- Aftermarket Head units with stock stacker
- FYI
- Factory radio terminals for B6S4.. do I need a special tool to
- NEED TO KNOW WHAT SIZE SPEAKERS IN MY 2000 S4
- How to dismantle the center console? (Xpost)
- Where to hook up 12V power for 200W sub amp?
- My main power fuse for my sub and amp wont stop blowing...
- Will these speakers fit in place of my stocks? Upgrading system w/ full Alpine speakers
- anyone got the link to the valeo alt.s?
- MA audio MA121XQ
- bluetooth and non-Telematics A4?
- Are Polk components the best thing to get for a B7 S4?
- Bose stereo malfunction in 99 A6
- I hooked up yo girl dog!
- need recommendations on car tv tuners...
- Anyone know if the Bose rear door speakers in the C4 model A6 are 3 or 4pt mount like the fronts?
- Has anyone tried Audible?
- Phatbox Madness (in '04 A6 w/CDC and XM)
- X-post from B5 section: hidden menu...
- Use stock wiring for new sub?
- Problem with Xenarc screen....
- X-Post: from S4 forum about speakers...
- PhatBox DMS all of a sudden won't recognize properly. (!?!?)
- new allroad installation
- Sub comparisons. Please post your experience with any of these.
- finally...i got my phatbox installed and guess what.....
- How to hook up an amp to OEM HU
- 5th Annual Audi Expo - Come be a part of history again!
- Memphis components
- Anyone added NAV after delivery to a C6?
- CD changer options
- Pioneer Avic N2, or Eclipse AVN 5435 ???
- FS: Cool Sub/amp rack with 4 JL subs !
- Question about replacing front speakers
- Anybody else done a sub enclosure behind the trunk liner like this picture. Can you share details?
- Ordered the $165 Phatnoise from Clair Parts 2 weeks ago . . .
- Alpine TDM-7534S only responsive to power button!
- CD-R compatability in my Symphony II
- Phatbox 000057110A vs. 000057110C
- Hey Omarr, question for you about Phatbox...
- comp. question
- Is $279 too much to warrant purchasing a rockford fosgate 50 farad comp. capacitor?
- Phatbox Question
- what do you guys think of the flip down monitor..
- B5 S4... usually front door speakers are 5.25, is 6.5 doable ?
- Pinout or cable diagram for Phatbox
- Hey TeddyBGame
- Routing path for XM sat antenna?
- 99.5 speaker adapters for sale...brand new...
- The phatbox for VW is available for $119
- What's the Wattage on OEM HU?
- rear deck and adire koda's
- yes..another phatbox request...
- nav-plus question
- Looking for a Concert II Head Unit
- Speaker size for A6 2000
- ok...need some phatbox help
- REAR AMP ON 2001 A6 1.8 T Saloon giving noise with aftermarket head unit
- Why does a wider frequency = worse sound?
- Replace Nokia Sub with anything?
- Aftermarket stereo pre-amp outs to GAMMA HU harness problem
- Basslink Install Problem...No Servo Light
- Need adapter for component speakers non oem?
- Help!! Newbie trying to install HU
- Mapping the VW Phatbox Cable
- Need help with Oil Pressure Gauge
- Installing an amp
- OK...got my connectors from buxcomm.com for Phatbox
- Can I splice in Bass Blockers into a factory set of 6X9's...
- I have 8 speakers (all w/sound coming out of them) and a trunk mounted sub as a stock system, do I
- When I turn the lights on, the radio goes off..
- Stock deck
- is 17ft of power wire ok for b5 a4 for amp install? purchasing install kit from ebay...
- Help!!!
- Valentine V-1 Question ... and question about rear view mirror..
- Electronics blinking off and on
- which amp would you chose
- Alpine Subs for sale
- OEM Replacement Speakers
- bezel for faceplate/headunit
- Ice link plus problem
- anyone need the blaupunkt adapter?
- Phatbox Installed and now there's a constant buzzing sound when played
- Should I replace head unit or just add a DVD player?
- Audio Conrol EQQ questions...
- Icelink+ problem
- i've done some number crunching and need at least a 240amp alternator...
- anyone use the clean sweep (jl) should ZI get it for subs only??>
- head unit replacement/pics
- Subwoofer rumbles after turning off head unit...help!
- Amp and Dual Voice Coil question.
- Installing the following... Need advice and help
- 2 Bose issues in a 91' 200 20v (help please!)
- Connect a powered antenna amp to the headunit?
