- im ashamed to say i have a phatbox installed in my B5 S4 for over a year
- good cheap multimeter?
- Radio Symphony II don't wakeup and don't illuminate
- Ok, now i'm really confused about ipod/xm in a 2007 A4
- To Bose or not to Bose
- 04/05 OEM Sirius in a 05.5 A4 avant bose no nav
- 2007 A4--can it use the OEM XM module?
- Mr Ken, any news about the shallow 8" sub you were recommending?
- ipod adapter that uses RDS to send text info to screen/radio
- Follow up: if i use a DICE/ipod with my 07 A4, can the oem headunit display the XM info?
- SD reader that works with 4Gb card $6, 4GB card $38, both work great
- anyone ever have problems with the remote turn on from a symphony HU with the blau adapter?
- A4 sat/ipod issues..help please!
- D3 A8 MMI iPod Integration Install
- Anyone familiar with the Rockford 800a2 Power Amp (Circa 1999)
- no radio signal after replacing Symphony HU
- Distortion in driver's door - caused by pressure on crossover?
- Delta Radio Problems
- Mr. Ken of avincar what do you think of Dynaudio MW180 for subs?
- Need help with XM install on 07' A3 with Nav
- Replacement HU advice for 2007 A4?
- .01 cent ice link is on the way from ebay, what will i need to hook it up?
- Question about after market CD Player
- Help With Symphony
- Paging avincar -- best B5 S4 setup for under $1,500?
- Best iPod 5G 80GB cradle?
- icelink plus ... newest firmware?
- Help Needed - Wiring Glovebox Cd Changer to Chorus
- My Conert I's display has several columns of pixels half dead. Any known fix or replace? ...
- DICE iPod operation strangeness
- Symphony II Non-Bose
- Already STFA forever and still couldn't find a specific straight answer...
- Back Speakers?
- any way to hook up aux input on a navplus unit? i had a blitzsafe in my 04 S4.
- Short of asking a cop with a laser gun for a favor.. any idea of how to test a laser jammer??
- Double Din Navs
- Is it possible to change the blue color of a Pioneer HU to red? Not the screen but the buttons?
- And another q: is there a mobile, affordable DAC that has optical input and balanced or RCA output?
- Bose Speakers
- Has anyone had kick panels made?
- Grounding RCA's?
- Have you guys heard of the brand PHASE EVOLUTION??....
- Harness for connecting Icelink to CDC wires
- Audi Hood Emblem! Should I buy ?
- A6 Bose AUX Question
- Is a Symphony a Symphony?
- New sub enclosure for my B6 S4
- Is this CAN based or '3 wire'..rare Concert I or BS?
- Harman Kardon Drive + Play with Blitzsafe
- Valentine1 Rear View Mirror Display
- Audio noob here...icelink install issue on Bose Symphony II in B6 A4
- With the a8 having a separate nav screen and radio controls...what is it like to get
- Will the XM receiver out of my 2004 S4 work in my new 2006 S4 with navplus?
- Sym II code for installing aux input
- Finally got the system done in my B5 S4 (DLS UP6 front........
- Anyone try iTunes AAC for ripping music to iPod?
- I'm thinking of picking up an Eclipse CD5000 and I can't find how the iPod info is displayed...
- New Tweeters didnt fix bad front left tweeter - Is the amp bad?
- Does anyone know if the DICE and the Icelink install roughly the same way?
- Good Audio installer in Bay Area
- AMP headlight connector pins and sockets?
- Anyone add a HD radio to their Bose system?
- just got a Parrot ck 3100 bluetooth & need help installing on a 2000 A6 w/ bose
- DICE install finally finished (long)
- Need help please
- x-post: what audio stuff can you fit into your glove compartment?
- Q re C4 Bose amp interchange. Will 1996 work in a 1992?
- does bose symphony use any crossovers?
- Question about cell phone car charger voltage...
- Which pins or wires for preamp output from HU?
- What 2gb SD cards are you all using? What xfer speed does the audi req?
- Poll: What bit rate do you rip your music onto your iPod at?
- Had functioning ice link for all of 5 minutes, then i broke it...can it be fixed?
- Bose upgrade, worth it?
- the new Pioneer AVIC-D3 looks promising
- How to make your Phatbox...well...skinny? (custom enclosure)
- Crappy iPod integration in A4 Chorus
- My CES notes... (long)
- Heads up! $.01 IceLinks are available on eBay again.
