...help?
- Where can I tap an ACC wire for my headunit on a B7?
- Anyone make their own faceplate to replace the B5 A4/S4 Symph II?
- Love my PhatBox hardware, HATE the software
- Delta to Symphony swap... few ?'s
- blaupunkt preouts: where can i get them???!!?
- OEM ipod kit...
- My install
- Infinity Kappa 652.7i as replacement to...
- Input on aftermarket amp/speaker install A4(B7) + Nav/no BOSE (Xpost with B7 Forum)
- New System
- POWER INVERTER probs.
- b7 S4 speaker locations
- Any Eclipse Head Unit experts out there?
- Need help with Dash Disassembly
- Anyone else not happy with signal strength, and audio quality of Sirius??
- Alpine double din is out
- Modify Phatbox DMS
- iPOD Question for a Newbie!!!
- RNS-E install for C5 A6/S6/RS6/allroad: Part II and III
- Concert II/Bose bass
- Audi TT Bose Rear Woofers Question
- Pioneer Premiere Headunit --- Pioneer GEX-P920XM or Terk XM Direct
- 5G iPod video + RNS-E (TeddyBGame look here)
- Question about the existing wiring going into my Symphony HU.
- Harmon Kardon Drive + Play- anyone have one installed?
- Lost sound in 1 speaker
- Audi IPod adapter + SAT works!! - EASY mod
- What is the "Learn" message on Concert 1 h/u?
- Anybody ever found a cheap place to buy DMS cartridges?
- Paging NSX JR...
- XM install in B7 A4
- Concert wiring
- Anyone have problems with Phatnoise skipping??
- Adding pins to the red 10-pin connector for mobile phone integration
- satellite radio ?
- Japanese Symphony I
- Bose in-dash CD error? Easy to fix or no?
- '01 S4 speaker help needed...TIA
- Audi GPS headunit question
- intergrate IPOD itunes with phatnoise library
- Anyone notice SAT radio not quite as clear & clean as regular FM?
- Anyone know were I can buy a 12 pin female Molex end of the CDC cable?
- Phatbox and compliation Cd's...wtf?
- Amp install help
- Installed my Delphi SKYFi2
- bbaudi382: Question regarding Eclipse head units.
- Does anyone have the repair/service manual for the Symphony I Radio.
- iPod installed today with iPod2Car....
- On subwoofers: Which configuration is best (of these?)
- Whats everyones opinion on MB Quart premium series??
- audiophiles, need some help
- Non BOSE/Non NAV AMP Upgrade...
- Is there enough room to tuck a 4ga power cable under the door sills on a B5?
- speaker locations in a3?
- Anyone have pictures of wire color codes for the plugs in the rear of a Symphony II/B7 A4/Bose?
- How exactly do you remove HU (I have 4 of the removal tools)?
- How do you hardwire a Sirius portable into the existing radio?
- Symphony HU output RMS pwr. specs. ????
- Is it just me or is the sound quality of Phatbox kind of flat compared to OEM CD changer?
- How is the sound quality (compared to SD) for IceLink/Audi iPod?
- can I connect an MP3 player to the symphony II's CD changer input?
- Please Post Icelink w/ XM instructions......
- X-Post on A4- Symphony adapter kit from scosche?
- Got XM Delphi Skyfi2 radio - Questions:
- Installed Nav...X Post from B5 forum
- Is it possible my CD NAV + is draining my battery? Car is dead after a week of sitting.
- Hardwiring question
- CD changer problems with Concert II
- Drive + Play install question
- help- settings for auto-tec amp for my JL w6
- upgrading speakers in a3
- Anyone using a JL Audio CleenSweep?
- Concert II permanent unlock
- 1995 A4 - Audio upgrade, help!
- Amp and speaker upgrade on a Concert 1 non-Bose - do you have to VAG?
- tap into existing wires or run new wires
- Stupid Stupid Stupid
- Xpost: Can this be done...
- DVD Install, Bose Compatibility
- Phatvoice help
- PhatBox only plays first song of each album??
- Looking for simple 10" sub & enclosure suggestion
- Tapping rears for amp install HELP!
- iPod video
- nav-plus and a system
- 2000 a4 double din faceplate...
- Tapping line-outs- voltage?
- Are the door speakers 5 1/4 " on a B5 A4?
- concert head unit: any way to program it to recognize CD changer without using VAG Com?
- Rebuilding a system again . . . input would be helpful . . .
- What info does the OEM head unit show for Sirius/XM radios?
- Current requirements to update B5 S4 to RNS-E Nav?
- can this be serious?
- Looking for a HU with Bluetooth and iPod controls
- System is 100% finished. Pics inside
- What color wire is the remote turn on for the bose amp on an 03 A4
- will this work?
- Anyone know where I can download PhatMac software? I've dl the Mac stuffit file, but when I try...
- B5 Audi S4 System Upgrade help
- Sirius Install Help
- documentation for bridging an Eclipse 36401 needed!
- BA SL60 components: hit/skip?
- If I'm using a Blaupunkt adapter in place of the OEM line out adapter, does that mean I will no long
- suggestions for the stock route
- Hardwired 5G 60 GB Black iPod Video for audio and power !
- Installing New Amp & Subs
- Phatbox wont play startup sound file i have selected for it.
- Question about rears in 2000 A4...
- cd changer for delta cc
- 4 or 8 gauge?
- Need help with code entering on a RNS-D unit.
- how can i prevent MOISTURE in the boot/trunk!
- Where to get nav+ units? I've been contacting a couple of the popular suggested ones and no answer.
- ok, so from yesterdays post about a mcintosh amp my alternate is a Xtant 603X.
- Wiring a DVC Sub....
- Looking for custom box suggestions for 2000 A4....
- Repeated Click From Dashboard
- best way to wire an lcd
- I have a new A4 B7 and going to upgrade the stereo. im not changing
- Yet another custom enclosure BT....
- More on custom enclosures....
- 01 S4 bose, rear door speaker sounds like cr*p. replacement suggestions?