- Ready to pull the triger on a Phatnoise but have a few questions
- Stock Deck
- I finally got my 5.25" components but even with adapters they don't look like they'll fit! more...
- I'm confused as hell with this Phatbox install...
- Phatbox Install - 25 Pin Male not 13 Pin
- 13 pin din connector...question
- Another Phatbox ? for 2002 a4 Owners
- non- phatbox Q's
- X-post from B6: Can you guys help me with my Blitzsafe/XM questions???
- What exactly does "turning off the bose function" on the HU do?
- 10" sub recommendation
- The cassette deck on wifey's Concert is dying. Best place to get one cheap (with a code)?
- install advise / questions.... speaker placement..
- ordered my audi cable for phatbox from ECSTuning.....
- X-post, Question about running a Phatnoise and a CD changer in a B5 A4.
- Audi S4- Maximum Trunk Dimensions for Sub Box
- Need suggestions for an in car 4.8 to 5 volt power supply ??
- Most economical way to get better sound from B5 S4 Avant w\ Bose?
- Anyone know if it's possible to set the HU to read ID tags from CD's so it can show song titles....
- DIY Phatnoise + SAT install pinout
- Anyone with the Pioneer AVIC-D1, the double din unit?
- DIY pinout information for Phatbox VW to Audi cable conversion...
- While I'm installing the Phatbox in the trunk what wires should I run to upgrade the sub?
- Need an A/B type switch to go between the CD changer and XM Blitzsafe adaptor.
- Advice sought on x-over settings on an amp for components that have their own x-overs already...
- 2000 S4 with Bose rear speaker grill removal?
- PhatBox cables? updates? anyone?
- New Beetle Audio options?
- what kind of voltage can i expect to get out of a 1.8t a4?
- Audio experts, need your help
- k, think we need a phatbox forum now mmmkay?
- Who has a B5 NavPlus unit for sale?
- weird phatbox /symphony prob..
- alarm in an audi
- I want to get started on a system need some advice. Here is a Breaks Cd for your troubles
- I put my Concert deck back in after I had it out for the past 3 years and now I have a problem
- sugegstions: cheap cd player that can connect to iPod??
- Reception Problems
- Bruck, others: how many of the pins/8 off the back of the icelink are required?
- Tapping the Bose sub in an A6 Avant
- Looking at this iPOD dock for my car, but the audio out is a 3.5mm jack...
- Anyone here biamp their front components. Do you still use the passive crossovers?
- B6 S4 Phatbox install question - hijacking the SAT/NAV cables
- My Phatbox Audi cable from Clairparts arrived today. What a relief!
- Has anyone here had BestBuy install their Dension ice>Link Plus?
- Anyone replace the keyhole on a B7 with a rearview camera?
- anyone need 5.25" speakers?
- Anyone know how to get the arm/disarm PULSE" signals
- Basic DIY: B6/B7 Phatnoise w/Sat radio install
- ok stupidly i when putting the new HU.........
- Any opinions on MB Quart subs?
- Could somebody with an Audi Phatnoise cable (part # 000 051 592A) post...
- so now that the cables are on worldwide backorder with no ETA.....for PhatBox
- any way to incorporate this into a amplifier / subwoofer install?
- B5 Door Panels - Aftermarket
- Help! Need clarification on the VW PhatNoise system before ordering...
- Phatbox Audi pinout diagram?
- fitting phatbox in cd changer shelf?
- Sirius Starmate in B5S4: If I buy the wired FM modulator, which adapters will I need to make it fit?
- ok instaled the rest of my system today and i havea question.....
- Anyone know where i can get a few bose tweeters for my '98 A6 and how much??
- Will the Phatnoise/Phatbox work with the Kenwood monitor H/U?
- How does the Audi Nav Dvd RNS compare to aftermarket Double Din Navigations?
- Will the phat box hook up to a 1996 a4 stock radio?
- Installing new HU
- which should I get and why?
- Finally, OEM Audi iPod integration kit (unofficial thread) - Coming the Summer of 2005
- need help delta to concert swap
- What is the difference between the Phatbox Media Manager and Music Manager?
- Phatbox VW converter
- Feedback on Compact Amplified Subwoofers? Clarion SRV303 or Kenwood KSC-SW1?
- Phatbox....which one do I order for my car
- My Phatbox noise problem diagnosed...how about this:
- Done my searches.. need a pin-out for B6 Phatnoise install w/Sat Radio
- cd text on symphonyII ?