- More Line Output Questions for Bose (2006 A4)
- iPod connectivity in my 2007 Audi A4 with Sym II+ at long last :-)
- Stuck radio...pls help
- 2005 Audi A4 headunit replacement question
- Buy Lrg Sidekick 3 for $150
- Symphony II+ & Audi Ipod intergration - is there a firmware update to display info?
- phatnoise question
- Audi A6 card slot
- question for AVINCAR or anyone willing 2 help (06 a3)
- aftermarket radio install
- Calling all Audio Installation Gurus....
- DICE install update, two more questions (99.5 Concert HU)
- Hello all. new here. got an a3 question.
- '04 A6 Sedan - Sharkfin antenna connection
- Heads up - $0.01 Icelink back on eBay but there's not that many left so hurry...
- Looking for iceLink nano cradle insert - anyone have a source?
- Where would I get those keys for removing the head unit?
- Recommendations for B5 S4 NAV?
- IPOD and XM radio for 02 B6 w Symphony
- Inexpensive mini-ISO pin removal tool
- Symphony I Turn On Wire Questions w/XM install.
- Looking for new speaker setup for my B5 S4..
- newbie needs help with sat radio options
- Going to CES (my feet hurt already), gone for a week
- Power to an aftermarket head unit
- IceLink firmware update and error 13??
- b5 blau adapter grounding question
- a3 center speaker replaced w aftermarket Dynaudio MD140.
- Trying to find the best solution for 2007 RNS-E & iPod Integration
- Avant Sub installed...Anybody need a free B6/B7 tupperware subwoofer?
- Symphony II - frozen/software glitch
- iPod to XM Direct input... Aftermarket Stereo...
- Concert II flatten signal
- IceLink Plus Firmware 2.15: Problem with controls on Concert 1?
- Audi Ipod Ice Link
- DICE module behind Concert headunit?
- Hardwire radar + OEM Audi mute/L.E.D. switch!
- Needed: spring latch mechanism for rear storage compartment..
- Vibration noise coming from door panel "compartments"
- Anyone put sub in rear deck or rear armrest space of A4? Pics?
- extension of mmi plus
- Can the Symphony volume control be adjusted?
- Manual CD Changer cartridge release?
- Does anyone have the latest firmware version for the Dension Icelink?
- Japanese Nav Plus
- Anyone here know if the RNS-E head unit and CD changer supports CD text?
- Icelink install - need to completely disconnect battery or just pull fuse?
- So... I blew my 12w3... I've now demo'ed an 8w7, and a 12w6...
- 2001 TT - Sirius retrofit.
- I need a B5 Bose Right Front Speaker...
- Any SQ tune/installation master in NY/NJ/CT for my stage1 audio upgrade ?
- Denison iPod not functioning correctly
- Who had Can-bus adapter Installed when upgraded fron Non-Can to Can-bus radio..
- b5, what gives a flatter resoponse, bose coding or non bose?
- dension icelink or dice ipod thing?
- XM station preset text is wacked out...
- Is there a way to connect and iPod Shuffle to a Concert HU?
- Head Unit replacement tip
- Rear speaker phasing/cut out trouble...
- Paging Sir Lord Avincar
- Replacing Bose Speakers, found a solution...
- Audi Ipod Interface
- is the ipod the only way to go?
- Symphony+Phatnoise+Sirius Starmate....will this setup work? If so, what is needed?
- X Post for DICE help..............
- My upgraded audio system in my 2001 ar
- ice link plus dilemma....no sound from right side speakers!!! HELP
- Searched this forum but no luck so I'll ask. How do I load my iTunes
- Thanks to TeddyBGame for the RNS E install on a B5
- looking for an ice link plus trunk cd changer cable....
- Thoughts about JL's cleansweep
- Is dual satellite Radio possible in Q7 or A6(C6)
- IceLink Buggy - Previous Track on HU doesn't work properly alot of the time. Normal?
- power connection A3 sportsback
- hit or skip: boston acoustic g210 dual voice coil 10" sub
- Gentleman we have lift-off! Center Speaker Grille is OUT!
- X-post: looking for Concert I radio with CD player
- not quite related to audi, but mabey someone can help me real quick
- radio not working
- concer radio unlock please !
- Sirius Satellite Reciever
- dvd help
- A4 B5 Amp Wiring Project
- Sirius and IPOD
- S4 audio upgrade
- Delta CC to Concert I swap - Bose amp relay needed?