- My reception sucks in my B5 S4... HELP!
- Phatnoise/box Help for an audi noob...
- i am having a new HU instaled tomorow.......
- Any advice on how to ground the radio to get rid of the alternator whine?
- One of the clips on my radio is screwedup. Is there anyway to remove radio without destroying
- Where can I order a B7S4 book..... I know someone had THE B7 book that the techs buy to learn the...
- Pioneer AVIC-D1, thoughts, advice, suggestions?
- B6 Phatbox install.. Whats the final word on installing with Sat radio?
- How durable is a phatbox?
- Is it possible to use a generic phatbox for the trafficpro.. The Hk trafficpro phatbox is $795!!
- this is my first amp instal how did it come out??
- Question about car cell phone antennas...
- anyone know where to go in the boston area for a system?
- When did everyone order their $119 Phatbox, and has it arrived yet?
- PhatNoise/CDC cable question - for those with B6 A4s that have to install a CDC cable. . .
- Connect Antenna amplifier?
- projectEZP.com - next generation police radar detector. Free database for your GPS system
- CAN-Bus question
- Anybody familiar with the wiring of a 2001 VW GTI 2-piece headunit (main unit + in-dash CD player)?
- X-Post : C version glovebox CD Changer won't work with my RNS-E
- New amp options. Narrowed down to a Zapco Reference 1000.4 or a Audison LRx 4.300. Which one?
- Phatbox problem, since everyone else is having them
- X-Post: Need some help with the aftermarket radio install...
- I can't get my phatnoise to play AAC files, anyone know how to do this?
- Aftermarket Deck
- navigation quesiton... for '00 S4
- If someone is interested I have spare Audi XM receiver.
- Anyone know what this cable is??
- Symphony II display recode possible?
- PhatNoise Cheap!
- Noise comming out of my speaker
- Putting Orion speakers in my car. I can get them pretty cheap. Few questions?
- Nav soloution?
- help Please! Last year I installed a Memphis Belle 5 channel in my tt.
- Why does my 2002 symphony II have a Sat antenna connection?
- Phatbox w/Sym II, XM and CDC
- 2003 A4 Speaker cutout problem
- What's up with dension? Firmware updates gone? Ended?
- Front Speaker Template/Adapter Question..
- Anyone Have the Older Sony Stereo Removal tool?
- Can you take a CD changer out of a TT and put it in a A4?
- Gamma Radio - ipod connection
- Why do RCA plugs on Blaupunkt adapter need to be grounded?
- XM unit recommendations?
- X-post: Phatbox Question: are there auxiliary connections on the unit, or other way I can split (m)
- Anyone have experience with the IHF1000 (new BT moto kit)
- anyone seen one of these used for nav or an mp3?
- Turned my C5 A6 in. Items for sale that I removed that were mine.
- Hooking Up mp3 player to Audi Symphony Stereos (v2)
- Bluetooth car kit and multifunctional steering wheel
- Best Subs?
- They sent me here- more volume on c5 a6 bose (2003)
- In-Dash Computer
- finally about to pull the trigger on the Traffic Pro, will there be any problems fitting it [more]
- 2005 A4 Bose Radio SAT Volume...
- Avant satellite module location?
- Burnt Cd's.....
- amplifier question in regards to subs that I already have...
- Phatbox install.. I thought it was going to be simple (long)
- Parrot CK3100 with Bose Symphony II & Nav
- I have a low repetitive thumping sound coming from my sub and it won't
- how do you mean to tap a fuse?
- Anybody seen any reviews or heard anything about the new MB Quart Q amps.
- half din dvd plyr install in glove box?......................
- flip outs
- Phatbox question
- Amp gone on front left bose speaker... what to do?
- Feeler: Anyone interested in a slightly used XM Radio Commander unit?
- What the hell is RNS-E?
- if I wanted to conect an aftermarket amp to the stock hu, this is what i will need right ?
- I think I need a new amp. Left channel sound is cutting out every so often. Any recommendations?
- HK Trafficpro New Software
- 12Volt line near the front doors ad the door sills?
- me got B5 1.8TQS Tip...some Q's..
- B5 Bose rear deck speaker replacement question
- PhatBox Wiring Diagram
- Feeler post...gonna be selling my car and am thinking about selling my system...(edited)
- Wow, the quality of the equipment you use really does make a difference. Just upgraded my sub amp.
- car audio install
- wiring diagram
- phatbox + tint problems?!!