- Rear Speaker Trouble
- It's Official: Need Help! Need detailed instructiosn how to remove center speaker grill on a B6!
- brand new nokia n93 $230usd , nokia n95 $350usd
- SD Card Troubles - A4 Avant
- Line level outputs and no steering wheel controls?
- Completed Icelink Install This Weekend - Thanks To SouthboroAudiGuy
- Got the Icelink in... now got hiss from center speaker.
- XM sat antenna...
- Some tips for Car Computer or Laptop hookup
- question bout putting my subs in
- Okay... help me find the ground point on this Symphony II?
- Anybody using the Blue Tooth system with the new Alpine head units?
- Sub in B7 Avant
- Yet another Ipod install question... (A4 B5 2000 Bose)
- Sirius Satellite Radio
- Audi Newbie with iPod & Sat Radio questions
- Any good sources of Rainbow speakers in the US?
- symphony removal frustration...help?
- SD Card help...nned REAL expert
- Radar Detector Sensitivity Question?
- DB-25 pin CD Changer for delta radio
- urgent car audio help - aftermarket headunit with bose
- Just got my D310 by alpine, looking to add nav any thought on the
- Anyone have experience with using time alignment?
- newbie a3 owner needs ipod/aux advice
- Bose in B7 advanced features or tuning
- car audio porn
- aux in and amp
- Horrible radio reception - Any suggestions?
- newbie looking for 07 A4 Avant audio (basic ) upgrade advice
- Where does the XM module go in a TT?
- What do you guys use to download MP3's?
- I completed my audio upgrade in my B7 and I have a comment on grounding the Bose pin.
- After market deck with bose
- Is there something to hook up a usb port to an alpine touch screen?
- Need help with Ice Link. Got it installed, it lights up, but the changer wont recognize something
- Are there any decent cheap speakers that I could use in my B5 A4?
- JL 12W7 Prowedge
- JL Stealthbox for 96-99 A4. What size bolts (diam-thread-length) hold that bish up?...
- VAG HELP
- Dice Dice Baby ! (help with) Vanilla Dice Dice Baby!
- Non-audi guy needs help on b5 non-bose stereo upgrades
- I need HELP with removing my center channel speaker in my B7. Here's how far I am...
- 98 audi concert radio PROBLEMS
- Blitzsafe owners, need your help.....
- 02 A6, speakers depth and size of tweeter
- Updated: Just a heads up for AW....
- delta radio switch
- bose subwoofer in 02 a4
- Any Ipod skins work with Icelink cradle?
- new to audi world....b7 harness for aftermarket radio..
- static and bad reception
- Any other option beside ProClip for mounting IceLink in a B6?
- A4 B5 Front Speaker Replacement (previous search performed)
- X-post from B5 A4
- Headphone jack audio input for B7 A4
- CD Changer cassett
- Adding speakers to a concert headunit?
- Is a Symphony II to Symphony II+ upgrade plug and play?
- How does the Phatnoise hook up to a B6 factory head since the changer is in the dash?
- Just noticed Focal makes amps, anyone ever hear them. Thoughts? $$$? Specs?
- Tried recoding my Symphony II head unit to Bose and I don't think it's changing...
- My Kenwood is pooched!
- Car concert Radio clips broke.. can't remove it. what to do ?
- A4 Speakers and Subs
- Location of rear speaker amp on 1998 A6 2.4
- ipod nano icelink install in card drawer
- swapping Delta unit for other audi In dash CD Player?
- Parrot CK3000 Evolution with a Symphony II BOSE
- avincar....looking for a hard hitting SQ sub. Preferably 10'' that will fit in a 1-1.3 cube
- In a 2003 ar with Sym II bose (I think) is there a way to tap the lines to an amp for a sub...
- Hello. I just got a B6 A4 and the stock bass is kind of lacking. What's a good solution
- Upgrading Audio on a 2007 S6
- anyone interested in swapping an xm module for a sirius module for an rnse?
- Bose in 01 A6 Blinks
- Sorry for the Noob question, but.......
- AM radio reception is BAD
- B7 A4 Non-Bose Stereo Install Initial Pics (slight BWW)
- Alpine IVA-W200 help
- know of really cheap 6.5" speakers I can buy w/ decent sound quality and some decent bass
- Some RNS-E Parts Needed
- Wierd static problem
- ISO: 8E0 035 593/8E0 057 593
- BOSE Radio_Base suppression at high speed on A6 3.0 2003
- Questions about Harman Kardon Drive+Play iPod Connection
